01-06-2019, 09:14 AM | #23 |
Rep 5,322
Numbers are a mute point if you have actually got in the vehicle itself.
It’s simple. X5=‘s 2rows. X7=‘s 3 rows. Everything else is equal so how many people you need to move is what determines the choices. I am sure there are those that are dissatisfied with the room in their Bentayga but nit picking about cubic inches takes first world problems to a new level. Last edited by MystroX5; 01-06-2019 at 09:24 AM.. |
sygazelle11347.00 |
01-06-2019, 12:00 PM | #24 | |
Rep 3,406
When something doesn't add up, there is usually a reason in my experience. Like you, I couldn't understand where the space went. Could the Top Speed possibly be right given the extra 1" or so in total length of the G05? So, I decided to check a couple of other sources for the actual G05 dimensions and, as it turns out, the Top Speed article's dimensions that were used to establish their dramatic design trickery conspiracy theory were incorrect! The actual cargo space is 48% bigger than they reported with 3rd row seats up and 10% larger than they reported with the 3rd row seats down. So, at least part of this mysterious space loss has been found. I'm wondering if author Kirby will be writing an update to his dramatic BMW trickery article? I'm guessing the answer is no. We will see. Last edited by sygazelle; 01-07-2019 at 08:00 AM.. |
01-06-2019, 12:09 PM | #25 |
Rep 3,406
It turns out the Top Speed article had incorrect cargo space figures. Here is a comparison of the X15 to the GO5 with accurate information. Bottom line: The total leg room is a tad bigger in G05. The cargo area is 4 cu ft. smaller, but not the whopping 11 cu ft difference reported by Top Speed.
First # is bogus Top Speed volume. Second # is accurate. Spacegate solved! Cargo Volume to Seat 2 (ft³) 22.8 33.9 Cargo Volume to Seat 1 (ft³) 65.7 72.3 Last edited by sygazelle; 01-07-2019 at 10:33 AM.. |
Doc5513450.00 |
01-06-2019, 12:17 PM | #26 | |
Rep 631
01-06-2019, 02:00 PM | #27 |
Rep 2,599
The issue is rear space is smaller than other competitors like Cayenne. I was disappointed all the length made it no where as spacious as the Cayenne cabin. X3 has the same problem too, almost dead last in its class.
01-06-2019, 11:07 PM | #28 | |
Rep 3,406
Since you have good source for cabin dimension information on the Cayenne, would you please share this info with us all. I'd like to know just how much more roomy the cabin space is in the Cayenne vs. the G05, in terms of cargo space, legroom front and back, sholder room, headroom. Thanks. |
01-07-2019, 08:41 AM | #29 | |
167
Rep 405
The Cayenne provides 27.1 cubic feet of cargo space with the rear seats up and 60.3 cubic feet with them folded. Those numbers drop slightly in Cayenne Turbo models (to 26.3 and 59.3 cubic feet). This Porsche doesn't have the smallest cargo hold in the class, but most other luxury midsize SUVs have higher capacities. A power liftgate comes standard." No info on legroom. What does that suggest? |
01-07-2019, 11:26 AM | #30 | |
Rep 3,406
01-07-2019, 12:21 PM | #31 |
Self-Deprecating Narcissist
7266
Rep 6,561
also keeping it closer to the cabin for proper weight distribution which isn't a concern of Lexus either.
01-07-2019, 02:40 PM | #32 | |
Rep 2,599
Still a nice car though. |
01-07-2019, 05:26 PM | #33 | |
Rep 3,406
01-08-2019, 02:43 PM | #34 | |
Rep 2,599
I personally am waiting for the X7 for the different looks and presence which allows me to overlook its tight rear space. |
01-08-2019, 10:13 PM | #36 |
Rep 2,599
Had checked the specs space is the same so will be as tight as he X5, but willing to overlook that as mentioned. Space is not everything, Hope it drives well.
01-08-2019, 10:46 PM | #37 | |
Rep 3,406
I'm still trying to wrap my mind around you calling the X3 almost dead last. If you are going to make claims like that, why not entertain us with a fact or two showing how you arrived at that conclusion. I guess that is par for the course with this thread since the OP called the space lame and cited a Top Speed article as his source when it turned out the Top Speed article was way off in the cargo specs. Look, the X5 and the X3 aren't going to be for everybody. They were designed for a certain market in mind. If space is an issue, there are plenty of other excellent choices. Its a great time to be a car buyer. |
01-09-2019, 01:17 AM | #38 | |
Rep 2,599
Here is a snippet of the X3 forum, dead last in its class for rear legroom. https://x3.xbimmers.com/forums/showp...6&postcount=63 For the X5 Autogefuhl also complained on rear legroom of X5, less than Cayennes and new GLE, see their YouTube videos. In conclusion having sat and researched I suspect from BMW marketing research of their customers they decided to prioritize trunk space for the car over rear legroom for the X5/3. I am not knocking BMW, it’s just surprising given the size increases from last gen. Front legroom adequate for 6 footers which matters most! |
Mark609166.50 |
01-09-2019, 03:53 AM | #39 | |
Rep 3,406
1) It does seem like BMW is going for cargo space at the expense of legroom. 2) The X3's poor legroom performance is possibly and partly due to the fact that its engine is mounted longitudeinal as opposed to transverse direction. The QX50, NX, and XC60 engines sit sidways allowing their dashboards to be more forward, allowing for more legroom I suppose (not an engineer). The X3 is still lowest in legroom even among the longitudeinal models (GLC and Q5), but in both of those cases, the X3 beats them in cargo space. So, articles may be written any number of ways based on the author's focus. If the focus had been cargo space, the X3 would have shown more positively in the article. As to the OP that started all of this space talk, the numbers in in the referenced Top Speed article were just plain in error. I suppose doing another analysis (engine mount direction, cargo space, legroom) for the X5 and its competitors would yield similar results. More cargo space, less legroom. Tranverse engine mount gains a bit of space. I cannot believe, as the Top Speed article claims, that BMW is purposely being inefficient or hiding space somehow to make the X7 look more appealing. |
Mark609166.50 |
01-09-2019, 08:36 AM | #40 |
167
Rep 405
Thanks for the chart. Kinda wish you had included the X5 specs. Combined legroom is 77.2, only 1/2" more than the X3. Pretty pathetic but since we only have rear passengers maybe 6 times a year we'll just have to deal with it.
sygazelle11347.00 |
01-09-2019, 08:46 AM | #41 | |
167
Rep 405
Acura MDX is very roomy. BMW screwed up somehow. Lengthened the car and the legroom is pathetic? This is where a pretty face is more important than functionality. We got a great deal since you mentioned it. |
iconoclast7265.50 |
01-09-2019, 08:51 AM | #42 | ||
Rep 631
01-09-2019, 08:59 AM | #43 | |
Rep 6,121
for comparison these are the vehicle lengths and wheelbases X5 (G05) Length 194" Wheelbase 117.1" Q7 200"/ 117.9" GLE 194.3"/ 117.9" XC90 195"/117.5" Cayenne 194"/114" The X5 is the same length as a 2019 Cayenne with a slightly longer wheelbase. Audi's Q7 is by far the longest of the bunch as noted. edit: corrected a typo
01-09-2019, 11:32 AM | #44 | |
Rep 3,406
Here's the chart. |
Mark609166.50 iconoclast7265.50 |
