04-26-2023, 06:13 AM | #23 | |
13276
Rep 19,807
04-26-2023, 06:46 AM | #24 | |
37
Rep 322
Question about Bimmercode Expert Mode. What happens when I set a value in expert mode that is Unassigned? For example: C_WUNSCHGESCHW_min_kmh in ICMQL has options: 00 = 20 km/h 01 = 30 km/h 02 = 50 km/h 03 = ... 10 kmh is not a setting. Let's say I set this field to the actual speed in Hex: 0A=10km/h instead of available option in Hex, so the result is 0A = Unassigned Another example: Minimum heated seat temperature for setting 1 set to 0x19, 25c in Hex, instead of the minimum option 30c or 31c in Hex. 25c is not a setting, so the result is 0x19 = Unassigned. What would happen in the above cases? The system would be broken, or it defaults to the minimum assigned value? |
04-26-2023, 07:00 AM | #25 | |
13276
Rep 19,807
My advice would be to only make changes that you know are correct and proven to work. There are hundreds of threads on coding to look at.
09-30-2023, 10:21 AM | #26 | ||
Rep 1
I was looking around trying to find out if it was possible to add driving assistance to my g21 lci, and came across your picture and it made me abit confused since my car only has (SA 5DF) but it still has lane departure warning and speed limit info from (SA 5AS), but not blind spot monitoring and other stuff, would you have any idea how that is possible? |
09-30-2023, 11:10 AM | #27 | |
13276
Rep 19,807
