12-26-2019, 11:23 AM | #23 |
Rep 1,155
Not sure how they work on GO5 but on most models they work when you turn the wheel past a certain point, nothing to do with turn signals, you don't indicate when you are taking a bend.
12-26-2019, 01:49 PM | #24 | |
1053
Rep 1,952
Adaptive lights = lights that follow the turn angle of the steering wheel to light past a bend up the road. Cornering lights = seperate set of lights that light up 90 degrees to the car to light up the road when you're making a sharp turn... Say into a driveway or onto a street. For the US G05 only the Lazer lights get the cornering lights. However all models get the adaptive LEDs. |
polychromatic134.50 |
12-26-2019, 03:20 PM | #25 | ||
Rep 120
12-26-2019, 05:20 PM | #26 | |
Rep 1,155
12-26-2019, 08:02 PM | #27 |
805
Rep 1,790
I have a 2020 X7 40i and I believe the "Adaptive" lights are standard on the X7.
However, I don't think the "Standard LED" headlights come with the cornering lights. At least not in the US. This might also be a "Regional" option depending on what country the vehicle was built for. I just looked at my headlights again and it looks to me like the spot for the cornering lights is covered with a plastic plug. See the attached .pdf which shows both the Laser Lights and standard LED lights. Both the Standard LED and Laserlight headlights are showing the cornering lights on pages 33 and 34. Now take a look at my left front headlight assembly and you will see that there is no light in the spot identified as the "Cornering Light" in the .pdf. I was under the impression, reading my owner's manual, that my vehicle came with the cornering lights. Obviously that's not the case...Bummer! |
12-26-2019, 08:05 PM | #28 | |
13275
Rep 19,803
At least for the X5, the tech document is incorrect regarding the element that is used for the non-laser headlights. It shows a cornering light but that is not used, at least in the US and some other countries. Perhaps the X7 is the same. |
12-26-2019, 08:16 PM | #29 |
805
Rep 1,790
I believe you're right. Maybe there are no cornering lights for either the X5 or X7 here in the US.
12-29-2019, 06:20 AM | #31 | |
Rep 112
That is actually correct, depending on which X5 tho. I didn't realize the cornering lights and headlights are one unit on the G05, as BMW has two cornering lights trigger logics: 1, F15, F16, F10, F01 (pre LCI) just a few examples, if the headlight units don't include cornering lights, then they use fog lamps as cornering lights, in which case, can be triggered by a) turning steering wheel in either direction, b) turn indicator on for either direction, independent of steering input, and c) when in reverse both fog lamps/cornering lights are on; 2, F12, F13 (if equipped with LED), F01 (LCI), G05 for example, they have headlight units with cornering lights included, in which case, they are only triggered by turning steering wheel in either direction |
12-29-2019, 06:24 AM | #32 | |
Rep 112
On G05 and models with cornering lights included in the headlight units, can only be triggered by steering angle; on models don't include cornering lights in the headlight units, they use fog lamps instead, in which case, are triggered by a) turning steering wheel in either direction; b) turn indicator on for either direction, independent of steering input; and c) when in reverse both fog lamps/cornering lights are on. "you don't indicate when you are taking a bend", that sounds like you were referring to adaptive headlights |
12-29-2019, 06:29 AM | #33 | |
Rep 112
Correct for models with cornering lights included in the headlight units, and they can only be activated with steering input, however, for models without cornering lights in the headlight housings, and use for lamps as cornering lights, they can be activated by 3 ways: a) turning steering wheel in either direction; b) turn indicator on for either direction, independent of steering input; and c) when in reverse both fog lamps/cornering lights are on. |
12-29-2019, 06:30 AM | #34 | |
13275
Rep 19,803
12-29-2019, 06:31 AM | #35 | |
13275
Rep 19,803
That its not correct either unless there was a change in the last few weeks. The fog lamps do not operate as cornering lights on the G05. |
12-29-2019, 06:38 AM | #36 | |
Rep 112
There are two types of cornering lights: included in the headlight units or using fog lamps as cornering lights. I'm not sure if BMW would program the fog lamps to function as cornering lights on cars like yours, which the headlight units have spots for the actual cornering lights, but wasn't included due to option; or just outright not offering this feature. Can you give it a try and see what happens? |
12-29-2019, 06:39 AM | #37 |
Rep 112
12-29-2019, 06:42 AM | #38 |
Rep 112
Fine, and I already explained why I assumed they would function the same as most previous models! I have a X7 not a G05 and didn't know they had the same headlight functions. Regardless, I explained perfectly in detail and expanded your knowledge on cornering lights. Cheers
12-29-2019, 07:50 AM | #39 | ||
Member
899
Rep 2,032
Drives: 2019 X5 40i M Sport
Garage List 2023 BMW M2 (HEA) [10.00]
2021 330i xDrive [0.00] 2019 G05 X5 M Sport [0.00] 2017 Jeep Grand Che ... [0.00] |
2019 X5 Alpine White M-Sport
Software Version 11/2022.31 2023 M2 (HEA) Brooklyn Gray 2021 330i XDrive Alpine White M-Sport |
12-29-2019, 10:35 AM | #40 |
13275
Rep 19,803
12-30-2019, 06:15 PM | #41 | |
805
Rep 1,790
No cornering lights and no fog lights turning on while the steering wheel is cranked all the way to the left or right. So, no Laser Lights equals no cornering lights. |
12-30-2019, 06:33 PM | #42 | |
Rep 4,246
As you succulently stated - no Lasers = no cornering lights in the USA for now. They could add them in the future as part of the G05 LCI (lifecycle impulse) update. He is correct that F Series BMWs utilized fogs for cornering. Back then (sounds long but only a year, two years ago) Xenon headlamps were standard and LEDs were optional. But since we're discussing G Series vehicles, it isn't relevant to this discussion.
12-30-2019, 11:51 PM | #43 | |
Rep 112
People don't read! Not surprised! "BMW has two cornering lights trigger logics: 1, F15, F16, F10, F01 (pre LCI) just a few examples, if the headlight units don't include cornering lights, then they use fog lamps as cornering lights, in which case, can be triggered by a) turning steering wheel in either direction, b) turn indicator on for either direction, independent of steering input, and c) when in reverse both fog lamps/cornering lights are on; 2, F12, F13 (if equipped with LED), F01 (LCI), G05 for example, they have headlight units with cornering lights included, in which case, they are only triggered by turning steering wheel in either direction" |
12-30-2019, 11:52 PM | #44 | |
Rep 112
Again READ!!! I don't post incorrect information, actually my info is so vast, you can't quite follow! However, you did post incorrect info, but I didn't bother to correct. Here is it AGAIN! "BMW has two cornering lights trigger logics: 1, F15, F16, F10, F01 (pre LCI) just a few examples, if the headlight units don't include cornering lights, then they use fog lamps as cornering lights, in which case, can be triggered by a) turning steering wheel in either direction, b) turn indicator on for either direction, independent of steering input, and c) when in reverse both fog lamps/cornering lights are on; 2, F12, F13 (if equipped with LED), F01 (LCI), G05 for example, they have headlight units with cornering lights included, in which case, they are only triggered by turning steering wheel in either direction" |
