06-13-2021, 05:57 PM | #155 |
Rep 6,916
One thing to also consider...the ball adapter on a WDH can be in the 75# range, so you need to add that to the actual tongue weight of the trailer.
Yes, a WDH will transfer some weight to the front axle from the rear one, but it does that by twisting on the body. The body is only so stiff. From your weighing exercise, it appears that that big lever is pushing/twisting about 200# average, and more when you go over a bump. |
06-13-2021, 06:49 PM | #156 |
Rep 585
Another thing to consider- propride (which is the best WDH on the market) is 180 lbs. However, it adds ca. 3 ft of length between the tongue and the receiver. Therefore, actual impact on the TW is in 60-80 lbs range.
Unibody is very rigid, stiff. Much stiffer than body on frame. Using WDH should not be an issue. The hitch may require reinforcement, but no problem with WDH and unibody. |
06-13-2021, 08:16 PM | #157 | |
Rep 114
06-13-2021, 08:20 PM | #158 | |
Rep 114
06-13-2021, 11:30 PM | #159 | |
Rep 585
Air suspension does not transfer any weight. IMO you should set up WDH based on CAT scale tickets (trying to restore front axle weight and not to exceed rear axle limit).
I started towing without air suspension - just set up the WDH based on CAT scale measurements. Then I added air bags in the back to to help the suspension. It just level the tow vehicle but is not necessary, if WDH is set up correctly. Quote:
elp39.00 |
06-15-2021, 12:44 AM | #160 |
Rep 802
As I sit here, browsing the internet late at night, I wanted to run a crazy idea past everyone. I've got an x5m which I'm planning on towing with, close to the 7700 lbs weight limit. I'll be using a reinforced tow bar with WDH and anti sway, etc.
So far, everything above seems doable and I'll be respectful of the tongue weight. Here's where browsing the internet at night can be dangerous: I saw a product that's essentially air bag sleeves that slip inside the rear coil springs. The idea is to help level out the back end while towing. This is pretty common for pick up trucks, but I doubt anyone would be crazy enough (…) to do this on their X5s. Im wondering if 1) it's worth doing 2) more importantly, when deflated/not towing, if it would impact handling dynamics/performance in any way. From what I've seen, they just deflate and sit inside the Center of the coil spring. Doesn't look like they get in the way of anything when not being used. Has anyone done anything like this on a SUV? I realize this is probably a question better suited for the manufacture but I'm hoping for a non biased opinion (I already know I'm likely crazy for even considering this haha) - the kit I saw was x5 specific, so I'm assuming it's been tested already.
Current: MB 21 X5 M Comp | '20 Z4 M40i
Past: 09 M3 Coupe DCT (sold) | 11 1M Coupe MT (sold) | 15 i3 REX (returned) | 15 X3 35xi (sold) | 16 M235xi Vert (returned) | 18 M3 Comp Ultimate DCT (sold) | MW 20 X5 M Comp (totalled) |
06-15-2021, 02:17 AM | #161 |
Rep 585
This is exactly what I have installed in my E70. I am not a real DIY person, but I could do it.
For $100 it is worth it. No impact on handling when deflated. https://amzn.to/3gsiOFe |
-cj-201.00 |
06-15-2021, 08:22 AM | #162 | |
Constantly Learning
66
Rep 200
I believe the max towing is 7,200 and only when having the factory towing package. Which, by the way, includes rear air suspension. Without the factory tow package, the max tow is 6,000 pounds.
-cj-201.00 |
06-21-2021, 07:51 PM | #163 |
Rep 1
This is my first post. I have a 2019 BMW X5 XDrive40i.
I bought it for my wife. I drive a 2016 BMW 328 because I can whip it around town easier. That said, I was somewhat concerned about being able to tow and launch a boat. I recently bought a 2,700 pound boat. With the motor, trailer, gas, gear, etc. the total weight is 5,000 pounds. It’s a 24 foot center console boat. I have towed it over 30 miles one way in city traffic. I have launched it at slimy boat ramps. The X5 is a towing beast. The AWD XDrive gives you plenty of confidence on the ramps. I am only reiterating what plenty others have posted on this thread. The only reason I’m posting now is in appreciation for the info shared previously by you all. My X5 did not come with a hitch. I had a hitch retrofitted by a reputable independent BMW hobby shop. They did a great job. It’s not an invisihitch. And it’s not the awkward shaped euro hitch either. It’s a standard hitch receiver but it’s from the BMW factory. I also have OEM wire harness and module that I bought separately from a dealer. The shop also had to install software on the X5 which went through without any problems. Now I have “trailer mode” which I did not have before. I’m posting this for posterity. If anyone has an X5 and is unsure about towing and launching a boat, don’t be (assuming your entire rig is 5,000 pounds +/- 500 pounds. P.s. You will need a hitch with a 2” drop and a 2” ball. My trailer sat perfectly level with that setup. I do not have air suspension and it’s not necessary to tow my boat and trailer. |
06-24-2021, 03:18 PM | #164 |
200
Rep 353
We're looking at getting a camping trailer for the 45e next year. The reduced towing for the 45e is 5,952 lbs and 551 lbs at the hitch. Inside the driver's door it says that the load limit for passengers and cargo is 947 lbs. If I assume a hitch weight of 500 for a light weight trailer, does this leave me with just 447 pounds inside the vehicle? Does the hitch weight counts against the vehicle load limit?
06-25-2021, 10:53 AM | #165 |
Rep 89
My mistake was not having a tow hitch and I MTB. First world problems…lol!
06-27-2021, 06:10 PM | #166 |
Rep 65
Hi guys, I have the rack package from Stealth hitch. I need to get a utility trailer and Im wondering if I can use a 2" ball adapter to just tow miscellaneous things to the dump from my house. I know I am not supposed to tow anything with the rack and the ball mount they sell is used for towing but it would be a medium sized (6'x4') utility trailer. Does anyone have any thoughts or expertise on this? Thanks
06-27-2021, 10:14 PM | #167 |
Rep 6,916
Buy their ball adapter. The receiver plug-in is not designed for the load of a trailer. Better safe than sorry. The receiver plug-in doesn't have all that much of a load rating...sufficient for bike racks, but not for the dynamic stresses you might get with a trailer.
Thought they normally sold it with both the ball and receiver plug-ins...they used to be packaged separately. Maybe I just haven't read it recently... |
06-29-2021, 07:53 AM | #168 |
Rep 25
All, hope some can help
I just got delivery of x5 and I am trying to get the 13 to 7 pin adapter to fit How do I get the fitting right? Once fitted, can It stay on permanently and will it retract without any issues?? This is the adapter i have https://www.amazon.co.uk/gp/product/...?ie=UTF8&psc=1 Thanks |
06-29-2021, 08:55 PM | #169 |
Rep 6,916
The gooseneck retracts, but I didn't think the plug did as well.
You'd need to run the system through a retract/projection cycle and see how much clearance there is. There's usually a cover on the 13-pin socket, so if you left the adapter on, unless it has a cap, the contacts could be corroded. I had a 13-pin socket on my last vehicle (I bought it in England and took it back to the states with me), and it's super quick to insert a plug into the socket, so I would just leave that adapter on the trailer rather than the vehicle. |
06-30-2021, 12:23 AM | #171 |
Rep 28
Trailer brake controller
I am new to towing but my friend used to tow his track car with his 2012 x5 diesel. I got the factory tow package for my 45e which has 2 plugs at the back.
Do I still need a trailer brake controller when towing a car? |
06-30-2021, 12:08 PM | #172 |
Rep 114
It depend on what you are towing but for most cases I would think so. Curt Echo wireless brake controller seems to be working quite well for a number for folks here on both X5 and X7. Personally I have not had any issue other than the rubber strap not staying in place but there are ways you can keep it secure.
06-30-2021, 04:24 PM | #173 |
Rep 6,916
The user manual lists which towing loads require brakes on them. Most trailers that need them will require a controller installed unless the trailer has it’s own that activated them automatically…don’t remember what they’re called.
07-08-2021, 10:52 AM | #175 | |
Rep 7
7 pin connector
07-08-2021, 10:55 AM | #176 | |
Rep 7
Echo
