09-21-2020, 03:44 PM | #1 |
Rep 232
New x5 M50d The last of the DIESELs
Hi
Finally made my decision on my new car, had F15 50D before. I was concerned over the termination of this engine, but I got over this. My car is well loaded Vis Pack Comfort Pack Tech Pack Intergal Active Steering 2 axle sus Tow bar 7 seats Sky Lounge Sun Pro Only done 300 miles in it but seem a real step up in many ways, the tech needs real understanding over F15. Have to say the F15 was a great car, and felt quick, this with all air suspension feels not as planted, but because I tow, its a no brainer to have the air suspension. Thinking of chipping 486 BHP AND 880 nm torque, can i have you experiences and issues please, i am in the UK Also thinking of clear wrap, will it damage the paint when i remove it to sell in 3 years. Unsure this car is a keeper with that engine, it could be a nightmare out of warranty! Advice please on my ideas Attached a pic |
09-21-2020, 04:05 PM | #2 |
10802
Rep 27,595
nice build, congrats on the new ride. Enjoy
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST! Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101 vipfinance@bmwofcamarillo.com for warranties! |
09-21-2020, 04:34 PM | #3 | |
Rep 92
Besides, I drove a Tesla last week. I can honestly say I hated it. Alas, the days of ICE cars are numbered so be glad you have the opportunity to enjoy such a beastie in its prime. You'll have fond memories long after you've forgotten how much it cost. I chipped and DPF-deleted my E60 535d and the difference was incredible. There's obviously a huge temptation to unleash the potential of the M50D but I don't think I'd do it under warrantee. And I certainly wouldn't do it until you've let several guinea pigs go before you and risk their ECUs first. I too would like to put something on the front-end, at least, to protect the body from stone chips etc. Most wraps are removeable but the adhesive is the issue. Be sure to use a quality brand with a 3M (or similar quality) adherence system that's guaranteed to wash of easily after x years under the sun. If you find a good one, do share!
Currently driving 2016 F10 M5 & 2017 G11 730d.
Note: Taxes on vehicles in Ireland are bananas! Previously 2019 G05 X5 M50D, 2016 F36 430d, 2012 F10 520d, 2006 E60 M5, 2005 E60 530D |
09-22-2020, 03:32 AM | #4 | ||
Rep 232
I think I agree with you on the ECU, I suspect any issues with software will be picked up, even if it's removed. I found a place in Preston called Wraps&Tints, they use XPEL Ultimate/Steath, I am worried that whilst I try to protect the paint, the actual damage could be done by the film! Thanks again |
09-22-2020, 06:26 AM | #5 | |||
Rep 92
The process I went through was: Received an OBD scan tool. Used tool to download 'image' of current ECU configuration. This was saved to the tool. Connect tool to my PC using USB & download proprietary file. Send file to supplier via email. Supplier runs config in their master system and tweaks settings with two flavours: Max power and more fuel consumption, More power & less fuel consumption. (Surprise, surprise, I never used the latter!) They send you back, via email, a new file. You reverse the process and save the files to the OBD tool. You can then connect the OBD device to the vehicle again, choose which 'mode' you want and send it to the vehicle. Worryingly, you get flashing indicators, dash lights etc during the process but, everything settles down, the job completes and, after a 'Hail Mary...' try to start it. Mine cane to life and was an absolute animal. Other than the risk of the ECU being fried (lol), there's no reason you couldn't repeat the process but, this time, feed back in the original file -I doubt there's a flashy light to warn mechs that the ECU was written-to. If there is, one would probably want to be forensically looking for it -and possibly only given-away by the time/date not coinciding with/ preceding its factory build date. Paint protection: I just rang Carstyle in Dublin. They're charging €1600 for a protective 'self healing' wrap to (front only) including bonnet, bumper, wheel arches & headlights using a pre-cut system from Premium Shield. Seems crazy money... you'd nearly get a re-spray for that! Info on actual material here: https://premiumshield.com There're obviously lots of crazy people in Ireland though, at time of writing Sept 22, they can't fit me in until the second-week of November!
09-22-2020, 07:02 AM | #6 |
150
Rep 365
The OBD method will not work on a G05. The OBD is locked and whilst you can read files, you cannot write.
The only way of doing things is ECU out on bench mode, although this does not require opening the ECU itself, just cables plugged into the pins. These engines have been remapped for a good five years now with this B57 first appearing in the 2015 7 series. There are plenty of guinea pigs already. A remapped 30d is rapid, a 50d must be bonkers |
09-22-2020, 12:20 PM | #7 | |
Rep 232
09-22-2020, 12:22 PM | #8 | ||||
Rep 232
