05-30-2013, 06:24 PM | #46 | |
Rep 101
Doesnt hurt to rev the car and shut it down. When the engine is off the turbos stop spinning within 2-10 seconds but still have enough oil pressure around the bearings to prevent damage. What really causes damage is coking. Oil in turbo applications undergoes temperature extremes and has a tendency to break down. If not cooled sufficiently carbon will precipitate from the oil and build up in the bearings, which over time causes damage. |
05-31-2013, 01:05 AM | #48 |
Rep 1,173
Sounds Amazing!!
Awesome write up and videos, thanks for taking the time to post up!! Getting catless DPs installed next week on the M6 with Meisterschaft full exhaust.... Can't wait. |
05-31-2013, 03:58 AM | #49 | |
Rep 5,110
Yes, heat (and lubrication) is the issue. That's why I said the turbos should be allowed to spool down and cool. If you rev the engine the turbos RPM is tremendously higher than at idle, hence taking longer to spool down. When engine is shut down oil and coolant pressure disappears (unless there is a "turbo timer" device installed). The turbos will then rotate for much longer without lubrcation and coolant flow through the turbo housing. This is bad for bearings and also accelerates/worsens the coking process. Not a big issue with just some slight revving, but becomes a issue after a spirited drive if this is done repeatedly. But, just to reiterate what I posted previously: The M5 have the Start/Stop functionality and I'm sure BMW has addressed this issue. So, probably not a big issue on this car. |
06-01-2013, 12:03 PM | #50 | |
Rep 101
If the car was started and revved up cold, the turbo bearings would be more likely to suffer damage as a result of low viscosity oil (from it being cold). If the car was warmed up, revving then shutting it off wont hurt it. Enough oil will still be in the lines and CHRA to prevent damage. Turbos dont spin for minutes after shut down, its a matter of seconds. If a turbo timer is present the engine isnt actually shut down (sounded like you were saying engine is shut down, but oil/coolant keeps flowing). Coking comes from the extreme heat and breakdown of oil, doesnt matter if the oil sits in the bearings or not, it will still coke. If the oil cools down it gets cleaned by the oil filter, preventing the carbon precipitate from building up in the bearings. The start/stop only shuts down the engine for a short time, so very hot oil doesnt have the time to coke in the turbos. It will still be an issue for those that drive their cars hard and shut down with little to no cooling period. |
06-01-2013, 01:54 PM | #51 | |
Savoir Faire
74
Rep 1,772
Current: Alpine White F10 M5|H&R springs|12mm/10mm spacers|Eisenmann Race
Sold:Imola Yellow RS4-KW V3|MTM 10mm spacers|Hotchkis rear sway bar|APR Stage 1|Milltek Catless|RNS-E|Euro RS4 Flat bottom Steering Wheel Sold:E46 323i |
06-01-2013, 04:00 PM | #52 | ||
Rep 5,110
I'm not sure I agree to what you are saying about revving turbo engines and not letting it idle though. First of all, a turbo can spin for at least a minute after shutting the engine down. Even more if you revved it first. The turbo might be rotating at 50.000rpm if you revved it (a modern turbo spins at 150.000rpm (or more) at full load). It won't stop from 50.000rpm in a few seconds (unless the bearings are covered in sticky gum... As regards the Turbo Timer subject. I'm aware of the old school turbo timers that would have to keep the engine running to provide cooling and lubrication (and shouldn't the fact that HKS developed a specific product to let the engine run at idle indicate that there is a point to idle a turbo engine?). Modern engines have electric water pumps and can even have supplementary electric oil pumps that take care of cooling and lubrication after engine shut down. The part # for the supplementary waterpump for the turbos on the M5 is: 11517629916 Anyway, your advice that there is no need to idle a turbo engine (after revving or a spirited drive) is contrary to what experts are saying: Quote:
But, let me once again say that this is not a major issue on the M5 as it has at least supplementary water cooling (which basically eliminates the need to idle the engine). |
06-01-2013, 04:03 PM | #53 | |
Rep 5,110
Modern engines have electric water pumps and can even have supplementary electric oil pumps that take care of cooling and lubrication after engine shut down. The part # for the supplementary waterpump for the turbos on the M5 is: 11517629916 Not sure I would call it pure magic, but clever engineering maybe |
06-01-2013, 07:58 PM | #54 | ||
Rep 101
In the case of the OPs video, the car idled for a bit before shut down. The turbo will stop spinning in less than 15 seconds, the RPMs arent high enough to keep it going for long. The compressor and turbo are lightweight and have fairly low inertia, allowing them to spin up and slow down pretty quick. The larger a turbo the longer it can continue to spin, but these small twins wont go for long. Turbo timers have their purpose. The longer and harder you push a car the more time it needs as a cool off period. Revving the car hard a handful of times isnt enough abuse to get the oil temps hot enough to cause coking. |
06-12-2013, 05:08 PM | #55 |
Rep 67
Thank you for making my stock M5 feel so inadequate ... jerk.
On a serious note though, phenomenal job on capturing the essence of the upgrades. You, sir, are a gentleman and a scholar. |
06-13-2013, 08:01 AM | #56 | |
Rep 7,885
I'm actually graduating tomorrow with my Masters Degree.
07-09-2013, 07:02 PM | #59 |
141
Rep 1,837
Dave, absolutely amazing job and sound!
just picked up my m5 less than 2 weeks ago and can't wait to change from stock exhaust! i have couple of questions, if you don't mind answering. I am thinking of getting GTM exhaust, which is mufflers free and resonators free (please correct me if i am wrong)?! Were you getting any engine faults when you had it, before you changed DP's? and did you upgrade your ECU with GTM exhaust? what would you recommend to go for? GMT or fully straight pipe as yours now?) I had race eisenmann on my e90 and it was not loud enough for me |
07-09-2013, 09:00 PM | #60 |
Curve Thrasher
623
Rep 3,773
I got the same kit except gts with gtm. Dave has gt with gtm plus dp. I have no drone lots of power and great sound. The gtm has resonators. No exhaust gives you cel but the dp will. If you want a rpi go gtm. It's all the way live. (Isley bro)
The more I drove and broke it in the more I liked it. If this what you want trust me you will like it. Last edited by boots; 07-09-2013 at 09:50 PM.. |
07-09-2013, 09:45 PM | #61 | |
Rep 785
Thanks, Greg
991 Turbo
993 GT2 Outlaw |
07-10-2013, 05:09 AM | #62 | |
141
Rep 1,837
what do u mean by saying "i have gts with gtm" and "Dave got gt with gtm" ? sorry about that, i thought GT, GTS and GTM are 3 different systems, where: GTS: Full system with resonators and with mufflers. GT: Full system with no resonators and with mufflers. GTM: Full system with no resonators and with no mufflers. thanks! |
07-10-2013, 03:35 PM | #63 | |
Curve Thrasher
623
Rep 3,773
2013 Bmw M5-Alpine White/Black-Oem gloss blk powder coated wheels-Expel clear bra-35% tint-Rpi Gtm Exhaust-Rpi Downpipes-Rpi Scoops-Halim Cazimi Performance Tune-KwV3 coilovers
Country run |
07-10-2013, 04:46 PM | #64 |
141
Rep 1,837
thank you!
i then i will definitely go for GTM and when software is available i will go "Full Retard" as well just cant stand warnings and symbols flashing all around the car |
10-11-2014, 05:12 PM | #66 | |
171
Rep 375
Are you still running the RPi DPs? When stopped you mentioned you notice the fumes; is this also the case if the windows are up? Your car sounded ridiculously awesome but if one wanted a less aggressive sound how do you think the RPis would sound with the comp pkg exhaust? |
