10-25-2015, 02:06 PM | #1 |
31
Rep 41
Common adaptive headlight error + headlight out + housing moisture. Cause? Fix?
I just picked up a 2011 135i m-sport (Prod. Date: 2011-01-06) knowing that there was an issue with the adaptive headlights (cost to fix was negotiated in).
I'm been reading a ton of threads here but they seem to deal mostly with aftermarket lights and bad seals. I believe I have stock lights (see below), but I'm getting the dreaded Adaptive Headlight warning and the actual headlight is out: Here's the classic moisture in headlight shot: What I can't tell is if they are aftermarket units? I didn't think they would be since my VIN Decodes with: 522-Xenon-Light / Xenon-licht. I don't know if you guys are familiar enough just to tell by the harness. These two pieces were just laying loose in the cover, which seemed sloppy for OEM (and the pink hues are odd)? [EDIT: Definitely aftermarket] There's no cracks or splits in the housing, the back cover was firmly in place. It would be nice to try to figure out how the moisture got in there before I start swapping in new parts — would hate to fix it and just have it happen all over again. Where should I start? --------------------------------------------------------------------------------------- EDIT: Summary of Solution from later in the thread (for future searches) --------------------------------------------------------------------------------------- I dried out the headlight by removing the rear cover of the headlight and placing a box fan on the engine, pointed at the headlight to move air into the housing. From the front, I positioned a shop light about 18" away to cast some heat into the housing. I left this setup for a few hours and it eventually dried up all the moisture inside the headlight. I removed the headlight from the car and discovered that the Control Module (that controls the Adaptive Headlights) and the Ballast (that powers the Xenon Headlight light), both located on the bottom of the headlight, were full of water and corroded. I replaced the Control Module (part# 63117180829) and the Ballast (part# 63117180050) and both the errors are now gone, the Adaptive Headlight and the Headlight light now work properly. --------------------------------------------------------------------------------------- Last edited by hungrybreadbutterhustle; 10-30-2015 at 05:14 PM.. |
10-25-2015, 02:21 PM | #2 |
390
Rep 859
Drives: 2017 Alfa Giulia Quadrifoglio
Obviously not OEM.
10-25-2015, 02:39 PM | #3 |
31
Rep 41
10-25-2015, 03:16 PM | #4 |
31
Rep 41
Update:
The plot thickens (get's worse): 1. I just had the lady friend turn the wheel while the car was running and absolute zilch movement from BOTH driver and passenger. 2. I dried out the moisture from the passenger side (low-heat lamp/fan) and then swapped the working bulb from the driver's side over to passenger — still didn't light up. If the control unit was fried, would it still at least light the bulb or does that also effect power to the bulb? |
10-25-2015, 05:21 PM | #5 | |
Rep 131
I had the same problem, most likely your ballast(control unit) is dead. I would remove the passenger light assembly to make sure it's completely dry. Then remove the ballast from the bottom and check for moisture and corrosion. Good luck
BMS DCI // Catless DPs // BMS OCC // BMW PE // ER CP/TiAL BOV // VRSF 7" FMIC // JB4 + MHD // SSR GT1 // Alpina TCU flash
10-25-2015, 05:56 PM | #6 | |
31
Rep 41
This is the control unit, yes? 14 CONTROL UNIT XENON LIGHT 2 63117180050 $449.90 |
10-25-2015, 06:11 PM | #7 | |
Rep 131
And yes, that is the part I am talking about. |
10-25-2015, 06:13 PM | #8 |
109
Rep 377
Hope you get this sorted out.
Cover probably not installed correctly. I replaced my covers this year , should be done every 6 years or so since the gasket loses elasticity and can leak. Don't know why so many have difficutly getting them back on correclty, really not that hard. Good luck getting this sorted out.
ER CP, Forge DV, Wagner FMIC, PE, Maddad Mid, ER Sports OC, BMS OCC, RB Check Valve, AFE intake, Cobb AP3- Stage 1+ drive, BMW SS, PS Springs, Yellow Koni external, M3 Control Arms F & R, M3 Strut Brace, M3 Sub Bushing, Rouge Toe, Dinan Camber Plate and Rear Shock Mts., E93 M3 front sway bar, Mfactory Diff, Arc 8 PSS 235/40/18-265/35/18
10-25-2015, 06:29 PM | #9 | |
31
Rep 41
- Last edited by hungrybreadbutterhustle; 10-25-2015 at 06:52 PM.. |
10-25-2015, 06:35 PM | #10 |
31
Rep 41
One part of the question still remains.... AHL aside, why is the
View post on imgur.com ? Even when I swapped the bulb from the drivers side (where it lights up fine), it didn't light up on the passenger side.Maybe it's not AHL aside? Can the issue with the View post on imgur.com and AHL make the bulb not light up properly? i.e. everything is related and you can't have a dead AHL control until and the headlight still work? |
10-25-2015, 07:10 PM | #11 |
European Editor
10624
Rep 22,992
ALL us-spec 135i's have AHL xenons as standard equipment.
On US spec 128i's xenons were optional. In the rest of the world... they had three headlight options for all 1er's... Halogens, Xenons(inner lens are clear) and AHL Xenons(inner lens is opaque). What's not OE are those purple(?) finned alu ballasts wired into the back of your headlights. Looks like whoever did the wiring job, never bothered to put back the headlight covers(behind the headlights) and that allowed moister into the headlights. When that happens it can blow out(up) the footwell module AND/or the internal wiring inside the headlight. New headlights are about $700 per side. A footwell module is a few hundred - plus it will need to be coded to your car. Some people have success in removing the headlight and using a hairdryer to blow out the water. Or leave them sitting in the sun. The damage is probably done already - you will probably need a new headlight and/or footwell module/bulb. The AHL function will ONLY WORK when the headlight switch is in the AUTO position! (turned to the full LEFT counter clockwise). IF you turn the headlights manually on... the heads stay locked in the straight ahead position. They will not turn when you turn the steering wheel. Dackel headlight switch in the OFF position. Auto is to the LEFT counter clockwise. Note: this is also the euro switch with rear brake fog light switch on the lower righthand side. non-AHL xenons AHL xenons (these are also LCI lights, ie: the brows)
10-25-2015, 07:17 PM | #12 | |
European Editor
10624
Rep 22,992
10-25-2015, 07:36 PM | #13 | |
31
Rep 41
The covers were on and on tight but who knows if that's always been the case. |
10-25-2015, 07:42 PM | #14 |
31
Rep 41
Regarding the footwell module. From what I've been reading here on the forum... wouldn't there be a high chance that other things would be acting screwy — like the other headlight, windows, light package stuff?
10-25-2015, 07:56 PM | #15 | ||
European Editor
10624
Rep 22,992
He then pulled his bumper off and pulled out the headlights... he thought it must have been the control unit under the headlight that was bad. In doing so he burnt up the "good" ecu from the driver's headlamp. It was his footwell module that was bad. In the end he needed one passenger headlight, two headlight ecu's and one footwell module and one headlight light bulb for the passenger headlight(bc he also broke that). It was a mess. I only remember the guy was in the military stationed near K-town and was driving around for weeks with only one headlight and then no headlights... bc he never had time to fix them. update: Here is that thread I remembered... e46m3to335i http://www.1addicts.com/forums/showthread.php?t=494279 I remember talking to the OP of this above thread in PM's... I think there was more to the "fix" than he posted. I don't remember all the details though. and... http://www.1addicts.com/forums/showthread.php?t=494279
10-25-2015, 08:52 PM | #16 | ||
31
Rep 41
10-26-2015, 05:54 AM | #17 | |
European Editor
10624
Rep 22,992
10-26-2015, 06:50 AM | #18 |
708
Rep 3,268
Drives: 2010 128i
I bet it's a bad ballast, but you need to pull the light completely out of the car to replace that. Or maybe the original ballast is missing or just disconnected? Like Dackelone saide, the PO likely swapped to an LED AE set up, which has it's own ballasts installed inside the headlamp housing (rather than underneath the headlamp like the much larger OEM ballast). I think that's what that pink/purple thing is - wonder where the PO got that from? I'm not super-familiar with the aftermarket headlamp "upgrades," but I've never seen any that looked like that.
Anyway, another issue I've seen on the boards is that sometimes the LED ballasts interfere with the AHL motor operation, since there's not really enough room for them in the headlamp to begin with, and the break things that way. I hope you got a good discount from the PO for all this mess! And, now for a shameless plug: if you do end up needing new headlamps, I've got a (pre-LCI) set for sale cheap in the classifieds section. Good luck! |
10-26-2015, 09:09 AM | #19 | |
Rep 1,181
hungrybreadbutterhustle >
If the adaptive function fails, but the lights in the unit are working (HID, angles, high-beam, etc.), and you get an in-dash error -- its the control unit: https://www.ecstuning.com/ES172035/ 63117180829 ------ If the main HID light is out (based on your picture...it is), then its the ballast. You can swap out the bulbs, ballast, and adaptive module from the working light to test -- won't cost you a dime. Just make sure the light is dry before testing: https://www.ecstuning.com/ES172034/ 63117180050 If both the light and adaptive are not working, then you'll need both. Again, you can swap it all out from the working headlamp to test without spending any money. ------ Note: From your pictures, the angles seem to be working correctly -- that's not your problem. Those loose resistors are from an aftermarket LED angel eye kit/HID angel eye kit. If its an LED angel eye kit, then you'll see those resistors inside the lamp. Unfortunately, although sloppy, that's how it is (http://www.jekusa.com/ebay/P/HLB-H8-20W-W.jpg). If you have an HID angel kit, you'll have an additional ballast outside the lamp...along with a hole/grommet on the light cap. If you DON'T have an external ballast or those holes in the light caps, then you DO NOT have an HID angel kit. ------ In any case, you're fine on that front man -- the angels are ok. Your main HID on the right is out -- it has nothing to do with those resistors/angel eyes. As far as the condensation, the previous owner probably didn't close the cap properly. Its not uncommon as there is very limited space to maneuver behind the right lamp. Even when you think you got it closed properly, sometimes it isn't. DO THIS: 1) Swap out the HID bulb from the good light... Note: If it works, then you know its just a bulb. If it doesn't...its the ballast. 2) If after the bulb swap, it doesn't come on, then swap the ballast from the good light. The light should come on even if the adaptive is not working. 3) Test the adaptive function -- I sent you a PM about it. Just like Dak said, make sure the headlight switch is in the AUTO position...then turn the car on or cycle to the first position. If the adaptive is not working properly, then swap out the control unit and retest. These simple swaps will help you identify the issue without spending any unnecessary money -- then simply buy what you need. FINALLY, on the right lamp -- once you fix it...make sure you put the cap back on properly before reinstalling the light assembly. You'll thank me later. --------- CLARIFICATION: Quote:
Adaptive motor failure codes: 9CC0 - SMC Right defective 9CBF - SMC Left defective ------- You can also diagnose using the in-dash error icon CC-ID codes: Footwell Module FRM 87 Right Rear Light Failure FRM 88 Dipped Beam Left Failure FRM 89 Dipped Beam Right Failure FRM 111 Number Plate Light Left Failure FRM 113 Sidelights Switched On FRM 114 Rear Fog Light Failure FRM 115 Reverse Light Right Failure FRM 116 Indicator Rear Left Failure FRM 117 Reverse Light Left Failure FRM 118 Rear Light Right Failure FRM 119 Indicator Front Right Failure FRM 120 Dipped Beam Left Failure FRM 121 Dipped Beam Right Failure FRM 122 Indicator Front Right Failure FRM 123 Rear Light Right Failure FRM 124 Indicator Right Failure FRM 125 Indicator Rear Right Failure FRM 126 Fog Light Right Failure FRM 127 Side Indicator Left Failure FRM 128 Left High Beam Failure FRM 129 Rear Fog Light Failure FRM 130 Right High Beam Failure FRM 131 Parking Light Left Front Failure FRM 132 Front Right Side Light Failure FRM 133 Right Rear Light Failure FRM 134 Right Brake Light Failure FRM 135 Centre Brake Light Failure FRM 136 Left Brake Light Failure FRM 137 Number Plate Light Right Failure FRM 138 Fog Light Left Failure FRM 196 Indicator Front Right Failure FRM 197 Indicator Front Left Failure FRM 231 Light System Failure FRM 256 Headlight Leveling System Failure FRM 259 Window Anti-Trap Deactivated FRM 261 Window Anti-Trap Failure FRM 345 Brake/Tail Light Failure Right FRM 346 Brake/Tail Light Failure Left FRM 371 Number Plate Light Failure FRM 372 Brake Force Display Light Failure Left FRM 373 Brake Force Display Light Failure Right FRM 378 Sidelight/Daytime Lights Defective- Left FRM 379 Sidelight/Daytime Lights Defective- Right FRM 380 Turn Signal Lights Defective- Left FRM 381 Turn Signal Lights Defective- Right FRM/ALC 295 Adaptive Cornering Lights Failure FRM 437 Parking Lights On FRM 490 Parking Assist Failure, Parking Assist Aborted Complete list of CC-ID codes: http://www.endtuning.com/ccidcodes/ MONEY $AVER: Buy the ballast and module from eBay (used OEM not aftermarket). Not worth buying new. You can get a ballast for $50, and control unit will cost you approximately the same: http://www.ebay.com/itm/OEM-2008-201...xT7EgL&vxp=mtr http://www.ebay.com/itm/Bmw-1-series...FWJSj3&vxp=mtr Last edited by TUN3D; 11-03-2015 at 12:18 PM.. |
KRAMCLASSIC45.50 kustom19513.00 |
10-26-2015, 11:16 AM | #20 | |
Rep 894
kustom19513.00 |
10-26-2015, 06:24 PM | #21 |
31
Rep 41
Ok. I'm admittedly a dumbass — when I originally checked the Adaptive Headlights (by standing in front and having somebody start up the car), I didn't have the headlight switch on A. I just re-checked it with the switch in the proper position and the working, driver's side does its centering, self-check process.
I just ordered a new ballast and module so I'm hoping that will fix it. I'll update here with any changes. |
kustom19513.00 |
10-26-2015, 06:47 PM | #22 |
31
Rep 41
For future searches:
These are the two errors I see in the nav when I first start the car: △ Right low beam malfunction! △ Adaptive headlights! Adaptive Headlight Icon: CC-ID 295 = FRM/ALC 295 Adaptive Cornering Lights Failure Headlight Beam Icon: CC-ID 121 = FRM 121 Dipped Beam Right Failure Last edited by hungrybreadbutterhustle; 10-26-2015 at 07:17 PM.. |
kustom19513.00 |
