06-03-2022, 11:44 AM | #1 |
Rep 114
What is the best (music quality) streaming source?
What is the best possible streaming source for B&W sound system or any other BMW sound system?
- build-in Spotify (still not Hifi) - Tidal (Hifi) over wireless Apple Carplay or AA - Deezer (Hifi) over wireless Carplay or AA - what else? Last edited by torso; 06-04-2022 at 05:09 AM.. |
06-05-2022, 07:43 AM | #2 |
14
Rep 32
Some quick comparisons to specs here:
https://freeyourmusic.com/blog/best-...aming-services |
Boardmember136.00 |
06-07-2022, 04:05 AM | #3 | |
Rep 114
06-07-2022, 12:53 PM | #4 |
Rep 8,803
Drives: eVeRyOnE mAD!
if you play hi-res from a device connected via USB and external DAC, you'll get the full bitrate. search the forum for additional threads on the subject
06-11-2022, 01:01 PM | #5 |
Rep 114
06-11-2022, 07:05 PM | #6 | |
Rep 8,803
06-12-2022, 01:11 AM | #7 |
Rep 114
06-13-2022, 07:08 PM | #8 | |
KB-1stM
Rep 6
06-14-2022, 09:50 PM | #9 | |
257
Rep 332
This post from Auricom may help; https://g05.bimmerpost.com/forums/sh...36&postcount=2
2020 BMW X5 M50i . Tanzanite Blue II . Black Merino . Extended Shadowline . 742M Black / ART Replica 181
07/2019.55 (since birth Oct.1,2019)-> 11/2019.70 (OTA Aug.11,2020)-> 11/2020.36 (Dealer Nov.25,2020)-> 03/2021.50 (OTA Jun.15,2021)-> 07/2021.85 (OTA Mar.1,2022)-> 07/2022.58 (OTA Dec.9,2022)-> 11/2022.60 (OTA Mar.2,2023)-> 03/2023.50 (OTA May.31,2023)-> 07/2023.35 (Dealer Aug.21,2023)-> 11/2023.50 (OTA Feb.9,2024) |
06-15-2022, 12:01 AM | #10 | |
Rep 114
06-15-2022, 03:47 PM | #11 | |
257
Rep 332
For more detail, or other info, perhaps you should contact Auricom directly via DM. I'm sure he would be happy to help.
06-16-2022, 09:55 AM | #12 | |
Rep 96
Had Tidal Masters, but MQA files Qobuz is very good, but not the most content Apple Music is best go to with lossless and best content and convenience! If you want best EQ setting for B&W, watch here: (now this is a M5 and not a X5, so setting might need to be slightly different, but B&W system is the same.) |
06-17-2022, 07:07 AM | #13 |
Rep 114
Thanks for linking this video.
I found that Apple Music works also best for me. Best quality for money, best music library and convenience. Now i have the following EQ settings on B&W and i am quite very happy with that. Sound mode: Studio - 100hz +4 - 200hz +2 - 500hz +2 - 1khz (flat) - 2khz (flat) - 5khz (flat) - 10khz +2 - Treble +2 - Bass +4 |
06-17-2022, 09:14 AM | #14 |
Rep 223
Drives: X5 45e
I need to clarify here. Unless it was a feature that got removed for MY22 (and that's why I'm not finding one), the G05 doesn't have an analog input. Therefore you can't use an external DAC. You can use a digital audio player connected via USB, but you're still relying on the head unit's DAC for that.
06-17-2022, 10:16 AM | #15 | |
Rep 8,803
https://a.co/d/27V9rWA |
06-17-2022, 02:19 PM | #16 | ||
Rep 223
Drives: X5 45e
07-09-2022, 07:32 PM | #17 |
805
Rep 1,790
I have a question. How much better is the sound coming out of a DAC into the USB port on the BMW with a USB C to 3.5mm Audio Aux Cable coming from the DAC versus playing the same HI RES files on a USB Thumb Drive/Hard Drive plugged directly into the BMW's USB port?
I'm not seeing anything in the BMW owner's manual that talks about the specifications of the DAC in the HK head unit. |
07-14-2022, 02:40 AM | #19 |
Rep 3,479
I stream lossless audio files directly from USB hard drives. The resulting quality is far greater than any other audio source I've tried. Nothing comes remotely close. Lossless audio makes the B&W audio come alive.
I have not tried messing with additional DACs.
Cross-continent road trip journal from BMW PCD to Alaska in new X7 M50i in this thread HERE!
New EVEN BIGGER road trip in X5 from BMW PCD to Alaska NOW ONGOING LIVE IN THIS THREAD! Wilderness road trip journal to Eastern Alaska in this thread And road trip journal to Denali and the Arctic Circle here in this thread! |
07-14-2022, 03:10 AM | #20 | |
805
Rep 1,790
I'm curious how much better sounding, if any, these files would sound going through a DAC. |
07-14-2022, 09:47 PM | #21 | ||
Rep 3,479
If there was an analog audio input that went straight to the amp, an external DAC would bypass the one onboard, and you could ostensibly achieve higher quality with a better DAC, while minimizing circuitry routing from source to amp. Using an external DAC, wouldn't we be just adding more gunk to the existing routing?
07-15-2022, 08:14 AM | #22 |
Rep 8,803
someone said they play lossless through USB drive. that's it. no external DAC. let the vehicle DAC do its thing. "sounds phenomenal" but he has B&W system
