BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > Is it worth updating all the car modules?
      11-26-2020, 08:41 AM   #1
tehnooks
Drives: F20 120dX M Sport
Hi guys thanks for reading,
I have recently replaced an amp and flashed it successfully in my f20120dX and I'm comfortable with doing so, I also have a suitable power supply that can manage 50+ amps for prolonged flashes. While flashing the amp I can see all the modules are out of date with an original 2014 istep shipment version
So my question is - is it worth updating all of these modules? Will the car have anything new or noticeable about it and/or where can you find out the information of what's new in the update, a changelog of sorts if it exists?
Thanks in advance for your time and suggestions
      11-26-2020, 01:44 PM   #2
bvrider1
Drives: e90 m3 + f80 zcp
I see no reason to do so. If it makes you feel better then just do it.
      11-27-2020, 02:56 PM   #3
F20_M135i
France
101
Drives: BMW F20 M140i Xdrive
on the contrary, some updates prevent access to coding so I would say, since it works well: we don't touch anything and we take advantage of it!
      11-28-2020, 11:41 AM   #4
DomMuc
DomMuc's Avatar
501
Drives: G87 M2
BMW says all ECU needs to be on same Level, so when one Ecu is replaced and needs a flash.. all ECU were flashed to the newest Software
1addicts
