12-16-2020, 10:28 AM | #67 |
Rep 1
2021 BMW X5 40i CTEK Tender
thanks for your posting regarding the CTEK charger- current my X5 has been sitting for about week and half - I put my CTEK MUS 4.3 on it which I had used on my 2016 BMW 435ix - the charger went to status 3 and didn't move for 10 hrs - I've disconnected for now - I place a call to CTEK tech support for their advise [let see if the call back] I find it both interesting and strange that you would need to get the CTEK to work only after the battery has first been fully charged - basically hooking up the CTEK after driving and parking it - if what you stated is accurate - I never had to do this for either my 2016 435 or my 2017 X5 - but thanks for the heads up
12-16-2020, 02:18 PM | #68 |
Rep 6,888
This may be more than you need, but I have had one for quite a while now. https://www.boschautoparts.com/en/au...martcharge-pro They have other models that are less capable. It also has a function where if you needed to remove the battery, it would keep clean power applied so all of the memory functions don't get lost. It kept a battery in my GT going for about 7-years without issues.
12-16-2020, 06:42 PM | #69 | |
Rep 84
12-28-2020, 09:45 AM | #71 |
Rep 177
Hello, folks! I have an MY2021 X5 XDrive 40i, took delivery about two and a half weeks back with just four miles on it. Have about 600 miles on it now.
Reading through the forums I figured I need to top off the battery once in a while, and I bought a BMW charger, which I think is a rebranded CTEK charger. I plugged in the charger, connected the terminals under the hood. It switched from stage 1 to stage 3 in about 30 minutes, but it has been sitting on stage three for roughly 16 hours now. Should it take this long? Hope I did not do anything wrong. The car is in the garage, and the temperature is in 60s. After connecting the terminals, I gently closed the hood (not all the way), and locked the car using key fob. Hope the locking is not disrupting anything.
2021 BMW G05 X5 xDrive40i - Phytonic Blue/Coffee Vernasca, "an adorable beast" :: 11/2020.33 (Delivered) -- 11/2020.45 (Updated at dealer)
09-11-2023, 04:23 AM | #72 |
110
Rep 319
Reviving this old thread rather then start a new, especially considering all the useful information in it!
How are you guys running the charge lead out from the car? Do you lock the car but leave the hood slightly open so as to not damage the cables etc? Or do you close the hood completely? |
09-11-2023, 05:42 AM | #73 | |
13594
Rep 20,230
09-11-2023, 05:50 AM | #74 |
110
Rep 319
09-11-2023, 07:58 AM | #75 |
13594
Rep 20,230
Yes, that should work.
IftiBashir110.00 |
09-11-2023, 08:33 AM | #76 | |
Rep 4,421
IftiBashir110.00 |
09-11-2023, 09:26 AM | #77 | |
110
Rep 319
09-14-2023, 07:10 PM | #78 | |
Rep 55
My G05 is a 2021 xDrive30d with 8500+ kms. I have the CTEK MXS 5.0 and connected the alligator clips on the terminals under hood then plugged into the garage outlet. I placed towels to cover each latch slots then lowered the hood with the hood latches just touching the towels. Left the doors closed but unlocked. In 15 minutes, CTEK reach Stage 3 and after 2hrs it shows Stage 7. Overnight, light still showing Stage 7 on battery tender. It appears the hood should not be closed shut (lowered but latches off) in order for battery tender to work. |
09-15-2023, 12:00 PM | #79 |
Rep 119
I was one of those folks whose CTEK MXS 5.0 would get stuck at stage 3 on my 2022 40i so I bought a NOCO Genius 10 and it charged the battery without a problem. I don't know if it was the state of the battery that was the issue or something else. The CTEK worked fine on my 2018 M240i.
09-15-2023, 12:11 PM | #80 | |
822
Rep 1,797
COL(Ret), US Army Hagerstown MD 2019 X5 40i MSport Alpine White/Coffee (my 13th BMW) 2015 Mercedes SL400; 2009 Lexus RX350 |
09-15-2023, 07:04 PM | #81 |
Rep 6,888
The mild hybrids may be part of the difference in performance. Note, if you want to actually top off the 48vdc battery, you need two things:
- the hood open - a charger that can supply >20A..i.e., not a battery tender/maintainer |
09-16-2023, 05:38 AM | #83 |
13594
Rep 20,230
You got them.
IftiBashir110.00 |
09-16-2023, 07:49 AM | #84 |
110
Rep 319
Guess my battery wasn’t as bad as I thought.
Took my car for a service 2 weeks ago. Asked them to look at why my iDrive update had copied across but just hadn’t started installing in the car for the past few months! Was told as my car isn’t used much (weekend car mainly) that it was most likely because the battery was sitting in a low state. Hence purchased the charger. Put it on charge at 11:15am today. Within 10 mins or so, it was on Stage 3 (charge to 80%). Around 1:30pm (so 2 hours or so later) it’s already on Stage 4 (slower charge to 100%). At this rate it should be done and trickle charging in another few hours, and leaves me ready for the winter months. Plan to do this every quarter. |
09-16-2023, 12:30 PM | #85 | |
242
Rep 374
09-16-2023, 01:33 PM | #86 |
110
Rep 319
09-16-2023, 05:33 PM | #87 |
Rep 6,888
The battery situation gets a bit messier with the mild hybrids...all of the batteries need to be above a certain level. Neither my phone or watch will update unless their batteries are charged above a certain level, and that's true with your BMW as well. A battery maintainer will NOT recharge the 48vdc battery...it takes one capable of at least 20A before that charging will kick in, and the logic requires the hood to be open to happen for the 48vdc battery to charge.
