03-07-2024, 01:47 PM | #1 |
Rep 140
Side lights icon in the Instrument cluster
I've just picked up my replacement 50e and noticed that the side light icon in the instrument cluster is missing, as in there is no icon! Turning OFF the 'Automatic driving lights control' button turns on the dipped lights and displays the Low-beam headlight icon.
In my previous 50e the side light icon did display so my question is - is this a fault in this car or is it a new 'feature' (or lack-of-feature)? Thanks in advance... |
03-07-2024, 01:54 PM | #2 |
Rep 1,196
Click the lever type switch at the end of your turn signal stalk although UK builds may differ?
2024 X5M60i-- Skyscraper/Ivory
2020 Cayenne replaced by ^^ 2017 X5 35d--still in my diesel phase 2015 GL 350--diesel burner/highway queen 2013 Audi S6--a beast in it's day |
sarpal12368.50 |
03-07-2024, 02:17 PM | #3 |
Rep 140
The left steering column lever has a button for displaying the fuel consumption (based on other settings) and a button for toggling main beam. This doesn't affect the daytime running lights display (AFAIK)
03-07-2024, 03:57 PM | #4 |
Rep 8,803
Drives: eVeRyOnE mAD!
in my 2021 45e, activating AUTO on the lighting panel doesn't display any icons in the cluster UNLESS the lights are actually on. for example, during the day when no headlights are needed, there's no icon in the cluster, but when it gets dark enough, the AUTO setting turns on the low-beams and parking (side) lights, and only at that point do i see their icons in the cluster.
i would think this behavior is the same on the 50e? |
03-07-2024, 04:21 PM | #5 |
Rep 1,201
The button on the left lever (bottom) is for auto headlights not for toggling main beam. Have you checked the settings in idrive, will see what is on the instrument panel in my car tomorrow.
2024 M60i Frozen pure grey/Black Merino
2023 M50i Tanzanite / Ivory/Night Blue Merino gone 2022 40i G05 Arctic grey/Ivory Merino gone |
sarpal12368.50 |
03-08-2024, 05:20 AM | #6 | |
Rep 140
03-08-2024, 07:34 AM | #7 |
Rep 140
OK, so I've just tried this out in the car and pressing this button in daylight has no effect and the sidelight icon remained on in either position. Reading the manual; it does look like the button activates high beam assist, which is only available at night, with low beam active (why you would not have it on at night is beyond me).
03-08-2024, 07:40 AM | #8 | |
Rep 94
03-08-2024, 07:51 AM | #9 |
Rep 140
so, why is it displayed (during the day) in my first 50e and the loaner I'm in now, but not visible in my second 50e that I had for 48Hrs? In all cases, the cars have the daytime running lights on. I can't think of another setting that I need to/should have set.
03-08-2024, 08:45 AM | #10 |
Rep 1,201
That light is on all the time in my new LCI and was in my previous X5, I believe it is on if the daytime running lights are on and if fitted have to be on in UK and thus
will always be on.
sarpal12368.50 |
03-08-2024, 10:04 AM | #11 |
Rep 140
Excellent, as I suspected; it should be visible, therefore it is likely that it is broken in my newest 50e and I'll have to take it up with my dealership. Appreciated
03-09-2024, 09:05 AM | #12 | |
Rep 8,803
04-21-2024, 07:54 AM | #14 |
Rep 140
SOLUTION
BMW finally came back with the solution and it's all to do with the "BMW Iconic Glow". If the iconic glow in the radiator grille is turned OFF (Exterior lighting, Additional settings, BMW Iconic Glow) then the "Side light" indicator in the instrument cluster is turned off. Turning the "BMW Iconic Glow" ON will display the "Side light" indicator light on. I can't think of a scenario where that makes any kind of sense, but there it is. |
04-21-2024, 08:17 AM | #15 | |
Rep 1,201
04-21-2024, 10:28 AM | #16 |
Rep 140
04-21-2024, 10:58 AM | #17 | |
Rep 638
The iconic glow makes sense, I don’t have that on my 50e (and would turn it off if I did ). The indicator light logic is flawed though, in my opinion! |
