01-14-2023, 12:52 AM | #1 |
Rep 480
45e transfer box broken
Felt some mild stuttering when driving off. Both in electric as ice. Since the car is almost out of warranty, I brought it to the shop. Appeared the transferbox is broken and needs replacement. There is only 36k km on it. It is covered by warranty, but I’m surprised things start to break down this fast. It seems to be a known issue with the 45e.
01-14-2023, 07:13 AM | #2 |
Rep 204
Drives: 2022 BMW X5 xDrive 40i
How noticeable was the stuttering, like from 1 to 10
01-14-2023, 07:24 AM | #4 |
Rep 480
It felt like driving over a broomstick a couple of times. At first I thought it was something on the road. But when testing it from 0 on a fresh laid piece of flat road I could feel about 2 or 3 “bumps”. Also when driving of from 0, sometimes felt like I floored the car while I was not. As if there was a short delay in driving off and suddenly make up for the lost time and give it all for a second. Making the CFO thinking I was going for a drag race. But hard to explain. At the dealer a mechanic stepped in the car. I demonstrated it to him both on electric and ice. He immediatelly said, transfer box. Known issue with the 45e. So be aware, if in doubt, have it checked. To prove it’s the transfer box, they put the car in neutral, mark the tires and manually push the car 20 wheel rotations. After that they measure the difference between front/rear. And if it’s within the margin, it’s probably tires/rims. If it’s outside the margin, it’s the transfer box. For warranty they even had to put on a different wheel set, to exlude them from the test.
01-14-2023, 08:54 AM | #6 | |
Rep 272
ikheetleon218.50 volodp198.00 |
01-14-2023, 09:01 AM | #7 | |
Rep 480
01-14-2023, 03:34 PM | #9 |
Rep 172
The transfer case issue appeared before. Indeed it seems to be a recurring issue
https://g05.bimmerpost.com/forums/sh....php?t=1934918 https://g05.bimmerpost.com/forums/sh....php?t=1570771 |
ikheetleon218.50 |
01-14-2023, 04:59 PM | #12 |
Rep 250
01-15-2023, 01:25 AM | #14 | |
Rep 172
01-15-2023, 02:18 AM | #15 |
Rep 272
Slippery roads? That’s not an excuse. If the technical design is that bad, bmw must do something about that.
ikheetleon218.50 |
01-15-2023, 03:31 AM | #16 | |
Rep 480
For summers I have the 22" styling 742M rims with summer tyres (same size, only different width). The dealer said it might have something to do with not swapping all tyres at the same time. But so far, I've only replaced the summer tyres, and did all 4 at the same time, allthough the rear tires weren't really worn out. So in my case I'm somehow "lucky" that it broke during warranty. But to be honest, with the bugs and shit I've had with this car, I'm looking at other brands for my next purchase. I've been driving BMW since 2007, (E46 330d, E91 335d, F15 M50d, G05 45e). The G05 was bought new, all the others were second hand. But with the G05 I've been so many times to the dealer (which always helped me very well) I've lost count. We have normal well maintained roads in the Netherlands (so not like the Belgium off-road highways ). Not slippery to my opinion. I have a towing hook, but only for a bike rack. |
1230vani652.50 |
01-15-2023, 05:19 AM | #17 | |
Rep 1,363
Rob |
01-15-2023, 05:25 AM | #18 | |
Rep 272
ikheetleon218.50 |
01-15-2023, 02:26 PM | #19 |
Rep 29
My 2016 Porsche Cayenne had an early transfer case failure, at about 20k miles. Common problem with Cayennes for awhile, and Porsche extended the warranty on the transfer case to something like 100k miles. Good thing, because the second transfer case failed a couple of years ago at about 70k miles.
I believe the transfer case used in the Cayenne was made by ZF, who likely make BMW's transfer cases as well. |
ikheetleon218.50 |
01-15-2023, 03:38 PM | #20 |
Rep 118
I recently traded in a 2019 X5 50i with a bad transfer case. Luckily it was still under warranty. The symptoms were exactly as described by the OP.
03-17-2024, 02:56 PM | #21 | |
Rep 28
Hello. So you had the transfer case replaced ! Or just had the oil flushed. Im having the same symptoms. I installed a 4 new non flat tiers today and the symptoms are becoming more and more worse. Thanks |
03-17-2024, 02:58 PM | #22 |
Rep 480
Mine got fixed under warranty. I’m not sure if they replaced the complete transfercase or just parts of it. But parts were replaced, so not just an oil flush.
