      02-16-2020, 09:04 PM   #1
rastaman777
Drives: 2020 i8 coupe,2019x5,2019 740i
Bimmercode
So, I finally coded my G05 tonight.
I've been sitting on the ODB/bluetooth adapter for months.
I was quite disappointed with the available features to modify.
Most of the stuff I wanted, which is generally what most people want, was not available.
I've used e-sys with a laptop many times, but it's a been a few years.
Anyone have any suggestions on alternative options for coding with more features available to modify?
      02-16-2020, 10:38 PM   #2
902
138
Drives: 2020 M340i xDrive
There's a new update to BimmerCode coming soon (which is in beta right now) that supports the Body Domain Controller module which will give you access to a lot more coding options.
Appreciate 4
mcsa65.00
VTENGR1052.50
      02-17-2020, 04:57 AM   #3
James_G0540i
Australia
446
Drives: 2021 X5 G05 40i M Sport
Finally !!!!!!..I wish they'd hurry up !
      02-18-2020, 01:39 AM   #4
fengyonghua21
Drives: F15
thankyou
      02-18-2020, 02:51 AM   #5
ifr
ifr's Avatar
United Kingdom
1198
Drives: Tesla MY LR AWD
Which G05 ECU's can you configure in expert mode using bimmercode?
How does it handle increments in i-step version? The issues with esysx/Launcher is keeping every ECU cafd mapped for every model and updated with every i-step version.
The key ECU's are BDC, HU_MGU, SASx - if bimmercode provides unlimited untrimmed access to these ECU's and provides updates for each new i-step release you could have a near perfect product there.
      02-18-2020, 06:23 AM   #6
James_G0540i
Australia
446
Well, looks like Bimmercode has been updated.
Just tested version 2.17.3-6357, and the Body Domain Controller ECU is now accessible and can be coded, including "Expert mode".
Anyone know how to add Sports+ mode in Expert mode?
      02-18-2020, 08:39 AM   #7
bemagrp
265
Drives: 23 Alpina XB7/21 Alpina XB7
I believe:
ECU BDC_BODY3/00007083 parameter FesPiaDefaultLastUserMode to 02
Now that I have access to the Body Domain Controller, I had to code TWO rows under 3221 PfFesMaster:
- FesPiaDefaultSportWorldMode: Changed to 0x02 (SportExpert) - from 0x01 (NotSportExpert)
- FesSportWorldMode1: changed to 0x02 (SportExpert)
Never tested myself yet.
Also, will program myself ( gotta find all in expert code with Bimmercode.):
FEM_BODY 3062 MAPPING_STANDL_V_L_PWM_LEVEL_1 32 8 Change Angel Eye Brightness when headlamps on (Left)
FEM_BODY 3062 MAPPING_STANDL_V_R_PWM_LEVEL_1 32 8 Change Angel Eye Brightness when headlamps on (Right)
FEM_BODY 3062 MAPPING_TAGFAHRL_V_L_PWM_LEVEL_1 32 64 Change Day-Run Light Brightness (Left)
FEM_BODY 3062 MAPPING_TAGFAHRL_V_R_PWM_LEVEL_1 32 64 Change Day-Run Light Brightness (Right)
FEM_BODY 3063 MAPPING_NEBELSCHW_L_PART_OF_WL Soft_On nicht_aktiv Turns on Left Fog Lamp with Welcome Lights
FEM_BODY 3063 MAPPING_NEBELSCHW_R_PART_OF_WL Soft_On nicht_aktiv Turns on Right Fog Lamp with Welcome Lights
FEM_BODY 3050 NSW_AUS_BEI_FL nicht_aktiv aktiv Allows Fog Lights to remain on when high beams are active.
FEM_BODY 3060 NSW_EIN_AUF_LDS_STL aktiv nicht_aktiv Allows Fog Lights to turn on while only parking lights are on.
KOMBI 3000 BC_V_KORREKTUR nicht_aktiv aktiv Turns off speed correction and displays actual speed.
KOMBI 3000 FDS_MENUE_TEXT_1/2/3/4 menue_3 menue_4 Enables Image of Sport + on KOMBI
KOMBI 3000 FDS_MENUE_SIGNAL_1/2/3/4 menue_3 menue_4 Enables Image of Sport + on KOMBI
KAFAS 3000 ROAD_EDGE_WARNING_ENABLED aktiv nicht_aktiv Add grass and curb detection to Lane Departure
ICM 3000 C_ZSW_Aktivierunggeschwindigkeit_Funktion_low 20_kmh 50_kmh Change Active Blind Spot Activation Speed.
ICM 3000 ICMKOD_B_SPORTLENKUNG aktiv nicht_aktiv Enables Sport+ mode (Not Necessary with Sport Auto Tranny)
FEM_BODY 3050 FH_TUERAUF_STOP_MAUT nicht_aktiv aktiv Allows the front windows to be rolled up while the door is opened.
REM 3050 FH_TUERAUF_STOP_MAUT nicht_aktiv aktiv Allows the rear windows to be rolled up while the door is opened
HU_NBT 3000 REGEN_SCHLIESSEN aktiv nicht_aktiv Sunroof Closing on Rain Detection
FEM_BODY 3020 TCM_STARTLOCK_BRAKE nicht_aktiv aktiv Start Car without holding brake pedal down.
FEM_BODY 3020 TCM_STARTLOCK_CLUTCH nicht_aktiv aktiv Start Car without holding clutch pedal down.
FEM_BODY 3020 TCM_STARTLOCK_DRIVINGREADINESS nicht_aktiv aktiv Start Car without holding brake or clutch pedal down.
      02-18-2020, 08:44 AM   #8
VTENGR
1053
Drives: 2020 X5 M50i
Hopefully the update will drop for iOS soon. Still on 3.4 here.
