01-21-2020, 07:56 PM | #1 |
Rep 74
Stealth Hitch - Question
Hey guys, I just got the stealth hitch installed and and noticed some silver mesh type of thing under the car and it feels like it's not 100% stealth or the installer messed up. Can someone please take a look and let me know if this looks alright?[IMG][/IMG]
01-21-2020, 08:26 PM | #2 |
Rep 810
I also have a stealth hitch, and looks like the installer has completely taken off and removed the black protective panel on your car. Either that, or he got over excited on the cut out and made it too large.
The proper practice is to cutout a very small section of that panel, just enough to enable you to insert the towbar into the vertical receiver underneath. I had mine installed by my BMW dealer, and he cutout a section of that panel. You can only see a small portion of that protective mesh. I'll take some pics later and post. In the mean time, I'd go back and ask for that panel to be re-installed, minus the small cutout. Did you get a dealer to install the towbar? |
AndroidRobot4328.00 XMan9.00 |
01-21-2020, 08:28 PM | #3 | |
Rep 74
You are talking about this step right? See attached picture |
01-21-2020, 08:35 PM | #4 | |
Rep 810
Also, make sure the towbar installation has been coded into the car's computers/ECU. You should see a "Trailer Mode" in the car's settings. You can either choose to enable Trailer mode before you connect the trailer, OR after you have connected the trailer the car sensors that a trailer has been connected and automatically goes into that mode. The trailer mode disables certain functions, and applies a stability program specific to towing. |
01-21-2020, 08:36 PM | #5 |
Rep 810
01-21-2020, 08:37 PM | #6 | ||
Rep 74
01-21-2020, 10:52 PM | #7 |
Rep 810
Here's mine....
alpinekarthik105.50 |
01-22-2020, 12:29 AM | #9 |
88
Rep 380
Mine is similar. The instructions asked to cut this large template which I think is too much. But replacing this panel and recutting seems a waste of money.
01-22-2020, 01:25 AM | #10 |
Rep 810
08-28-2020, 07:38 PM | #11 |
Rep 17
Mine looks exactly the same.
I got it done today at a recommended installer from Stealth Hitch's website. Not sure why they had to make such a huge cutout. |
09-04-2020, 05:40 PM | #12 |
Rep 5
Has anyone been able to code the X5 to activate tow mode with the Stealth Hitch?
I've got mine installed for towing and would like to find a way to activate that mode. |
09-04-2020, 09:33 PM | #13 | |
Rep 810
I'm not sure if the dealer will do the coding on a 3rd party tow-bar installation. |
09-04-2020, 09:54 PM | #14 |
Rep 176
We installed that hitch ourselves, The larger cutout on the passenger side is for room to get your hand in there to turn the big spring loaded knob until it clicks and stays cocked and ready to insert the receiver part. Ours is the model just for a bike rack, no chain connections for towing.
I’ve been on here before but after awhile they deleted my email etc. |
09-04-2020, 10:10 PM | #15 |
Rep 810
I have since painted the exposed silver mesh sections black.
Basically bought myself a can of black enamel automotive paint, removed that upper-inner panel and sprayed it with a couple of coats. I also sprayed the larger panel (using some cardboard to contain the spray to the silver area), and it looks awesome, blends in perfectly with the lower part and no more stand out.. I agree, the silver heat mesh stands out too much, doesn't look professional, looks like something took a bite out of that area. Dealers should be doing this when installing the after-factory stealth hitch. ***UPDATE*** - pics below. Last edited by James_G0540i; 09-05-2020 at 12:55 AM.. |
09-14-2020, 09:05 PM | #16 | |
Rep 17
10-15-2020, 05:45 AM | #17 |
Rep 27
I had my stealth hitch installed yesterday by my local dealer but they didn’t program “tow mode”. Did anyone else have any issues getting the service center to activate that setting?
10-15-2020, 07:25 AM | #18 |
10
Rep 37
You need the BMW harness and BMW control module to be able to use that feature. The BMW harness has been on been on back order since forever so they aren’t included in the stealth hitch kit. I’m waiting till they are able to get some stock before I make my purchase.
10-15-2020, 01:23 PM | #19 | |
Rep 27
10-15-2020, 01:57 PM | #20 | |
Rep 106
In order to get the true "Trailer Mode" that is part of iDrive you would need both the BMW controller and wiring harness. Personally I'm still holding out hope that Stealth themselves will release a Tow kit with the BMW electronics. |
10-15-2020, 06:23 PM | #21 |
Rep 6,789
There are ways to get the lights to work with any CANBUS system (like the BMW uses), but you need a module to talk to the vehicle's computer to get it to recognize something is plugged in...it's normally just the act of plugging something into the towing connector that triggers tow mode once you have that module installed and the main computer is programmed to look for it. The OEM module can also monitor the state of the lights in the trailer, or could...I haven't plugged anything into mine yet.
This may be dated, but it used to be only Westphalia was the OEM supplier of the tow package sold in Europe either OEM or as an aftermarket, or RightConnections that had a module that works(ed) in a BMW to enable the full functionality. Personally, I don't mind the look of the US factory hitch option, and it is less expensive and covered by warranty versus aftermarket units. Plus, enables all of the built in stuff automatically. |
10-16-2020, 07:09 AM | #22 | |
Rep 27
