02-21-2020, 02:30 PM | #1 | |
1165
Rep 1,778
Solved: Does the Key card not work with CarPlay?
So I tried the Key card today for the first time. I was very happy that it worked perfectly inside my wallet without having to take it out but there's two quirks that annoyed me, but maybe I'm doing something wrong:
1. whenever I unlocked the car, the driver's seat went back to some neutral position, and then I'd have to log into my driver profile for my settings to come back. It did that every time I locked or unlocked the car with the key card. Is there a way to assign the key card to a driver profile, or at least stop it from moving the seat constantly in between trips? 2. CarPlay doesnt work! I had my phone on me as per usual but it wouldn't pop up on the iDrive screen as it normally does. Does that mean I can only use CarPlay as long as I have the physical key fob with me? SOLVED: Quote:
02-21-2020, 03:02 PM | #2 | |
Rep 252
02-21-2020, 03:30 PM | #3 | |
Rep 73
My CarPlay works with even when I use key card. It should work. Are you saying it doesn't work at all or the screen is starting up with regular home page and not the Apple CarPlay home page? |
02-21-2020, 04:31 PM | #4 |
1165
Rep 1,778
okay well I just went out to my car and CarPlay didn't work even with my key fob, for whatever reason my phone was disconnected from the car, but after I reconnected it, it's working now.
I have an iphone, so I cant use my phone as a digital key. I tried to assign the credit card Key card that BMW gives you to my profile but couldn't find a way to do it. Can someone please teach me how to do it? |
02-21-2020, 04:57 PM | #5 | |
Rep 252
02-21-2020, 05:07 PM | #6 |
1165
Rep 1,778
02-21-2020, 05:47 PM | #7 | |
1165
Rep 1,778
right so I did what you suggested but it still says this: View post on imgur.com it still wont give me the option to tie my key card with my profile itself |
02-21-2020, 06:46 PM | #8 | |
13244
Rep 19,747
02-21-2020, 07:24 PM | #9 | |
1165
Rep 1,778
it worked!!! thank you all so so so much. this is gonna be a lifesaver for me until Apple/BMW has CarKey up and running (if ever). one last question: Can I still use my PIN to set my driver profile if I dont have the credit card key/fob with me, and someone else's driver profile was the last one used? I'm asking because I thought I saw an option in the profile that said you can either set your profile with the pin or the digital key. Last edited by thereef510; 02-21-2020 at 07:31 PM.. |
02-21-2020, 11:59 PM | #10 | ||
Rep 2,420
thereef5101165.00 |
02-22-2020, 12:42 AM | #11 |
1165
Rep 1,778
i appreciate you guys so much. I doubt i'd get all of this set up with the dealer or the BMW geniuses to the level of depth we have here, and the support we provide each other. We've had a f15 for 4 years and this has been a chief concern of mine, losing the key fob on one of my escapades. I couldnt be more pleased to have this feature and be able to use this key card as a regular key. thank you all, again for answering all of my questions and helping me set this up
02-22-2020, 01:51 AM | #12 | |
Rep 2,420
Ps last profile doesn't matter. If you don't enter with the programmed key fob or card it will start with guest anyway. If the car remembered the last profile That would have solved my display key issue. |
thereef5101165.00 |
02-22-2020, 02:06 AM | #13 | |
1165
Rep 1,778
02-22-2020, 07:31 PM | #14 |
Rep 2
The manual could certainly use improvement on the set-up and functioning of the key card. I finally got mine to work after reading this post and another.
I am able to lock and unlock my vehicle from my iPhone using the BMW Connected app, but do not see any capability to start the vehicle in the app. Larry |
02-22-2020, 07:39 PM | #15 | |
1165
Rep 1,778
there's an option right under the main Connected Drive screen for "start engine now" or 'schedule remote engine start" View post on imgur.com |
02-22-2020, 07:43 PM | #16 | |
13244
Rep 19,747
02-22-2020, 08:46 PM | #17 |
1165
Rep 1,778
Although I'm not sure, but i think on the G05 the climate control system is governed by the last state (if i turned it off, it stayed off when the next time I got in the car), unlike the F15, which always reverted back to ON, after a few minutes of maintaining the last state.
if you use the remote engine start feature, presumably to warm/cool down the car on oppresive weather days, does the climate control system always turn on? |
02-22-2020, 09:05 PM | #18 |
13244
Rep 19,747
99+% of the time I have mine set to Auto and so far the fan level was always at the lowest level the few times I did a remote start. Other than warming the engine, the remote start has been useless for me when wanting to heat the vehicle, the cooling seemed to work fine but the fan may have been higher when I turned it off. Perhaps there is a setting or something I don't have correct unless I need to set the fan to high before leaving the vehicle if I think I'm going to use remote start. Hopefully those that use it often will chime in with more info.
02-22-2020, 09:24 PM | #19 | |
1165
Rep 1,778
02-22-2020, 09:53 PM | #20 |
13244
Rep 19,747
I just talked to my brother and he got some info from the BMW Genius and evidently things are working differently than they are (or were) with mine. He didn't have time to give me all of the details but there is a temperature setting in iDrive for remote starts. He was able to enable climatization on remote starts and set a temperature for it to use. He has the remote start button on his app and when a remote start is done if the tempo is below the set value the heat comes on, above that value the AC comes on. I will have to check mine to see if maybe that was a change in the 07/2019.xx software and why my AC did work and now the heat doesn't appear to be.
thereef5101165.00 |
02-22-2020, 10:06 PM | #21 |
1165
Rep 1,778
I've only had ours for a week but I used it twice, and both times I got into the vehicle and it was noticably warm (after only 5 minutes of it running). But I cant remember if the A/C display was on or not. I'll be sure to check again this week.
I also noticed that under enabled features there is: Climatize Now, Climatize Timer, and Stop Climatization. but there's not yet a way to do any of these functions. |
02-23-2020, 12:03 AM | #22 | |
Rep 2,420
It can be turned on (cd app, display key, programmed time in the car) but you are not able to chose the temp. Unless it follows the last chosen temp on the airco as mentioned. It will chose to cool or heat the interior depending on inside and outside temperatures. Furthermore it also preconditions the high voltage battery. |
