08-23-2021, 09:54 PM | #1 |
Rep 109
Show me your baby seats!
I'm looking for options on a convertible car seat!
I've been recommended the Diono 3qxt, but I know its so tall that my front passenger seat would have to be pushed forward a bit and limit any reclining. Pics please!! |
08-23-2021, 11:10 PM | #2 | |
Rep 641
We have it behind the passenger seat, and yes, it does limit how far back the passenger can go. Not ideal, but it's also not that bad. About 2 weeks ago for a longer drive out of town, we moved the seat to the center which gave my wife more room to move the seat back. Somewhat related - just a reminder that the LATCH system is not supposed to be used when the baby seat is in the center in the x5. I know it seems stupid, but I see no reason to take any chances when it comes to the baby. |
08-24-2021, 10:07 AM | #4 |
1044
Rep 1,943
We used the Nuna Exec. When it's in the rear facing configuration it does limit the seat in front. My wife, at 5'-6" was still able to sit comfortably in the passenger seat with the exec behind it. I was also able to fit 3 execs across the back seat, which was a nice surprise. My 6 year old and 2 year old both sit in one. Now both forward facing so no longer an issue with the front seats being restricted.
08-24-2021, 10:22 AM | #5 |
Rep 641
Not sure how helpful these are, but I took a picture from each door.
Passenger Side Rear, where we have the baby seat: There's a gap of about 1.5 inches between the seat by the USB charger, and the baby seat Driver's Side Rear: Passenger Seat: My wife and I are both 5 '10", and we both find it comfortable enough with the way it's setup. As mentioned before, though, for longer trips we move the seat to the center so the seat can go further back. Driver's Seat: |
hiki08173.50 |
08-24-2021, 10:30 AM | #6 | ||
301
Rep 327
Which begs the question, the X5 isn't considered to be a small vehicle by most people, yet a baby seat doesn't fit without the driver or front passenger comprising their position. So what do people with smaller cars (many cars on the road are smaller then the X5) and babies do?? Had I known this in advance, I would have really considered the X7 M50i. |
08-24-2021, 10:44 AM | #7 | |
Rep 641
Also, I really hope this doesn't come across the wrong way. I swear I'm not trying to be condescending or anything like that - In regards to the latch system, after reading about it a bunch, I found that in order for you to be able to use it from the middle seat, both the baby seat manual AND the car manual have to say it's okay to do. In all likelihood it's probably safe, but my understanding is that unless it's specifically mentioned, it means that the seat was not tested for that situation. I was also concerned about the difference in safety when using the latch system vs. the seatbelt to hold the base down, but everything I've read indicates that there is effectively no difference, it's simply a matter of convenience. EDIT: Oh and forgot to mention, congrats on the baby! |
08-24-2021, 12:02 PM | #9 |
Rep 25
If you are using the middle seat, you should NOT be using the latches on the outboard seats. They are not designed to take a load at those angles. You should instead use the seatbelt to secure the car seat or base. Latches were designed to be easier to use not stronger; they are actually substantially weaker than seatbelts. Latch only has a 65lb rear facing and 69lb forward facing combined weight limits. Seatbelts can handle handle much much more than that.
08-24-2021, 12:06 PM | #10 |
20
Rep 32
Is there enough room to have 2 car seats and a normal adult human in the middle?
I am about to take delivery of a 2022 and with 2 kids, I'm starting to worry that there won't be room for a third person in the middle of the back seat. |
08-24-2021, 12:13 PM | #11 |
1044
Rep 1,943
What I did is put the car seats to one side of the car. So you have one installed in the middle (as stated above, using seat belts, not latch system because of safety) and one behind the passenger seat. This left the seat behind the driver seat open. This was plenty of room for Nana to sit there. If you put the seats on the outside and leave the middle open, there could be enough room, however, it won't be comfortable and it will be challenging to maneuver around the car seats to get to the middle seat.
Greyback19.50 |
08-24-2021, 12:14 PM | #12 |
Rep 641
Definitely possible, but I would guess not comfortable at all. With two kids I would at least consider the x7 since that would provide more room in the 2nd row.
08-24-2021, 12:23 PM | #13 | |
Rep 641
08-24-2021, 12:27 PM | #14 |
Rep 426
I can show my beer basket.
Off topic, but has to be said. |
YuicyYumboYack507.00 |
08-24-2021, 01:48 PM | #15 |
Rep 73
Does his middle seat of latches? There are some makes/models that do have latches in the middle seat, so maybe that's why he's prefers to use them. However if it doesn't, then it is NOT recommended to use them as Watboy said.
08-24-2021, 02:40 PM | #16 | |
Rep 641
I absolutely don't want to be that person telling another parent how to do anything, it's already hard enough raising children, but I do hope that anyone who was considering using the latches in the center reconsiders. No matter how small of a chance something bad happens, it just doesn't seem worth it. |
08-24-2021, 02:46 PM | #18 |
Rep 73
We have a Graco 4Ever 4-in-one, but no pictures yet since we don't have the car yet. It is pretty wide. We did bring the carseat during our testdrive to see how it would fit, both for the front passenger as well as seating 2 adults in the rear. My wife and I are 5'5" and 5'7" though so not tall at all, and average build. We had plenty of room for front passenger, and also ok room seating 2 adults in the back with the carseat. We also brought our stroller to see how much of the cargo area it would take up.
08-24-2021, 02:50 PM | #19 | |
301
Rep 327
I do regret my wife not getting the bigger X7 however. Compared to the rear seat space of my Raptor, the X5 flat out sucks. First world problem I know. |
08-24-2021, 03:00 PM | #20 | |
Rep 641
I think your thoughts on the room in the back are totally fair. I believe the x5 is near the bottom in terms of rear leg room compared to other similar cars. Still, both my wife and I got used to it quickly. For one, we're never back there. And two, the passenger seat is still comfortable. |
Russ103300.50 |
08-24-2021, 09:27 PM | #21 | |
Rep 502
Also while the X5's rear leg room is disappointing for its size, it does have two benefits in my experience. One, it is wider than most cars so an adult can sit in the middle with two car seats in place. Two, the tall and boxy greenhouse plus lack of plastic clutter in the low dash area enables me to pull my seat more forward than any other car, helping to appropriate more space for the rear. Boxy shape and tall roofline also makes it easy to put/remove the kids in/from the rear facing car seat...
BMW CCA Member ID: 592739
08-24-2021, 09:37 PM | #22 |
Rep 52
I have the Nuna Rava (rear facing) on the passenger side and a Nuna Pipa Lite in the middle seat. My wife is able to sit comfortably in the 2nd row w/ them. Front passenger also has decent space.
