      10-11-2020, 07:25 PM   #1
DCC
Drives:
40i Door Sills
Thanks in advance to those who can help me out here.
On a M Sport 40i, the door sill scuff plate is lighted front and back with the M logo.
What does this look like on an X Drive vehicle? Are there door sill scuff plates that light up but show and “X” instead?
2024 M2, 2024 CGT4RS, 2020 M2 CS, 2021 Macan GTS, 2017 Cayenne S, 2002 M Coupe
      10-11-2020, 07:47 PM   #2
Auricom
Auricom's Avatar
Drives: 2020 X5 xDrive40i M Sport
What does this look like on an X Drive vehicle? Are there door sill scuff plates that light up but show and "X" instead?
In regards to 40i, no it lights up "BMW"
There are 9 styles for the illuminated front door mucket/trim and 4 styles for the rear door mucket/trim across X5/6 models.
Front:
1. BMW - xLine models
2. BMW Individual - xLine with Merino
3. /// ///M //// - M Sport
4. /// ///M50i /// - M50i
5. /// ///M50d /// - M50d
6. — X5 ///M —
7. — X5 ///M Competition —
8. — X6 ///M —
9. — X6 ///M Competition —
Rear:
3. /// ///M /// - M Sport
4. — ///M — - X5/6 ///M and Competition models
MystroX56289.50
IFlyX5236.50
      10-12-2020, 06:58 AM   #3
maczrool
Drives: 22 M50i Carbon Black
The BMW ones will light in different colors depending on lighting conditions. I believe it’s orange at night and white during the day. The M Sports do not change color. There is an unused pin on the connector presumably for the unused second color.
      10-12-2020, 10:32 AM   #4
I've Seen Things
I've Seen Things's Avatar
24
Drives: G05 X5 Msport 40i MY2020
Has anyone replaced a front trim - I'm referring to the metal light-up strip?
I'd like to be sure how to do it before I dive in heavy-handed.
      10-12-2020, 10:37 AM   #5
Shawzy44
Shawzy44's Avatar
158
Drives: 2019 BMW X5 40iX
Very easy. They just pry out with a plastic trim tool. Super easy.
I have a complete set of "BMW" trim if anyone is interested from my 2019 X5 40iX.
Shawzy44
2023 BMW X3 M40i
2019 BMW X5 40iX
2019 BMW 440iX M Performance Cabriolet
      10-17-2020, 10:59 AM   #6
littleump
Drives: x5 40i
Are they unmarked as mine are pretty scuffed up , price and postage to uk ?
      10-18-2020, 06:21 AM   #7
maczrool
I replaced my driver’s side front one for about $75 US I believe. It is clear coated, so if you can get it out to work on, you may be able to buff out the scratches depending on severity. I have the original to play with now so I may try it at some point.
      07-13-2021, 02:44 PM   #8
javapro
Generalissimo
javapro's Avatar
Drives: 2024 iX xDrive50 Sport
Front:
6. — X5 ///M —
8. — X6 ///M —
Rear:
What is the part number for the front M Sport one (#3 on your front list above)? I scratched mine up and want to replace it. I took pictures of the part number on it (see attached) but can’t find it anywhere. This is for 2021 X5 45e if it makes any difference.
      07-13-2021, 06:08 PM   #9
Auricom
Auricom's Avatar
Front:
6. — X5 ///M —
8. — X6 ///M —
Rear:
What is the part number for the front M Sport one (#3 on your front list above)? I scratched mine up and want to replace it. I took pictures of the part number on it (see attached) but can't find it anywhere. This is for 2021 X5 45e if it makes any difference.
This is what I have:
For vehicles with
M Sports package ( P337A Yes )
51-47-8-069-271 - Qty : 2
https://www.getbmwparts.com/oem-part...rt-51478069271
      07-13-2021, 08:09 PM   #10
javapro
Generalissimo
javapro's Avatar
For vehicles with
Thank you. What do you mean by quantity of two? It comes as a pair? It is definitely the same one I sent the pictures of - M Sport illuminated logo, right? The description says “Front sill insert, m. Without m model, with m package. Without ambient lighting, with m type.” The "without ambient lighting" part doesn’t apply to M Sport trims, right?
      07-13-2021, 08:42 PM   #11
Auricom
Auricom's Avatar
For vehicles with
Thank you. What do you mean by quantity of two? It comes as a pair? It is definitely the same one I sent the pictures of - M Sport illuminated logo, right? The description says "Front sill insert, m. Without m model, with m package. Without ambient lighting, with m type." The without ambient lighting part doesn't apply to M Sport trims, right?
According to Bimmercat, it comes as a pair. Yes it is exactly the one in the photo you posted. The numbers on the part is missing the 51-47 portion and the 8-069-271 matches exactly.
It's just the insert and not the cover strip which is:
Left - 51477479935
Right - 51477479936
Not sure where they're getting their part description but that is the ONLY M sport sill listed in the parts database and it should light up from ambient lighting unit in the cover strip. Call your dealer part to confirm.
      07-13-2021, 10:14 PM   #12
IFlyX5
IFlyX5's Avatar
Drives: '21 X5 s40i, '22 X5 x45e
Do the door sill scuff plates light up if you have the sDrive (not xDrive)?
2021 G05 X5 s40i Phytonic Blue | Ivory White Vernasca | Anthracite-Brown Poplar Matte Trim
2015 F10 535i M-Sport Space Gray | Black Nappa (Gone)
      07-13-2021, 11:42 PM   #13
javapro
Generalissimo
javapro's Avatar
Front:
6. — X5 ///M —
8. — X6 ///M —
Rear:
Where do you get such nice parts pictures from? Bimmercat?
      07-14-2021, 12:16 AM   #14
javapro
Generalissimo
javapro's Avatar
Left - 51477479935
Right - 51477479936
Thanks for the info. I think the quantities that Bimmercat shows is the total number of that particular part installed in the car (left and right are the same, hence 2) but each part is sold individually. For example, cover strips are listed with the quantity of 1 because left and right are different; clips have 22 because there are 22 of them for the front and rear on the left and right sides.
      07-14-2021, 01:35 AM   #15
Auricom
Auricom's Avatar
All the sill plates should be illuminated. What trim is your sDrive? xLine or M Sport? What interior leather upholstery option did you select - SensaTec, Vernasca or Merino?
Let's say you have a sDrive xLine then your sill plates are No. 3 - BMW
If you have a sDrive xLine with Merino leather then your sill plates are No. 4 - BMW Individual
If sDrive M Sport then it's No. 7 - ///M
If sDrive M Sport with Merino, it's still No. 7 - ///M since M Sport supersedes Individual
      07-14-2021, 01:38 AM   #16
Auricom
Auricom's Avatar
Front:
6. — X5 ///M —
8. — X6 ///M —
Rear:
Ja, yes in Slovenian
      07-14-2021, 08:38 AM   #17
IFlyX5
IFlyX5's Avatar
I have the xLine and Vernasca. The BMW logos on the sill plates do NOT light up when the vehicle is running and/or light is switched on.
      07-14-2021, 09:42 AM   #18
Auricom
Auricom's Avatar
I have the xLine and Vernasca. The BMW logoes on the sill plates do NOT light up when the vehicle is running and/or light is switched on.
Interesting, as I stated in my previous post - that they "should" be illuminated but I wasn't certain that all will. From my experience Individual, M Sport and above are and thank for providing a data point for sDrive xLine owners.
IFlyX5236.50
      07-14-2021, 11:17 AM   #19
IFlyX5
IFlyX5's Avatar
Thank you, Auricom
I will make a separate post to see if this is an undocumented feature
Auricom4361.50
