04-27-2022, 07:20 AM | #45 | |
Rep 153
04-27-2022, 11:35 AM | #46 |
Rep 216
If you can't get an A-F amp you can use the Technic PnP Add-an-Amp harness for a PnP solution that preserves the OEM harness and use some other amp that meets the specs stated on their site. While it looks to be a bit more work, mostly researching and sourcing the required components, it opens the door to other amps that may be better and/or cheaper than A-F. This is the approach I suspect most custom installers would use.
05-08-2022, 12:26 AM | #47 |
Rep 117
Hi guys looking for help. Was running nicely great amp. Now when ever I put in the Woofer inputs the main speakers drop out and woofers only work, disconnect the woofers input and the mains come back on....
The amp came with a 40amp fuse. Doubt that's the issue. Only thing is I was I had the car on accessories listening for 1 hours while reattaching the amp and putting the car back together and now the battery is very low so I have put it on charge. Anyone else come across this? Cheers Brett |
05-08-2022, 02:40 AM | #49 |
Rep 153
05-08-2022, 03:29 AM | #50 |
Rep 117
06-06-2022, 05:46 AM | #52 | |
140
Rep 1,597
Drives: MY2022 X5 M-Sport 45e White
If it has HiFi get the PP86dsp and make sure you get the new patch cable with 26 wires not the stand cable which has only 22. otherwise your Acoustic Pedestrian Warning system will throw an error.
MY22 X5 M-Sport 45e White, 22"rims, Red Calipers, Ceramic Pads. Better off saying what it does not have and that's a B&O Audio System, otherwise all option boxes are ticked. Last edited by watrob; 06-06-2022 at 05:55 AM.. |
jBwFellow40.00 |
06-06-2022, 01:00 PM | #53 | |
Rep 55
https://www.audiotec-fischer.de/en/k...mpare-matrix/# |
06-14-2022, 07:41 AM | #55 |
Noice
125
Rep 217
Drives: 2023 BMW iX 50drive
I just finished installing the bimmer tech amp and alpha one woofers on my 2022 X5 45e also matched up with the Bavsound speaker kit. All I have to say is WOW! Huge difference in sound quality. Night and day difference. Also puts to shame the Harmon Karmon in my 2021 X5 40i.
I also went ahead and changed the speaker grills to the B&W while I was at it since I wanted the metal grill and the led lighting.
2023 BMW iX xDrive50 - Blue Ridge Mountain Metallic / Oyster Perforated / Ultimate PKG 2 / Sport PKG
2023 BMW X1 xDrive28i - Portimao Blue Metallic / Black perforated /Shadowline/ M sport / premium package |
Tch-Nrd124.50 |
07-03-2022, 06:53 AM | #56 | |
Rep 12
08-03-2022, 11:31 PM | #57 | |
Rep 13
Thank you for such a wonderful post. I was inspired to go this route after reading your post. Unfortunately, due to recent parts shortages, I had to scramble and order parts from multiple vendors. So far, I have the MATCH UP 7DSP, MEC Analog In Module, & 1.7REM harness. I am still looking for the mounting bracket(OOS in the entire country!), as well as 12v with inline 50Amp fuse+holder and ground wire kit(didn’t come with my amp purchase). I am also not sure whether the MEC module needs to be reconfigured to 30V by removing the jumper or not. The instruction manual calls for removal if the input sensitivity is higher than 11V. Not sure how to figure out input sensitivity for the two additional channels through MEC/Analog In. I am installing the amp with the factory installed speakers that come standard with the HiFi system. Has anyone on the forum come across this problem? Any pointers? Thank you for your help in advance! Last edited by Cloud10; 08-03-2022 at 11:34 PM.. Reason: Typos, phone typing! |
08-08-2022, 05:38 PM | #61 | |
Rep 17
Good luck. |
08-08-2022, 07:23 PM | #62 |
Rep 13
Red blinking status light
I was able to install the amp, had to remove the jumper and change settings to 30v to get rid of the warning message.
Upon install and transferring/saving the tunes and settings suggested by encato, my amp keep showing blinking red/status led light while the pc tool is connected to amp. Once I unplug, status led changed to green. Subs are giving bass output now but it sounds a bit distorted, do I need to adjust the equalizer settings to get better output and less distorted bass? Thank you |
08-09-2022, 02:28 PM | #63 |
Rep 13
Does anyone on the forum have a File suitable for Match 7DSP with MEC card for Factory speakers?
I downloaded a file from ATF website but not happy with the output. I have spent some time learning about different settings and fell comfortable using their software, just need a better starting point to narrow/fine tune my settings. The biggest hurdle I am trying to overcome is to find the cross over frequency specs for factory speakers (G05). If anyone has those specs or the PC Tool compatible file for G05, could you please share it? Thank you! |
08-10-2022, 09:34 AM | #64 | |
Rep 216
Set the High Pass Center/Front/Rear/L/R speakers the same (except the time settings used for sound stage which were set correctly in the AF settings file) using Butterworth with a slope of -12db crossed at 140Hz. Be sure to keep the low pass set slope to off. Band pass (set both high and low pass filters) the R/L Subwoofer by settings the High Pass using Butterworth @ -12db crossed at 50Hz and Low Pass using Butterworth @ -12db crossed at 125Hz. You want the front/rear speakers curves to overlap the subs and using a 12db slope separated by 15 to20hz does this. You can play with moving the crossover frequency for the front/rear speakers up a bit to maybe 160Hz maintaining a 15-20hz separation with the under seat subs low pass crossover to get a fuller sound however messing with individual frequencies requires a measuring microphone to do it correctly. I played with the "auto" bass and extender functions in the processor but it always seemed to inconsistent across a variety of music and varying sound levels so left it off. If you do mess with it, use small increments so not to overload the sound with too much bass. It seems to work best when the sound level is moderate... gives a bit of punch to the bass. Hope this helps. |
08-21-2022, 06:29 AM | #65 |
Rep 14
The MEC Card
I believe this was asked before and no response was given, could anyone advise on why I need:
The "MATCH MEC ANALOG IN Match Extension Card" adds two inputs to an UP 7BMW/DSP amp If I'm doing just the amp upgrade on my 2022 X5 45e with no plans for future inspection? Thanks |
10-17-2022, 01:53 PM | #66 |
Rep 7
I'm not expert but as I understand, on post-2019 models, you'll need to use the 1.7RAM harness, and it has 3 molex plugs on it, one of which is the input. The UP 7DSP/BMW requires the analog input module for the molex input to plug into. Without it, you won't have a proper configuration.
