06-23-2020, 10:24 AM | #1 |
Rep 106
"Trailer Mode" for Non-OEM hitch
Has anyone successfully had their dealer code their vehicle so that "Trailer Mode" shows up in iDrive when they've had a 3rd party hitch installed?
My area dealers wouldn't install anything 3rd party so I went with an independent installer (who did a great job by the way), but that leaves me with a whole lot of beeping and alerts when I'm carrying the bikes. I've got a thread in the Coding forum to ask if anyone there has the coding parameters. |
06-23-2020, 11:29 AM | #2 |
Rep 166
My understanding is you need the trailer tow module for those features.
https://www.newtis.info/tisv2/a/en/g...sav/1VnYlzhFJu |
06-23-2020, 05:18 PM | #3 | |
Rep 810
This is a job best left to dealers. YES it will be expensive, but the electronics and safety systems in these cars are very sophisticated - and its not worth the complications, safety issues, or potential to impact your warranty by attempting to DIY. I had the BMW OEM (after-factory) towing hitch. installed and coded by the dealer - all good. Last edited by James_G0540i; 06-23-2020 at 07:54 PM.. |
JALS26.50 |
01-11-2023, 07:39 AM | #4 |
Rep 81
Drives: 2024 X5 50e M-Sport
I have a 2019 BMW X5 40i with the 8SL option and had a Stealth Hitch installed with the passive harness. This did not require coding but does not integrate into the full iDrive system. I just wish we could get access to the Towing Mode button in iDrive to shut off the backup sensors. The warning sounds are super annoying when using reverse with my bike rack. I don't need any of the other features. In my old Audi I could mute the sensor alarms but I don't see how to do that in the BMW.
01-11-2023, 09:32 AM | #5 |
Unapologetic Tool Hoarder
733
Rep 963
Yes it can be done. It's actually not that hard. Not sure it will help with your bike issue though. The tow mode is activated when you plug a trailer into the trailer/pollack connector and it detects a trailer attached.
This is the writeup I did a while ago for the wife's old X7. https://www.bimmerfest.com/threads/x...-help.1399968/ Another from a member here. https://g05.bimmerpost.com/forums/sh....php?t=1964995 Last edited by weinerbarn; 01-11-2023 at 09:40 AM.. |
Jcit51.00 |
01-11-2023, 12:51 PM | #6 |
Rep 81
With the bike rack there is nothing to plug in to the electrical socket so it would not automatically jump into tow mode. I am ok with manually activating tow mode from iDrive but it is not available in the "settings" screen in my X5 because it did not come with the hitch installed. What I would like to do is activate the "Tow Mode" using the button in iDrive so it would disable the backup sensors when I go in reverse with the bike rack. I think I can do it with Bimmercode but i have not purchased the OBD11 hardware yet. Another option is to simply mute the sensor sounds when in reverse by clicking a button in iDrive but that does not appear possible. I was able to mute sensor alarms in my Q8 on the fly with Audi MMI which made it so much nicer.
01-11-2023, 01:13 PM | #7 | |
733
Rep 963
Jcit51.00 |
01-11-2023, 02:24 PM | #8 | |
Rep 81
Also, in the manual (surprising I actually opened it) it says you can turn off PDC manually at any time by pressing the park assistance button (next to gear shifter) so it looks like it can be done that way. |
rtadams144.50 |
