07-03-2021, 06:53 AM | #23 | |
Rep 4,386
07-03-2021, 07:21 AM | #25 |
Rep 4,386
07-11-2021, 07:06 AM | #26 |
PANIC!
485
Rep 823
Before buying something new, I wanted to see if using something I already had on hand would work. I applied Aerospace 303 on the door seals and all other contacts points and it's quiet now. Not sure how long it will last, but this stuff worked just the same.
I originally got this stuff to use on my Lexus' sunroof seal as it was known to dry and crack and eventually fail. Ever since, I typically apply this to all rubber seals, but just never got around to it on this car. |
07-11-2021, 03:20 PM | #28 | |
Rep 2,649
07-12-2021, 07:47 AM | #29 |
Rep 779
Thank God someone posted about this. It drives me crazy when I drive my wife's car.
2020 M340i xDrive, Portimao Blue
2019 X5 xDrive 40i, Mineral White 2006 S2000, Berlina Black (Track car) |
07-12-2021, 07:25 PM | #30 |
Rep 668
In case this helps anyone, I finally found the source of the buzz in the door that buzzes when listening to talk radio and someone with a deep voice is speaking.
The source is a tiny little trim piece inside the door pull that I assume covers a screw. I can't see it, only feel it with my fingertips. I'm planning to just put a piece of scotch tape on it, because just barely touching the piece stops the buzzing. |
07-12-2021, 10:14 PM | #31 |
3141
Rep 320
I don't know that mine is exactly a door squeak. It sounds like the whole interior frame of my car creaks and cracks when I'm driving. It's absolutely awful that a car of this price range would sound like it does. My X5 is garage kept & gets detailed once a month. I'm going to try and get a sound video next time I drive.
07-15-2021, 08:17 AM | #32 |
Rep 114
Back in the 90's a Honda dealer gave me a tube of silicone to apply to the rubber gasket on a huge sunroof that was creaking. Worked fantastic. After some searching I see it is still available today. It's called Honda Shin-Etsu Grease 08798-9013. This video helped me locate the name of the product:
SmartSaves462.00 |
07-15-2021, 08:32 PM | #33 | |
Rep 3,940
Worked like a charm. |
07-16-2021, 05:12 AM | #34 | ||
Rep 289
exactly - detail every month. its actually all those chemicals and polishes and waxes that contaminate the rubber seals and then creating the squeaking) just a fact |
03-16-2022, 07:43 PM | #35 |
Rep 439
Just wanted to thank the prior posters for this thread, wish I had seen it earlier but I guess it's been a while since anyone has had this issue. I first started getting a creaking issue on the drivers door right by my ear a couple months ago. The creak wasn't *too* bad, and since I wasn't aware of an easy solution it kept getting moved to the "I'll deal with that later" list.
For me, the technique of just pushing on various parts of the door until you reached a creaky part worked like a charm. Then I used masking tape to do a dry-run and pinpoint the exact part of the frame that needed to be covered. Got it on the first try. Creak was 100% gone, I was amazed at how completely a simple piece of tape silenced it. From total exasperation to silent bliss. I ordered some of the Polyethylene Film Tape (https://amzn.to/36rE9xu) others have used and will replace the masking tape then. Easy peasy. Second time in a week I've been helped by this forum, thanks everyone for contributing. (Don't know why photo is sideways, has proper orientation prior to uploading.)
2014 981 Cayman S 6MT, X73 Suspension, SES 2021 X5 45e MSport, Manhattan Green, Coffee Merino, Review & Photos Previous: '18 340 GT, '15 M235i 6MT, '15 i3 REx, '15 x1 xDrive28i Last edited by scottomfg; 03-16-2022 at 07:46 PM.. Reason: Don't know why photo is sideways, has proper orientation prior to uploading. |
03-16-2022, 11:33 PM | #36 | |
///M ♥ Recycled Dinosaurs
3210
Rep 1,780
Drives: BMW M4, BMW X5 45e
Anyway to the real question - I can't make out where you applied tape in your photo. (On my phone at least). Do you have a pic where you can point out what was done?
2022 BMW ///M4 Comp M xDrive (Enzian, Kyalami - insta | youtube | bp featured: Delivery + 963M + 2x Enzian!) | 2021 BMW X5 45e (Carbon Black Metallic, Ivory White)
BMW CCA LIFETIME MEMBER | Past cars: 2016 BMW 435i Gran Coupe (Carbon Black Metallic, Oyster White - Euro-delivery) |
03-16-2022, 11:37 PM | #37 | ||
Rep 439
And yes, creaks were when going over bumps or even low speed turning, anything flexing the chassis.
2014 981 Cayman S 6MT, X73 Suspension, SES 2021 X5 45e MSport, Manhattan Green, Coffee Merino, Review & Photos Previous: '18 340 GT, '15 M235i 6MT, '15 i3 REx, '15 x1 xDrive28i |
kjx3210.00 |
03-16-2022, 11:44 PM | #38 | |||
3210
Rep 1,780
03-17-2022, 08:13 AM | #39 | |
Rep 4,386
03-17-2022, 11:44 AM | #40 |
Rep 1,254
I had the dreaded squeak - my fault really, as I used some sort of cleaner wax on the door jamb areas and it did not play nicely with the rubber seals.
Even with a good wiping of 90% alcohol didn't remedy it. I did the gummi phledge on all the rubber seals and it did nothing. Finally, on another thread I read here ordered some 1" thick strips of PPF film and just applied it around where the blue tape is shown and it eliminated 95% of the squeak. I still here it on occasion, but it's probably just due to how stiff the chassis is on my F95. |
03-17-2022, 07:54 PM | #41 |
Rep 668
If your window frames creak over bumps, you can spray a little silicone spray onto a towel and rub it into the felt strip that runs along the very top edge of the inside of the door, above the window. This completely silenced the door creaks for me.
03-17-2022, 08:38 PM | #42 | ||
3210
Rep 1,780
03-17-2022, 10:03 PM | #43 |
654
Rep 1,601
I did not have this problem in my E36 318is, E46 328i or my wife's F25 X3. But had it really bad in a E60 530i and now in my G07 X7.
The fix for me was to use gummypflange on the rubber seal around the doors and a couple of coats of real carnuba wax on the painted surface that these rubber door seals comes in contact with on the car. (Not synthetic wax, ceramic coating or anything else, just pure good old fashioned carnuba wax). This will usually quiet it down for several months (sometimes as long as a year). |
03-18-2022, 09:17 AM | #44 |
Rep 16
Both BMW Gummipflege and Sonax work perfectly 👍
Same problem since E90 and now in G05 and G02. First of all do not use silicone, it will make worse. Put Gummipflege twice a year on all previously cleaned rubber seals. |
