      02-23-2020, 07:16 PM   #1
x5TXguyG05
12
Drives: 2019 BMW x5 (GO5)
Assisted Driver View
Anyone know if you can code the Assisted Driver View on G05? If so can it be done in Bimmercode app?
      02-23-2020, 07:28 PM   #2
TurtleBoy
TurtleBoy's Avatar
13236
Drives: 2019 X5 40i,2021 M340i
Yes, here is LexxM3 's post with the details.
https://g05.bimmerpost.com/forums/sh...php?p=25641809
      02-23-2020, 07:30 PM   #3
x5TXguyG05
12
Awesome, thanks. Have you tested it? And was just it the iOS app?
      02-23-2020, 08:00 PM   #4
TurtleBoy
TurtleBoy's Avatar
13236
I have not done it but quite a few on here successfully have. I think it is available in iOS and Android.
      02-23-2020, 08:02 PM   #5
eagle_bmw
Drives: 2019 BMW X5 40i
Yes it works with the BimmerCode app. If you follow the thread above you'll find that the settings are only available in expert mode.
2019 X5 40i M-Sport
07/2020.54 -> 11/2020.50 -> 03/2021.50 -> 07/2021.85 [All OTAs]
      02-23-2020, 08:02 PM   #6
x5TXguyG05
12
Thanks, hopefully someone will reply that's done it. I have the iPhone App, but not sure how to get it done
      02-24-2020, 12:30 AM   #7
coco135
Drives: 2009 7
Did it today...
You need the adapter and the app.
From the app go to bdc control and then expert mode.
After that just follow the above thread
      02-24-2020, 05:13 PM   #8
vicfalc09
vicfalc09's Avatar
211
Drives: M340i xDrive
What options does your X5 need to have installed from factory for this to work correctly?
      02-24-2020, 05:25 PM   #9
x5TXguyG05
12
Originally Posted by coco135 View Post
Did it today...
Did it today...
Thanks so much
      02-24-2020, 05:41 PM   #10
ifr
ifr's Avatar
United Kingdom
1197
Drives: Tesla MY LR AWD
Just Driving Assistant Professional and an i-step >= 1907
      02-24-2020, 08:16 PM   #11
eagle_bmw
OP, if you haven't even tried anything yet you can start by reading on the app's quick start guide.
https://www.bimmercode.app/quick-start-guide/
I'd start by coding ASS (Auto Start/Stop) which doesn't require coding in expert mode. If you get to that point you should be at least 90% ready to coding ADV.
I'm pretty new to coding myself and with this app I found the process to be simple enough to follow.
2019 X5 40i M-Sport
      02-24-2020, 08:18 PM   #12
x5TXguyG05
12
Did it today...
Thanks eagle, I coded ASS yesterday successfully so your feedback is perfect and very appreciated!
      02-29-2020, 03:10 PM   #13
x5TXguyG05
12
Coded ADV yesterday and it worked great. The PIA was missing and still worked. Not sure what the PIA is, but happy it worked. Thanks TurtleBoy and LexxM3 for the help
eagle_bmw182.50
      02-29-2020, 03:21 PM   #14
eagle_bmw
Great! My car has the July 2019 software update and didn't have the PIA setting as well.
2019 X5 40i M-Sport
      02-29-2020, 04:24 PM   #15
ifr
ifr's Avatar
United Kingdom
1197
I'm not 100% but think the PIA coding option is profile related, so it shouldn't be an issue not having it. Maybe some different behaviour if you have more than 1 profile on the car, but I'm speculating.
BMW included the 4 options as a bundle when retrofitting ADV in the Japanese market, so I included all 4 in the published ADV coding.
      02-29-2020, 04:35 PM   #16
eagle_bmw
I do have 1 profile only so you may be right. I'll keep this in mind when I add my wife's back.
2019 X5 40i M-Sport
      03-01-2020, 10:47 AM   #17
x5TXguyG05
12
ADV after coding
So far the ADV works great and I only have one profile so haven't noticed anything off. While in ADV, I have noticed that the blind spot indicator lights on the side mirrors act a little funny. They work, but when I am passing someone in ADV, they don't turn on most of the time. However, when a car is passing me, they will come in while in ADV. Not sure if this was the same before coding, but don't think so.
      03-01-2020, 11:42 AM   #18
LexxM3
LexxM3's Avatar
1699
Drives: E46M3, G05X5
2019 X5  [0.00]
It was the same before coding (but obviously easy to verify by turning off ADV or coding back to stock values) and is intentional. The theory is that when you're passing someone, you know they are there (ie they are not in your blind spot).
      03-01-2020, 07:46 PM   #19
x5TXguyG05
12
Thanks. Did you experience changes with the comfort access too? After coding, it seems to miss auto locking or unlocking from time to time? Not sure how that could be affected, but has happened a few times some coding.
      03-01-2020, 08:50 PM   #20
FreddyBMW
FreddyBMW's Avatar
95
Drives: 2019 X7 40i iSTEP 07/2020.54
ADV is not bad and I definitely like it (except that it needs my attention diverted to the cockpit to notice who is/what is around me (and praise tech!) and keep looking to it and paying attention to it).
I am a fan of HUD (don't know why TESLAS don't have it?1). It is definitely recommended not only a driver to have it in front of his windshield with the info specific to the driver but also for the passenger seat to have different info displayed there (probably a good idea for BMW?)). I wish if my whole cars's windows had a some kind of HUDs respectively.
Back to the point, ADV is great and it should be in a visible area to the whole car to extend this safety concept.
      03-01-2020, 09:56 PM   #21
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
Completely agree. Naturally-delivered 360 degree situational awareness at all times should be the goal. I've wanted this my entire driving life, this is 50% of the way there.
      06-22-2020, 12:45 AM   #22
ifr
ifr's Avatar
United Kingdom
1197
I think PIA relates to profile settings, so sets the configuration of a parameter to a specific setting. It can be overriden in idrive manually.
There are default PIA masks in HU_MGU and SAS that configure what the default driver assistance settings look like. Modify these and each new profile starts with a different set of settings.
So not really needed, and I only included them in the original ADV coding for completeness.
