07-16-2021, 06:46 PM | #45 |
Rep 61
Three questions:
- Do you have to recode everything everytime you take it to the dealer/update the car software? Does it reset back to default settings whenever these are done? - Isn't there a code for anti-dazzle headlights? IMO this is the biggest reason why people code, correct? - What's the point of activating the B&W sound options on a vehicle not equipped and B&W speakers? |
07-16-2021, 07:06 PM | #46 | |
Rep 8,753
Drives: eVeRyOnE mAD!
2) coding anti dazzle onto US headlights does not make it function 100% like the EU because the hardware have some differences. it's not a simple code either. actually, very few US folks have coded this because of that fact. coding popularity varies: instrument cluster logo, layout, startup screen, alarm sounds, ASS, windows interrupter, remote tailgate, seat belt reminder… the list goes on. 3) if I recall correctly, B&W and HK share the same amp, but other than the obvious speaker differences, the intimate differences escapes me. one can take advantage of B&W's DSP options. I noticed an improvement in my HK system, but it likely won't improve the HiFi system because of its inherent limitations. |
07-16-2021, 08:09 PM | #47 | |
Rep 3,940
nZtiZia4696.50 |
07-16-2021, 08:25 PM | #48 |
Rep 8,753
07-28-2021, 03:11 AM | #49 | |
Generalissimo
658
Rep 1,415
07-28-2021, 05:02 AM | #50 | |
Rep 8,753
by default, the window will stop closing if you open the door while it's closing using the auto-close function. i coded it to continue closing if i open the door. |
07-28-2021, 02:08 PM | #51 |
Generalissimo
658
Rep 1,415
Yes, that's what I thought. So, "close tailgate with remote without long press" is active by default?
07-28-2021, 02:27 PM | #52 |
Rep 2,948
Drives: 2020 BMW 530xe
Are there any hardware differences anymore? Canada allows anti-dazzle now and from my understanding the same part number is used for Canada and US headlights and only the software differences remain.
07-28-2021, 02:37 PM | #53 | ||
Rep 8,753
closing the tailgate with the key fob requires 2 codes: • tailgate via remote OPEN or OPEN AND CLOSE (the default is OPEN) the second code is responsible for specific button-tailgate closure behavior. • close tailgate with remote without long press ACTIVE or NOT ACTIVE ACTIVE = after a long press of the key fob tailgate button, the tailgate closes, and you can't stop it mid-travel even if you release the button. NOT ACTIVE = after a long press of the key fob tailgate button, the tailgate closes, but you can stop it mid-travel by releasing the button **the wording of the second code is not intuitive, likely lost in its translation to English (the main developer is from EU) Last edited by nZtiZia; 07-28-2021 at 03:00 PM.. |
4ML INC65.50 |
07-28-2021, 02:56 PM | #54 | |
Generalissimo
658
Rep 1,415
07-28-2021, 04:16 PM | #55 | |
Rep 2,948
What would the hardware difference be that you think is present? The primary feature of the anti-dazzle is headlight swiveling to move the beam away from the view of other drivers and the other is turning beams on and off. We have 4 lights in the US and each support movement as shown by the movement taken during startup. Although it is possible BMW makes a US specific (or NA specific) headlight it seems less likely to me. As then why would they have to decode the cars when they could just skip adding the hardware features that aren't needed and skip decoding altogether? |
4ML INC65.50 |
07-28-2021, 05:02 PM | #56 |
Rep 8,753
For those who haven't coded, something to think about
you could be right! I don't really follow this feature so I may have glanced through applicable threads incorrectly. maybe I got confused in the functionality of anti dazzle between standard LED headlights and the laser headlights. maybe LexxM3 or @ifr can set me straight
08-01-2021, 12:27 PM | #57 | ||
Rep 842
2021 G05 X5 ///M50i / Phytonic Blue / Cognac Vernasca
iStep 03/2023.50 |
08-06-2021, 12:48 AM | #58 |
Rep 17
Drives: 2020 Lexus RC F, 2022 BMW X5
Light on - light off, I don't think I would care. ASS sounds like it is a pain in the ass and turning it off permanently will be high on my list when I receive my 2022 X5.
08-06-2021, 10:08 AM | #59 | |
Rep 181
08-09-2021, 06:35 AM | #60 |
Rep 181
To follow up on this particular piece of this thread. I had previously noticed while coding other items, an option under head unit control unit something about B & W coding. So, I went back and connected up to my X5 and sure enough there was a coding option related to B&W. But I have HK system. So, I went in it and there was a note stating that in order to this to work you had to have the HK system. I had to assume that when the BimmerCode read my contents within my VIN number vehicle or it would not be there. So, I selected the “active” option and coded it. What it did was to add five dynamic listening selection to my sound screen. And in fact, they seem to work really well. I can’t remember exact words, but they were to effect of “Studio, Concert, On Stage, Theater, and Lounge”. Actually, the whole HK system seemed to improve sound quality. Equalizer seemed more responsive too. This all was from the basic coding function NOT the Expert mode (Which I have never even looked at) One thing which was great was in the “Theater” setting, if you play a full 5:1 surround sound movie, you get full surround sound affects in the vehicle.
08-09-2021, 07:09 AM | #61 |
Rep 8,753
yup, these are the same features that show up if you were to EXPERT code (before the option became available more easily in the modules).
**one little thing I noticed is that the background image after B&W coding looks like perforated leather. I agree with the HK sounding more improved after these changes. |
08-09-2021, 04:32 PM | #62 | |
Rep 842
iStep 03/2023.50 |
08-09-2021, 04:57 PM | #63 |
Rep 8,753
yup. u can run the most recent backup which is a 'snapshot' of the system prior to the last coding, or you can re-select the default setting(s) then code again.
JimVR4337.50 |
08-09-2021, 10:35 PM | #64 |
Rep 842
Thanks, I enabled it and got the 5 options for surround. I had to re-enable VIM as well. Now I need to figure out how to play one of my surround music tracks
iStep 03/2023.50 |
08-10-2021, 07:15 AM | #65 | |
170
Rep 301
Shawzy44
2024 BMW X1 28i 2023 BMW X3 M40i 2019 BMW 440iX M Performance Cabriolet |
nZtiZia4696.50 |
