12-01-2020, 07:42 PM | #1 |
Rep 3,879
Deactivate Auto Headlight Switch
I looked in the owners manual. No luck.
Is there a way that I can control when the headlights come on? When I start the car in the garage, the headlights come on. Same thing when I return. The headlights come on as I pull into the garage. Using the off button will turn them off, till the next time started, then the Auto button is lit up again and the same repeats. |
12-01-2020, 09:07 PM | #2 |
12879
Rep 19,386
Rather than using the Off button just press the Auto button and that should turn off the Auto function.
2021 BMW G20 M340i xDrive - Verde Ermes/Black - 03/2023.67
12-02-2020, 12:53 AM | #3 |
798
Rep 1,786
That didn't work for me. I just tried this today. The headlights were on and I pushed the "Auto" button and they remained on. I'm on iStep version 07/2020.31 for reference purposes.
12-02-2020, 06:53 AM | #4 |
12879
Rep 19,386
Yes, I would imagine they would at that point since they are on. What happened the next time you stated the vehicle though. I know I have accidentally hit the Auto off and my lights didn't come on.
12-02-2020, 12:58 PM | #5 |
Rep 4,246
Low-beam headlight is automatically switched on when the system recognizes that it is dark, even in OFF mode and when driving readiness is activated (Auto)
12-02-2020, 01:41 PM | #6 | |
798
Rep 1,786
BMW needs to open their eyes and minds and actually use these features so they can see the error in their ways!I'm sure this will never happen though. |
12-02-2020, 02:46 PM | #7 |
Rep 6,728
With an incandescent lamp, that might be a problem, but not so much with LED bulbs...an incandescent generally fails when first turning on, the surge through it does that. An LED doesn't really care.
12-02-2020, 03:18 PM | #8 | |
195
Rep 351
There are times when you may want to turn the lights on, when raining for example. Then you can hit Auto to turn them back to light sensing. The button has purpose |
12-02-2020, 03:37 PM | #9 |
Rep 802
12-02-2020, 04:12 PM | #10 |
Rep 6,728
"Automatic headlight
control Concept The low beams are switched on and off automat‐ ically depending on the ambient brightness, for example in tunnels, in twilight or if there is pre‐ cipitation." From the manual. In some places, headlights are required when using wipers, so having them come on automatically makes sense. Now, if the headlight control is NOT in auto, I'm not positive that it does turn them on any time. |
12-02-2020, 07:19 PM | #11 | |
Rep 3,879
12-03-2020, 12:03 AM | #12 | |
798
Rep 1,786
There's a message that pops up on the instrument panel stating that Headlights can not be turned off while driving if you push the "Off" button. Pushing the "Auto" button just throws a message that you have activated the Auto Headlights. Pushing the "Auto" button again just repeats the same message. The "Auto" button LED remains on regardless if you push the "Auto" or the "Off" button. In other words, while driving, you can NOT turn off "Auto" head lights and you Can NOT turn of the head lights by pressing the "Off" button. The "Auto" button LED remains lighted regardless of which button you push. All 2019 and newer X5/X7s have the headlight controls shown below. In the US you can't turn off the headlights unless your parked. The picture below says their automatically switched on "when the system recognizes that it is dark, even in the OFF mode and when driving readiness is activated (country-specific)." |
12-03-2020, 08:43 PM | #13 |
798
Rep 1,786
I did some more testing on this today.
1. The "Auto" button is a single action button not a toggle on/off button. It does one thing only. It turn's on the "Auto" function of the headlights. For example, where I live, it was overcast with low hanging clouds in the afternoon around 3:30 PM. When the "Auto" button is turned on the headlights will come on even though it's not anywhere near dusk or dawn. Just less bright than on a clear day. Additionally, they will activate when you enter a tunnel, heavily shaded area, or when it starts raining. 2. The only scenarios where you can turn off the headlights is when the car is stopped. You can, turn the headlights off if you are stopped and the car is running even with the transmission in Drive and the engine running. However, as soon as you start moving pushing the Off button will not turn off the headlights. The message it throws is "Headlights OFF Not while driving". 3. While parked in the garage after returning from my drive, the Headlights were in the "Auto" mode (Auto Mode button LED illuminated). The headlights turned on as soon as I entered the garage. Once I put the car in park I pressed the headlights off button and the headlights turned off. I turned them on again by pressing the "Auto" button. Next, I turned the headlights off by pressing the Off button while the car was still running in Park. I shut the engine off and then started it again. The headlights came on and the "Auto" button LED was illuminated automatically. So, in a nutshell, the only way you can turn off the headlights is if the car is stopped. However, if it gets really dark, as in dusk or after dark, the headlights will still come back on automatically even though they were turned off before it got dark. When they do come on after being in the off position the Auto LED button will be illuminated. These headlights are Automatic by default. BMW should rename the "Auto" button to "Adaptive" instead of "Auto" because that's how the "Auto" button works currently. It adapts to the climate conditions such as raining, dusk, dark, etc. |
12-03-2020, 11:00 PM | #14 | |
Rep 2,932
Drives: 2020 BMW 530xe
12-04-2020, 08:01 AM | #15 |
Rep 253
Is there a way to code the switch off the lights while the car is moving? It will not comply currently whenever the car is moving.
Also, on my euro spec car, i can turn off the lights completely but only when stationary. |
12-04-2020, 01:56 PM | #16 |
Rep 6,728
MOst of today's instrument panels are illuminated whenever the vehicle is on. When driving around town at night, it is not at all uncommon to see at least one vehicle that does not have their headlights on. When there are street lights, and you can see your instrument panel, the clue to turn the actual headlights on may not be big enough for today's inept or distracted drivers to turn them on. As a safety thing, I don't see a good reason to actually turn them off. Some countries require daylight running lights for this reason. While many things in a modern BMW are controllable with the right computer settings, BMW has not chosen to make many of them available to the user. This is a business decision, and one sometimes dictated by national law based on where the vehicle is delivered.
Yes, many of those functions, nominally locked out from normal user control, can be modified with 'coding' the vehicle. As a result, the community is spoiled into thinking that they have the right to modify the vehicle any way they want. The way I look at it, while that is a nice feature, it is not sold to the customer that way otherwise, they'd include it in the normal menus. You bought the vehicle as is. If you can't change it, tough! That won't stop me or anyone from searching for ways to customize their vehicle, but complaining about the features as sold might get the manufacturer to change things, but is not a requirement. If it bothers you so much, next time, don't buy the same vehicle. IOW, if you don't like the implementation as delivered, you probably shouldn't have bought it if it bothers you that much. ANything that you tweak afterwards is a bonus. Few things in life are perfect. |
12-04-2020, 07:11 PM | #18 |
Rep 4,246
Ne, they're off. Just the front and rear DRLs are on.
12-04-2020, 09:21 PM | #20 |
798
Rep 1,786
Daytime running lights have there own setting in iDrive separate from the Headlight stack below the dash.
12-04-2020, 09:54 PM | #21 | |
798
Rep 1,786
It blows my mind how some of these Designers, Programmers and Engineers come up with what "They" think is a good idea. BMW thinks it makes sense but those that are using their "good" ideas are coming here on the forums asking how to use their "good ideas". I still love the car and the technology is light years ahead of what I've ever driven. I drive it every day. |
12-04-2020, 10:01 PM | #22 | ||
Rep 4,246
