11-29-2018, 12:27 AM | #1 |
Rep 533
2019 X5 Suspension option comparison
new 2019 x5 comes with several suspension options, which is really confusing to a newbie like me. local dealership is very helpful and provide explanation ( see below )
========= Suspension and Handling: More agility, comfort and enhanced off-road capabilities. The newly developed suspension, various control systems and a number of suspension options turn the new BMW X5 into an SAV that establishes a new benchmark for all-around ability in its class. Equipped with a double-wishbone front suspension, five-link rear suspension and Dynamic Damper Control as standard, the chassis of the X5 can be additionally configured to maximize its dynamic ability, comfort or off-road capability. Standard Dynamic Damper Control The basic X5 suspension set-up is designed to yield an ideal mix of outstanding driving dynamics, steering precision, agility and comfort. The SAV now comes as standard with the Dynamic Damper Control system, whose electronically controlled dampers sharpen the X5’s handling dynamics at the same time as increasing ride and suspension comfort. Two-Axle Air Suspension The optional self-levelling two-axle air suspension maximizes ride comfort. The suspension’s air supply is controlled individually for each wheel using an electrically driven compressor with pressure reservoir, enabling it to balance out an unevenly loaded vehicle. Since the air suspension works in tandem with the Dynamic Stability Control (DSC) system, the vehicle load registered by its sensors can be factored into braking calculations. Above 86 mph and in Sport mode, the suspension is automatically lowered by about 0.8 inches; in off-road terrain, it can be raised by up to around 1.6 inches. For loading it can be lowered by around 1.6 inches at the touch of a button. Overall, this means that ride height can be varied by up to approximately 3.2 inches. xOffroad Package (xLine only) Another new feature for the BMW X5 is the Off-road package with off-road-specific xDrive adaptation and off-road experience control. The package’s specification includes rugged underbody protection at the front and rear of the vehicle, along with the two-axle air suspension and electronically controlled rear differential lock. The differential lock balances the rotational speed of the rear wheels when they encounter varying friction coefficients in off-road terrain. The xSand, xRock, xGravel and xSnow modes can be selected at the push of a button and automatically adjust the vehicle’s ground clearance, xDrive set-up, DSC, accelerator response and transmission set-up to match the current properties of the terrain or road surface. Available Integral Active Steering The Integral Active Steering, available for the first time for the BMW X5, makes the over 16 foot long SAV as maneuverable and easy to direct around hairpin bends as a compact car, in addition to significantly increasing stability at higher speeds, especially when executing a fast lane change. This feature turns the rear wheels in either opposing or the same direction when steering, which significantly improves both maneuverability at low speeds and agility at high speeds. Adaptive M Suspension (included in M Sport Package) Adaptive M Suspension (2VF) is now included with M Sport Package for all models. This suspension enhances the standard suspension by providing variable suspension and damping characteristics which can be adjusted through the driving experience control switch. Dynamic Handling Package - Adaptive M Suspension Professional (X5 xDrive50i with M Sport Package only) The X5 xDrive50i can become even more agile to drive with the Adaptive M Suspension Professional, which complements Integral Active Steering with anti-roll stabilization to reduce body roll in bends, enabling both more dynamic and more comfortable cornering. The roll stabilization system employs electric swivel motors to enable remarkably swift and precise compensation of body roll under dynamic cornering. This increases agility and directional stability when turning into corners and helps optimize traction when accelerating out. The system has the additional effect of increasing straight-line driving comfort by actively countering the vibrations triggered by bumps on one side of the road. Comfort Handling Package - Two-Axle Air Suspension + Integral Active Steering (M Sport Package only) Starting with December 2018 SOP, vehicles equipped with M Sport Package can now add the Comfort Handling Package. This package combines the features of the optional self-levelling two-axle air suspension and the Integral Active Steering for a more comfortable and agile ride. At speeds above 86 mph and in Sport mode, the suspension is automatically lowered by about 0.8 inches, allowing for increased aerodynamics and a more sporty look. Please note, this package cannot be combined with the Dynamic Handling Package, and removes the Adaptive M Suspension that comes standard in the M Sport Package. ======== air suspension seems a better choice, I hesitate when consider maintenance cost. does anyone know if BMW air suspension reliable in general? and how long it can last? |
11-29-2018, 10:49 AM | #2 |
Rep 157
I have the rear air suspension in my 2014 X5, which I've owned for 4 1/2 years and 68k miles -- no issues. I realize that's just one data point, but at least it's a positive one. I'm looking forward to the 2-axle air suspension in my new X5.
11-29-2018, 11:00 AM | #3 |
Rep 6,121
'better choice' depends on what you're wanting from the X5. If you prefer the smoothest ride an air suspension will be the choice. On the other hand for sportiness the DHP is a must because of the anti roll stabilization and active dampers.
Audi had both an air suspension + active dampers which gives a nice ride but no anti-roll bars meant it still had some roll in the corners. Since the X5 is heavier with a higher CoG it still want to lean more. I prefer whatever trivial agility I can get in an SAV for when you want things to be more fun. I drove an X5 on air and is rode smoothy, body roll was still noticable but much better than the other older F15. Based on this I assume the DHP will be great (none were available for me to test) therefore that's what I got.
Xtabi1701.50 |
11-29-2018, 02:08 PM | #4 |
Rep 533
12-01-2018, 10:45 PM | #5 | |
Rep 157
12-02-2018, 10:24 AM | #6 | ||
Rep 533
01-11-2019, 12:01 AM | #7 | |||
Rep 75
I tried to lower it but as soon as I drive it, it goes back to the normal level, is there a way I can adjust the settings to have the suspension close to DHP feeling? Would a sport or sport plus mode do it? Is there anyway I can stay on comfort mode but my suspension is a bit tighter for cornering? Any help will be greatly appreciated |
01-11-2019, 04:44 AM | #8 | |
Rep 978
If you go into car > settings > Drive Mode there should be an options to setup “Sport Individual” and "Eco Individual". For each, you can set the suspension, steering, transmission to your liking. Then just press the Sport button repeatedly to cycle through “Sport”, “Sport Plus” and “Sport Individual”. Sport Individual will use your defined settings and will lower the vehicle height one setting. I’ve got my Sport Individual setup with "Sport Suspension" and all other settings on "Comfort" - which let’s me use a tighter suspension when I want it but not at the expense of comfort mode elsewhere. Extra benefit, Sport Individual disables A.S.S. Last edited by lumpydog; 01-11-2019 at 07:53 AM.. Reason: clarification |
Forrera24.50 |
01-11-2019, 11:47 AM | #9 | ||
Rep 75
08-30-2019, 01:11 PM | #10 |
Rep 15
Any upgrade retrofit options for air set up?
Having a 7 seat x50d GO5 meant I had to have the AS and IAS options but I truly hate how soft it is and cornering is woeful at any sort of speed.
I’m hoping therefore someone will be able to upgrade and stiffen the sport + setting - if not i’m Going to have to swap out of mine and get the sq8 when it finally lands. Have asked Hamann and Schnitzer but still waiting on a response. All ideas or suggestions welcome. |
08-30-2019, 02:07 PM | #11 | |
Rep 25
Drives: BMW X5
08-30-2019, 02:43 PM | #13 |
Rep 421
Drive mode defaults to Comfort upon restart. Suspension setting remembers last setting (at least it will remember if you were in Sport suspension setting, -20mm ride height). Auto stop/start defaults to 'on' (you can program to change this to remember last setting using, for example, Bimmercode).
09-24-2019, 02:33 PM | #14 | |
Rep 99
When you select sport mode does it automatically lower the car by 20mm or does it only lower it above a certain speed ?? Thank you |
09-24-2019, 02:52 PM | #15 |
Rep 143
I have a 50i MSport w/22’s and even in sport + mode the car leans wayyy too much around the turns. It’s a constant reminder that i missed the boat getting the DHP option on my 50i.
Please, if you like to have fun around the turns without putting people in the x5 in danger. Spend the extra $ and get the DHP... i regret it everytime a curvy road is approaching. I typically get the wife looking over and saying this isn’t a sports car and i instantly think of that damn option i should have sprung for.... true story. |
09-24-2019, 03:11 PM | #16 | ||
Rep 4,246
SPORT level 1. Activation via SPORT button: 0 up to maximum speed 2. Automatic lowering without button actuation: 200 km/h (124 mph) up to maximum speed DYNAMIC level If you leave it at normal and cruise at 87-124, it will automatically lower to Dynamic height or -10mm.
09-27-2019, 01:19 PM | #17 | |
Rep 99
09-27-2019, 02:45 PM | #19 |
Owner
132
Rep 566
Drives: G05 30d M-Sport
I really like the air suspension on mine, but I WISH I had taken the Active Steering 4 wheel steering option as well, as it makes an incredible difference in handling on small roads and roudabouts, and for manoeuvring.
I had a BOAT of a 840 series at a loaner with that, and it felt I was driving a small hatchback at the way it was dealing with that sort of things, it was really borderline spooky. As far as rising/lowering the car, I also like that a lot -- I do some pretty rough tracks with the car and I really like being able to raise it; while the tailgate button to lower the car to it's lowest setting is very handy to load/unload stuff... I haven't really tried to drive the wheels of the car as yet, as it's still breaking in period, but so far it's a LOT nicer than the Discovery I tried with air suspension, which felt like a river barge in comparison.
Received 190911: X5 30d M-Sport:Artic Grey:Comfort Pack:Tech Pack:Visibility Pack: Driver Assist Pro Pack:Heat Pack:Glass Roof:Leather Dash
09-27-2019, 02:52 PM | #20 | |
Rep 4,246
But these are other factors where you're unable to adjust the 2-axle ride height - not necessarily relevant to your question. 11.4.2. Control inhibitors The following vehicle conditions prevent a change in ride height: • Brake test stand • Transport mode • Stored speed thresholds • Increased lateral or longitudinal dynamics • Flat tire • Non-availability due to component protection (component temperatures or pneumatic pressures exceeded) • Low vehicle voltage in the residing condition (protection against starter operation if insufficient energy is available) • Doors open • Electrical connector of trailer tow hitch inserted. The control inhibitors prevent damage to the vehicle, among other things, due to incorrect operation. At higher payloads with air suspension strut pressures of more than 9 bar, the high level is not available due to component protection.
01-01-2020, 09:23 PM | #21 |
Rep 258
My current tow rig, a Grand Cherokee, has air suspension and it tows like a dream. Is the air suspension to blame? I barely Notice the 21’ boat behind me. I’m hoping for the same arrangement and since I’m custom ordering my bmw, I can choose whatever’s best. Advice for towing?
2003 Z4 2.5i Roadster (SOLD)
2006 Z4M Coupe 2017 Porsche 911 C2S Cabriolet |
01-17-2020, 08:04 PM | #22 |
Rep 275
Tags |
adaptive suspension, air suspension |
