      10-23-2021, 07:31 AM   #1
R34L15T
Drives: 2019 BMW X5 30d M Sport
22" Tyre Options
Hi Guys,
In search for front tyres. Currently running the following:
275/35/22 - Continentals
315/30/22 - P Zero
Want a bit more rubber so was wondering if the following would suit with out any issues
275/40/22
315/40/22
Thanks!
BMW X5 30d M Sport
      10-23-2021, 12:19 PM   #2
Auricom
Auricom's Avatar
Drives: 2020 X5 xDrive40i M Sport
Originally Posted by R34L15T View Post
Hi Guys,
315/30/22 - P Zero
275/40/22
315/40/22
Thanks!
Previous thread covering your inquiry in +5 sidewall sizing but also in regards to all-seasons.
But TLDR; is no issue since overall front and rear tire sizes are within 1%. And if you're fine with ONLY summer performance tire options.
Going +5 in front increases overall diameter by 96mm to 114mm = +14%
When speedometer reads 60 km/h actual speed will be 62.2 km/h
Revs per mile is 4% less, from 682 down to 658.
All what ever size changes you make, you want to ensure there is 1% or less differentiation between front and rear cause well xDrive.
https://g05.bimmerpost.com/forums/sh...9#post28042649
My detailed answer here:
https://www.bimmerpost.com/forums/sh...php?p=28042649
      10-27-2021, 09:36 AM   #3
R34L15T
Hi Guys,
315/30/22 - P Zero
275/40/22
315/40/22
Thanks!
Very insightful thank you!
Nearly 1.4 miles in that case (UK)
I remember seeing somewhere on the idrive menu where you can actually adjust the mph difference? Cannot remember where
BMW X5 30d M Sport
      10-27-2021, 03:47 PM   #4
James_G0540i
Australia
446
Drives: 2021 X5 G05 40i M Sport
I believe Michelin now offer a 22" option too.
      10-27-2021, 06:42 PM   #5
R34L15T
Possibly - i was trying to see if it would be ok to use 40 vs 35 on the fronts.
BMW X5 30d M Sport
