04-28-2020, 09:19 PM | #3 |
Rep 533
04-28-2020, 09:29 PM | #4 |
Rep 494
I just did this myself and it is nice but i have noticed a reduction in power. Anyone else?
2019 BMW X5 40i Phytonic Blue/Tartufo
2016 BMW X3 35i M-Sport, Dinantronics (sold) 2012 BMW X3 28i (sold) |
04-29-2020, 06:31 AM | #5 | |
Rep 109
I have read somewhere (don't have source) that the exhaust flaps are also used to give more performance. I think it has to do with the backpressure which you loose. Which should mean that the turbo's give less of a boost. Maybe that is something you are noticing. |
04-29-2020, 09:04 AM | #6 |
Rep 16
Drives: 2024 X5 M60I Carbon Black
What application do you use?
Pretty cool. What application do you use to open flaps?
04-29-2020, 11:05 AM | #8 |
Rep 3,506
If you feel power loss without measuring it you might have a much larger problem. Exhaust flaps will not impact either way the power of the vehicle due to the design of the actual muffler. You still have CATs and resonator and muffler that is what supplies any sort of back pressure.
2022 M8 Comp Convertible
04-29-2020, 11:07 AM | #9 | |
Rep 3,506
04-29-2020, 11:58 AM | #11 | |
Rep 2,609
ikheetleon218.50 2019x5User146.00 |
03-14-2021, 02:38 PM | #13 |
Rep 2,609
It should be the same for G06 x40i. Carly is not favoured around here, but Bimmerlink has flap control functionality as well.
03-14-2021, 10:13 PM | #14 | |
805
Rep 1,789
In other words, once you set it with Bimmerlink to open the flap and then disconnect the OBD adapter doesn't it revert back to factory defaults after you disconnect the ODB adapter? |
Burnt C6257.50 |
03-15-2021, 08:26 AM | #15 | ||
Rep 2,609
UPDATE: I may be confused about Carly functionality as I don't use it (and I don't use it because there were a large number of reports about, uhm, "optimistic marketing of capabilities" in the past). But permanent flap open is not a coding option, it is rather a real-time control over OBDII. Or the various mechanical methods: fuse pull at the right time, control cable pull at the right time, spring unclip and flap open tie-off.
03-15-2021, 11:36 AM | #17 |
Rep 524
Not that Ive seen. Easiest way to disable permanently is use BimmerLink and obd adapter to open exhaust valve. Then go pull fuse. Done. Now exhaust will always be open, even after restarts, etc., until you put the fuse back in. That's how I did mine. Couple thousand miles now, and valve is still open, and no issues.
03-22-2021, 02:44 PM | #18 |
Rep 903
fyi, you dont need the bimmerlink app or have anyone jump in the trunk to pull a fuse, lol.... you can either remove fused or disconnect the plug at the exhaust when the car is off. (the flap is in the open position when car is off).
I have bimmerlink and was just playing around to see the difference, to find out that flap is open when the car is off. flaps closes when car starts. I believe it opens up again while driving up to certain mph. Also, dont know much difference with the flap open. it might be slightly louder at startup, thats about it. |
03-22-2021, 07:08 PM | #19 |
Rep 11
I noticed when you remote start the vehicle both exhaust tips are open and there is quite a difference in sound. As opposed to starting the vehicle inside using the push button as this only opens the one flap.
02-04-2022, 02:52 PM | #20 | |
Rep 106
Thanks
2022 White X5 Xdrive40i M-Sport
02-04-2022, 06:00 PM | #21 | |
Rep 6,789
FWIW, a restriction in the airflow causes what exhaust volume there is to flow faster. Opening up the flap helps on wide open throttle, but it will get there on its own once it's warmed up and you trounce on it. Look up Bernoulli’s Principle. So, the initial spool up of the turbo should help with it closed until it starts to impact the ability of the gasses to get expelled by the increased friction...that's when the flap opens. Personally, I prefer it to be quiet, especially on a long trip! To each their own. |
02-05-2022, 08:25 AM | #22 | |
Rep 106
Thank you
