02-07-2024, 08:41 AM | #45 | |
44
Rep 37
02-07-2024, 08:46 AM | #46 |
44
Rep 37
oh well, I guess we are luckier than the ones bought the new 50e. Seems that one has tons of problems. I just wish coding the car can be done in independent garages. So I do not have to deal with the dealer's absurd charges. I thought it should be possible since Safelite does replace BMW windshield that they are able to calibrate all the cameras and sensors attached to it. So seems they have access to BMW's latest software.
02-07-2024, 08:54 AM | #47 | |
13275
Rep 19,805
Link for mobile app users -CPO Exclusions BMWCPOWhatIsNotCovered.pdf.asset.1691598782694.pdf
02-07-2024, 09:04 AM | #48 |
Rep 99
Drives: X5 50e
If I were concerned about this, I would run a fine bead of cyanoacrylate adhesive ('Super Glue' - the watery version) around the very edge of that shark fin! ...and where it wicks in quickly, add significantly more!
02-07-2024, 09:11 AM | #49 | |
44
Rep 37
Bottom1615.50 |
02-07-2024, 09:27 AM | #50 |
13275
Rep 19,805
Since the OP's is a 2019 it wouldn't be covered by that SIB. I thought there was an earlier one though, maybe someone has it.
02-24-2024, 04:29 PM | #51 | |
Rep 4
Going through this now and considering replacing hardware myself. Did the dealer program for you after replacement? Seems like they might be against this or charge out the wazoo for something like that. |
02-25-2024, 09:39 AM | #53 |
Rep 4,337
I used clear silicone around the sharks fin when I replaced it on my wife's GTi. If you're good at caulking, you won't even see it when done. Proper prep is essential, meaning a good cleaning of the area with alcohol and then a firm press when applying. It's been a year and no leaks.
Bottom1615.50 |
04-14-2024, 08:05 AM | #54 |
Rep 273
Went to the AD yesterday to get this all sorted finally. They quoted $630 to do the programming and update the software.
Shortly after leaving they called saying that the TCB (TCM) is dead and there was no communication to the unit. Advised that I didn't install it properly. I told them that this was a simple replacement and that I had purchased all OE parts from a different AD and that I highly doubt it was not installed properly. They said they would do an inspection to see the issue but I would be charged. Gave them the green light, was worried af that there was another water leak!! Turns out that there was blown fuse. Part # 61-13-6-917-401 Fuse Mini, Yellow-Brown So all parts that were replaced were the Cap, Antenna, TCM unit, Battery and a fuse So far everything is working fine, software is 03/2024 Good luck for anyone doing this DIY |
