10-12-2007, 03:01 PM | #25 |
Moderator
567
Rep 4,240
You are godsent 1ster!! I have a some question Are you positive the weight is 3384?
- 04 Honda S2000(gone)
10-12-2007, 03:04 PM | #26 |
Rep 908
I AM disappointed that there's (apparently) no cloth seating option :iono:
Other than that... Dude!! :headbang:
Vorsprung durch Gas Geben!! 172 of 740 |
10-12-2007, 03:05 PM | #27 |
A swell fellow
Rep 146
I wonder why the 128i weighs 143lbs more than the 135i.
Also, I hope there is a headlamp washer delete. I assume its with the cold weather package only? No problems there considering it doesnt get cold here. |
10-12-2007, 03:09 PM | #28 |
Large Member
164
Rep 937
I made an error there. The brochure contains a typo, which shows just how preliminary it is. Here are the correct weights.
Unladen weights for manual and (automatic) 128i: 3252 (3329) 135i: 3332 (3384) The 335i Coupe is listed on BMW's website as 3571, a 239 lb difference! Sorry for the earlier error. |
10-12-2007, 03:14 PM | #29 | |
Moderator
567
Rep 4,240
10-12-2007, 03:20 PM | #33 |
Large Member
164
Rep 937
Because I did a bad job of forging the brochure. Sorry.
No fuel economy figures yet. I bet it hasn't been certified. |
10-12-2007, 03:23 PM | #34 |
Rep 908
I've seen this often. They use the same basic press photos and simply print a disclaimer at the bottom saying "European Model Shown" :iono: I'd imagine it helps reduce the cost of the brochure
I've even seen versions where they photoshopped the NA reflectors onto an EU model (I think that was either a Z4 brochure or an Audi model... I forget)
10-12-2007, 03:23 PM | #35 |
Rep 502
10-12-2007, 03:23 PM | #36 |
Moderator
567
Rep 4,240
You gotta scan the weight numbers on the brochure if it ever lets you man. The weight difference between the two is SUPER SHOCKING. I already made to phone calls. Awesome post.
10-12-2007, 03:25 PM | #37 | |
Rep 472
1ster, just us a website like this to upload them. Higher resolution too please http://www.tinypic.com/ |
10-12-2007, 03:31 PM | #38 | |
Large Member
164
Rep 937
When you see them, note that it lists the 135i manual's weight as 3732. That's the typo I was referring to. The correct weight has got to be 3332 to keep it in line with the other weights listed for the 128i and the 135i automatic. No way the manual trans weighs 400 lbs! |
10-12-2007, 03:32 PM | #39 |
Rep 7,594
Drives: '19 M2C
1ster I envy the fact that you can go to the LA auto show next month!
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange) |
10-12-2007, 03:55 PM | #40 |
Rep 502
10-12-2007, 04:01 PM | #41 |
Rep 291
is the weight of the 335i on the website also unladen? I want a direct comparison on the weight. If it really is ~200lb's less with both unladen then that gives the 1 alot of brownie points in my decesion.
10-12-2007, 04:03 PM | #42 | |
Large Member
164
Rep 937
10-12-2007, 04:05 PM | #43 | |
Moderator
567
Rep 4,240
Thanks to Harold for editing. Hey 1ster, where did you get the 3332lb from??
10-12-2007, 04:07 PM | #44 |
Large Member
164
Rep 937
I'm guessing that 3732 is a typo for the manual car, and 3332 is my best guess. I'm assuming they mis-typed the "7" in that number.
Otherwise the weights are: manual and (automatic) 128i: 3252 (3329) 135i: 3732 (3384) That just doesn't make sense. The manual 128i weighs 77 lbs less than the automatic. Hell, if the manual 135i is similarly svelt, then it only weighs 3307! 3332 is a conservative estimate since we can't be sure due to BMW's typo on this early brochure. |
