      06-05-2020, 04:04 PM   #1299
Frenetic
PANIC!
Frenetic's Avatar
482
Drives: 2020 X5 M50i
Is there a way to code out the steering wheel tilt away each time the ignition turns off? I would like to turn it off. It’s really slow in retracting and extending.
      06-05-2020, 08:19 PM   #1300
jimv03
Drives: 2019 BMW X5
Originally Posted by LexxM3 View Post
Originally Posted by TK421BMW View Post
To be able to have it display cars in the lane next to you like the above, is that a software update or something that can be coded?
That's called ADV (Assisted Driving View). See video:
If your G05 is MY2019 with the necessary options (5AU and ISTEP 07/2019.xx or later), you need to code to get ADV, but it can now be done with Bimmercode in expert mode:
DKOMBI
- CB_FZG_UMGEBUNG_FAS -> Aktiv
- PIA_FZG_UMGEBUNG_FAS -> Aktiv
- SICHT_ABSICHT_ENABLE -> Aktiv
Thanks! So I coded my 2019 model Go5 and I now how the ASD but only when in assisted driving. I don't have an option to display all the time? What did I miss??
      06-06-2020, 06:56 AM   #1301
LowerEast
Drives: .
I just received my new car and got through the coding With Bimmercode yesterday.
Everything went smoothly and seems to have been updated in line with what I coded except for the seat belt warnings for driver and passenger. I coded both to “not active”, but am still getting the audible warning if I start the car without first buckling up, or if I remove the seatbelt with the engine still running.
Any ideas on how to resolve this?
Also, as a disclaimer, I and everyone who travels in my car wears a seatbelt when driving. I want the chime gone because I don’t need to hear a reminder that I took my seat belt off before I shut off the ignition, pressed the start button before I put on my seat belt, or didn’t buckle up to move the car in my driveway etc.
      06-06-2020, 08:57 AM   #1302
jmciver
///M SubDriver
jmciver's Avatar
Drives: 2017 M3, 2020 X7 40i
2017 BMW M3  [10.00]
2020 BMW X7  [0.00]
2019 BMW X3  [0.00]
2009 BMW 128i  [0.00]
DKOMBI
You probably also need to code a few parameters in the Head Unit module in order to display the option to turn this on/off. My car has this option from the factory so I don't know what the parameters are. But I do have a menu option in iDrive to turn this feature on/off..
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior
X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic
X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's)
      06-06-2020, 12:10 PM   #1303
VTENGR
1053
I coded my seat belt reminder off... You still get the reminder to buckle up when the car starts but you don't get the annoying alarm if you don't. Not sure if there's a way to code both off.
      06-06-2020, 01:43 PM   #1304
jimv03
Drives: 2019 BMW X5
DKOMBI
Thanks! You were correct. There was one more parameter that needed to be coded. All good now!
      06-06-2020, 05:58 PM   #1305
Frenetic
PANIC!
Frenetic's Avatar
482
Anyone do the Brake Force Display change? Certain cars--under emergency braking--will blink their brake lights versus the solid display. This setting allows you to change the threshold to when that will happen (i.e., you can lower the braking force).
https://youtu.be/MWjD7Zrb6Yk
Thing is, though, according to the above video there are additional steps, but according to BimmerCode, it's just two simple settings. Has anyone changed this with the two settings and verified it worked?
Brake Force Display
Brake Force Display activation brake force
The brake deceleration at which the Brake Force Display is activated.
Values:
Weak braking (5 m/s²)
Medium braking (7 m/s²)
Hard braking (8 m/s²)
Requirements:
“Body Domain Controller” BDC control unit
“UniCarScan“, “OBDLink” or ENET adapter
Brake Force Display activation speed
The speed at which the Brake Force Display is activated.
Values:
5 km/h
10 km/h
20 km/h
30 km/h
40 km/h
50 km/h
Requirements:
      06-06-2020, 08:15 PM   #1306
TestnDoc
Drives: 2008 BMW M3
What’s the coding for this? Thanks
22 BMW X7 M50i
24 Porsche Macan GTS
24 MB GLS 580 (wifey)
23 Countryman JW Cooper (wifey)
      06-07-2020, 10:28 AM   #1307
ifr
ifr's Avatar
United Kingdom
1198
Drives: Tesla MY LR AWD
The full coding for ADV is
DKOMBI:
CB_FZG_UMGEBUNG_FAS: aktiv [01]
CB_PRESELECT_NAVI_ANSICHT_FZG_UMGEBUNG: aktiv [01]
PIA_FZG_UMGEBUNG_FAS: aktiv [01]
SICHT_ABSICHT_ENABLE: aktiv [01]
Activate as many as possible. All coding for ADV is in DKOMBI, no other ECU need be coded, but if you want it on all the time you need to replace the console map preview with ADV, within i-drive menu.
      06-07-2020, 07:15 PM   #1308
TestnDoc
Drives: 2008 BMW M3
Cool. Thanks!
22 BMW X7 M50i
      06-07-2020, 07:16 PM   #1309
Aimster82
Drives: 2018 X3 M40i 2019 BMW X5 5.0
There is no search for Android bimmercode. Can someone tell me the steps to code ADV? -- Nevermind I found it manually. Works, thanks!
      06-08-2020, 06:38 PM   #1310
alpha265
alpha265's Avatar
Drives: BMW X7
Just received my MHD ENET
I can confirm that this wireless unit is a lot faster than the Bluetooth counter part.
However, leaving the unit plugged in will trip the vehicle's alarm system.
LexxM31698.50
      06-08-2020, 07:58 PM   #1311
mitch57
805
Drives: 2020 BMW X7 xDrive40i
Why would you leave it plugged in anyway? How long was it plugged in before it triggered the alarm?
      06-08-2020, 08:05 PM   #1312
alpha265
alpha265's Avatar
Drives: BMW X7
I normally left the Bluetooth unit plugged in. Approximately 2 minutes later the alarm system tripped. At first I thought it was something wrong with the coding so I restored my last coding and the problem persisted. I realize it may be the wireless unit and the alarm system is back to normal after removing the unit.
      06-08-2020, 08:28 PM   #1313
LexxM3
LexxM3's Avatar
1699
Drives: E46M3, G05X5
2019 X5  [0.00]
That's annoying. Might need to hack in an off switch when mine gets in. Any chance it's held together by screws rather than glue?
      06-08-2020, 08:31 PM   #1314
alpha265
alpha265's Avatar
Drives: BMW X7
I didn't notice any visible screws. Possibly held together by glue.
      06-08-2020, 08:33 PM   #1315
mitch57
805
I have this same ODBII adapter on order as well. So, what happens if the coding doesn't get finished within 2 minutes?
Can you silence the alarm while the adapter is plugged in with the key fob?
      06-08-2020, 08:42 PM   #1316
Frenetic
PANIC!
Frenetic's Avatar
482
I purchased this one, but it didn’t work.
Veepeak OBDCheck BLE+ Bluetooth 4.0 OBD2 Scanner for iOS & Android, Car Diagnostic Code Reader Scan Tool for Universal OBDII/EOBD Vehicles https://www.amazon.com/dp/B076XVQMVS..._jHU3Eb4228D9C
I purchased it based off of recommendations from within the app itself. I could interface, but it wouldn’t program. I then went to the website and there were more details on the recommended scanners and lucky me, the one I first purchased was listed as not really compatible with the G05.
I ended up returning it and just got this one today as there aren’t many available on Amazon that is listed as compatible with BimmerCode.
New 2M Ethernet to OBD Interface Cable E-SYS ICOM Coding F-series for BMW ENET
https://www.amazon.com/dp/B00MECEI14..._ZEU3EbW6AS1FC
I haven’t tried it yet. Anyone have any success with the wired one I just got?
      06-08-2020, 08:55 PM   #1317
alpha265
alpha265's Avatar
Drives: BMW X7
The alarm is not activated when you are inside your vehicle. The alarm is only activated when you leave and lock your car.
      06-08-2020, 09:34 PM   #1318
mitch57
805
Ahhh! I see. I wonder what's causing that with the ENET adapter and not with Bluetooth adapters.
Have you asked Stephan from BimmerCode if he knows why this might be happening? Especially since this appears to only be a problem with this specific adapter.
      06-08-2020, 09:47 PM   #1319
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
How could it be Bimmercode app? When the alarm is going off, it is not connected to the adapter and is nowhere near the car. No, by far most likely is that the MHD adapter has a large standby/parasitic current and the car security system monitors for that as an anti-theft anti-hacking facility. It's almost certainly MHD's fault, plain and simple. The other recommended adapters either got lucky and accidentally have low standby current, or more likely explicitly designed for this and powered themselves down properly.
      06-08-2020, 10:02 PM   #1320
LexxM3
LexxM3's Avatar
1699
2019 X5  [0.00]
Originally Posted by Frenetic View Post
I purchased this one, but it didn't work.
I purchased it based off of recommendations from within the app itself. I could interface, but it wouldn't program. I then went to the website and there were more details on the recommended scanners and lucky me, the one I first purchased was listed as not really compatible with the G05.
I ended up returning it and just got this one today as there aren't many available on Amazon that is listed as compatible with BimmerCode.
I haven't tried it yet. Anyone have any success with the wired one I just got?
Well, Bimmercode app is actually pretty clear that neither of the two Veepak adapters are compatible with G-series cars (see pic), so best not to blame the app (for this). It gets pretty confusing which is why I have always recommended the OBDLink MX+ adapter as the simplest and most reliable for beginners ... but even they seemed to have screwed up with a firmware update recently (search for posts on the topic if interested).
The new thing you bought is an OBD to Ethernet cable. Did you also buy the Ethernet to Lightning interface? If not, you're going to have a little trouble shoving that big Ethernet RJ45 plug into your iPhone for Bimmercode *mobile app* to function with it . Anyway, the OBD to Ethernet cable should be fine, but you need the Lightning interface as well. This combo is very fast, but less reliable than the old-firmware OBDLink MX+ BT interface.
