05-20-2024, 03:48 PM | #1 |
Rep 27
Display questions
Still getting used to my new 2024 X5 and am curious about the display settings. Specifically:
AR in the gauge cluster Is the purpose of this view for direction overlays on the camera view and if so, does it only work with the BMW nav vs Apple Maps? HUD I don’t really understand the various views if this one as they don’t seem to provide much info. Sport mode view are just lines… and the others don’t seem to offer much either. How do you use the HUD? |
05-20-2024, 10:27 PM | #2 | |
Rep 130
05-21-2024, 08:16 AM | #3 |
15850
Rep 22,708
That means it is charging the battery. The vehicle uses brake energy regeneration and the alternator is on a clutch that is only engaged when coasting or braking. The exception to that is when the battery is low, around 60% then ot will stay engaged until 80% or so.
05-21-2024, 10:30 AM | #4 | |
Rep 130
Do you know of a good YouTube video that has an explanation of all the modes? I have searched and cannot find one. I checked beamerviews and he does not have a video on it. |
05-21-2024, 11:05 AM | #5 | |
15850
Rep 22,708
Damping; The EDC Sport program will be activated and it will become a stiffer/more sportier ride. If you has air suspension the vehicle will also be lowered. Steering: it will be a heavier feeling. Engine/Throttle: response will be quicker, ie. sport throttle Transmission: Gears will be held longer
Javiggan80.00 |
05-23-2024, 06:51 PM | #7 |
Rep 130
Yeah! I am still searching for a good video explaining the lines and power gauge. I even read the manual guide and it says it has a power gauge but does not explain how to use it. I downloaded the Driver Guide, no information about it.
05-25-2024, 01:35 AM | #8 |
Rep 420
Drives: 2025 BMW X5 Xdrive40i
HUD should show directions, MPH, speed limit, stop lights or stop signs and some other info. Have you tried the on steering wheel menu to change the HUD visual?
Maybe this will help? Head Up Display Tutorial |
Javiggan80.00 |
05-27-2024, 08:08 AM | #12 |
15850
Rep 22,708
Think of it as your Tach but showing percent of power rather than RPM's.
05-27-2024, 08:36 AM | #13 | |
Rep 9,521
Drives: eVeRyOnE mAD!
well, I guess one way to use the power gauge is as a guide for “hypermiling” |
05-27-2024, 08:51 AM | #14 | |
15850
Rep 22,708
05-27-2024, 09:46 AM | #15 |
Rep 130
05-27-2024, 10:09 AM | #16 |
Rep 91
The power gauge is how much power you use to accelerate. Arrow 1 is the regen area when you lift off the gas pedal (there is a car in front) or braking, it will show how much regenerative power you can get.
Btw you can always change the gauge mode in any driving modes with 3 lines button on the steering wheel. |
05-27-2024, 11:07 AM | #17 |
15850
Rep 22,708
No, not at all. It is exactly as I and the manual described. Haven't you noticed the percentage increase as you step on the throttle and then have it go down when the gear changes?
05-27-2024, 11:14 AM | #18 |
Rep 130
I'll send a video, the blue line goes up when I brake, and it starts depleting when you start driving, not always but sometimes.
05-27-2024, 11:20 AM | #19 |
15850
Rep 22,708
Sounds like you are looking at the regen. That is showing when the battery is being charged.
05-27-2024, 11:22 AM | #20 |
Rep 130
05-27-2024, 11:37 AM | #21 | |
15850
Rep 22,708
Just like in the screenshot you posted, it is showing the RPM in percentage.
05-27-2024, 08:29 PM | #22 | |
Rep 91
And the difference is where the power curve is no longer linear above 5200 rpm; the power stays the same at 525 hp up to 6200 rpm. So at the range 5200-6200 rpm, the power percentage will stay the same at roughly 100% even though the rpm is changing. The power percentage will drop off if you go above 6200 rpm with manual mode even though the rpm is increasing. That's why I prefer to use rpm instead for better reading. Last edited by driftkido; 05-27-2024 at 08:46 PM.. |
