06-21-2020, 10:36 AM | #1 |
Rep 90
2 quick questions
Took delivery of my M50i Friday.
Two quick questions. 1 - my digital keycard works to start the car, but I can’t seem to unlock the doors with it. Is there an option I need to change? 2 - is there a way to control rear climate from the drivers seat? |
06-21-2020, 10:54 AM | #2 |
210
Rep 715
The keycard works on drivers door only, if it's starting vehicle, should work when put near driver's door handle to lock/unlock.
06-21-2020, 11:07 AM | #3 |
147
Rep 313
Yes- press the climate control menu button between the two front climate zone controls. I believe under Heating and ventilation you will see an option for rear controls. It's somewhere in those menus. Pretty self explanatory when you find it.
2023 BMW X7 LCI M60 (On Order) 2020 BMW X7 xdrive40i M Sport Phytonic Blue 2019 BMW X5 xdrive40i Mineral White |
X5 45e1090.50 |
06-21-2020, 11:33 AM | #4 |
Rep 90
I can’t get it, idk. I have held the card literally touching the door. Have to unlock through the app, but the car starts the car perfect.
06-21-2020, 11:49 AM | #5 | |
Rep 296
Drives: M3 Competition (G80)
See if you can search for it or even on youtube. |
06-21-2020, 12:03 PM | #6 | ||
Rep 2,420
I have the card in my wallet as back up when I lose my key. I have never traveled with the cars only. And don't leave it in your car! If somebody finds it they can drive away. |
06-21-2020, 12:06 PM | #7 | |
1164
Rep 1,777
This would have been a particularly good use case for BMW to let you use the voice command to turn on the rear A/C. It would have been a cool party trick and useful since rear passengers, especially guests are wary of playing with your a/c controls and usually don't say anything. |
06-21-2020, 12:12 PM | #8 | ||
Rep 2,420
06-21-2020, 12:39 PM | #9 | |
1164
Rep 1,777
For having one of the most complicated A/C systems on the planet, BMW really could have made a dedicated button to turn on and off the rear seat climate controls. Very rarely will a friend or a guest come into my car, already overwhelmed by how nice and clean I keep it and reach the center control stack to mess with the climate settings, but I want them to be comfortable since I paid for those options. It would be so simple to be able to control the rear settings from the front, like how you can now adjust the passenger seat position from the driver's seat controls... |
X5 45e1090.50 |
06-21-2020, 12:46 PM | #10 | ||
Rep 2,420
I am also really missing the red-blue wheel to directly change temperature. Such a hassle now. |
thereef5101164.00 |
06-21-2020, 01:43 PM | #11 |
1164
Rep 1,777
you can turn on the A/C for the front driver/passenger by saying something dumb like 'hey bmw i'm hot/cold' and you can change the temperature via voice command, but you can't turn on the rear a/c with it.
Although I haven't tried the voice command "hey bmw synchronize the A/C". Maybe that would work? I'll try it I wish they had a published list of voice commands and senarios we could refer to |
X5 45e1090.50 |
06-21-2020, 01:58 PM | #12 |
Rep 91
Rear temp cannot be controlled from the front climate controls except by using "sync" option from the A/C menu or by saying "hey bmw sync A/C" or "hey bmw sync climate (control)"
I think (not sure) the help menu in idrive has list of commands (or at least a majority of the commonly used ones) for BMW voice assistant. Maybe (hope) as part of MY2021 they also give us option for rear AC control by voice along with the other new voice commands which will be available in MY2021. |
thereef5101164.00 |
06-21-2020, 03:34 PM | #13 |
Rep 90
Sync button aside, really stinks that there’s not just a simple, 1 button solution to turn off rear climate.
Thanks for the help! It seems one corner of the card works rather than the flat, middle part. Working though! |
06-21-2020, 04:02 PM | #14 | |
1164
Rep 1,777
Anyone know if you can turn on the second row seat heaters with a voice command? |
06-23-2020, 05:35 AM | #15 | |
Rep 2,420
See pictures attached. Verwarming / ventilatie = heating ventilation menu Tweede rij stoelen = second row seats Activateren = first check box activates the system. You can probably assign this to a preset button to turn on and off the rear seat CC The others below sets the temperature left (links) en right (rechts) sync, ... I don't know if this came available with 03/2020 or was already there in 07/2019. |
06-23-2020, 08:03 AM | #16 |
1164
Rep 1,777
Right so we know you can turn on and off the rear climate stuff and control the temps through idrive. What we were saying was having a simple on off physical button would have been way less cumbersome than having to use the either idrive or voice command to turn it on for passengers too inept or meek to fiddle with the controls themselves.
Also there's no way that I have discovered for you to be able to turn on the rear seat heaters from the front. |
X5 45e1090.50 |
06-23-2020, 08:43 AM | #17 | ||
Rep 2,420
I didn't manage to save on off or sync as a preference |
