04-27-2023, 03:14 AM | #1 |
Rep 5
TPMS Retrofit
My G05 does not come with TPMS (rubber valve stem).
So basically as the vehicle already has a receiver, to retrofit, can I just buy 4x433Mhz BMW TPMS from ebay or anywhere, install it, and use bimmercode to show temp and pressure? There is no need to tell the car, using a TPMS tool, the ID and which tire like what are on youtube for other car brands? Thank you so much for your comments! |
04-30-2023, 08:13 PM | #2 |
Rep 6,806
Are you sure it has the TPMS receiver?
You may need to do a bit more coding to tell the vehicle to use the TPMS versus using logic to determine if a tire pressure is low (it does that by counting revolutions...a low pressure one will have a smaller rolling diameter). |
04-30-2023, 11:19 PM | #3 | |
Rep 5
From this, it seems that the Remote Control Receiver (receive signal from car key to lock/un-lock) is also functioning as a TPMS receiver? Not sure if I interpreted this correctly or not.. Last edited by podpod; 04-30-2023 at 11:36 PM.. |
07-20-2023, 06:29 PM | #4 | |
Rep 158
If no tpms came with factory likely you would need to retrofit a new DSC as its a integrated system for tire press and temps. |
