05-29-2020, 12:06 PM | #23 | |
Rep 3,506
General inspection of paint and body, inside for damage... The big thing is to drive it on every mode. Ask to take it out for about 1 hr or so and really get to know it. Sell the well I live so far away if I'm buying today I want to drive it for awhile to test it out. Take it on highway, and side streets at all speeds. Stop park it check cameras make sure nothing stands out for your 3 hr ride home when you buy it. After that warranty everything that shows up!!
2022 M8 Comp Convertible
05-29-2020, 12:16 PM | #24 | |
125
Rep 372
Tenac4537.00 |
05-29-2020, 12:48 PM | #25 | |
Rep 4,315
Spend as much time searching through this forum, making notes and asking questions as you can before going and don't shy away from printing some of the issues out and taking it with you as I guarantee you that once there, it will be very difficult to remember all you are learning here. I would also get it in writing that if you buy it, they will install the latest level software for free before you take it off their lot. Hopefully someone here can chime in on what number that is but there is also a separate thread on that topic you can check out. During your visit and before you test drive it, have their resident genius sit in the car with you and go over its iDrive menu so you know how its set. I'm sure whoever owned it before had it tweaked to their liking. This will also give you the chance to see if something doesn't work while you have them in the car with you. Some of the silliest things can be overlooked that might cost you when you discover them once you are home. For instance, after reading through the "passed" two page CPO checklist on my car, I walked out to see it and took out my tire tread depth gauge only to find out that the two rear tires were at their absolute minimum tread depth. I had them replaced on the spot at no charge. I don't believe this was due to dishonesty, I believe they had a new tech measure them and he got confused at how to read the gauge, as simple as that. The best of luck to you and I truly hope everything they are telling you is the truth because they know very well that once you leave their lot, you will not be returning for service so any issues they may not be revealing will be someone else's problem...know what I mean? |
05-29-2020, 09:04 PM | #26 | |
125
Rep 372
