10-16-2021, 04:10 PM | #1 |
Rep 225
Can you rotate the tires on the x5?
Is tire rotation recommended on the G05 40i with xdrive?
The manual doesn't seem to have much info on tire rotation. Any advice appreciated! Thanks! |
10-16-2021, 07:20 PM | #3 | |
Rep 225
I have x-drive with the 20's on all four corners. Was looking at them this morning and seems like the fronts are showing more wear than the rears at about 8k miles. |
5pacey56.00 |
10-17-2021, 12:50 AM | #4 |
Rep 6,797
Depending on which iDrive software you have, the procedure to reset them can differ...the older s/w had a 'RESET" option. The newest version (that I've seen) doesn't, but all you need to do is tell it to 'SAVE', and it will reset. Otherwise, the location won't be right, and you may get pressure warnings assuming you do change the pressure for the new location in the tires.
10-19-2021, 12:59 PM | #5 | |
Rep 225
Im only at 8k miles, but due to the front outside wear im planning to have it rotated tomorrow since i have the squared setup hopefully it won't be an issue. I already read somewhere on the forum regarding the more aggressive camber settings on the G05 hence suggesting not to rotate. That leaves me a bit confused whether to do it or not. |
