10-12-2021, 04:01 PM | #23 |
Self-Deprecating Narcissist
7266
Rep 6,561
Correct; I mentioned the release for NAR here:
https://g05.bimmerpost.com/forums/sh...7&postcount=41 Essentially all this means is that it will operate as closer to how it has been advertised originally with not much else worth talking about.
10-12-2021, 05:40 PM | #24 |
Rep 6,797
The press release says the s/w update will become available in GERMANY on the release date, with other countries to follow. From previous history, it's likely to be months before it shows up in the USA, and then, it doesn't happen immediately to all at once.
As was mentioned, once it IS available, the fastest way to get the update is to download it to your phone (WiFi is probably the faster way, or cellular if you don't mind the volume of the data), and then have the phone transfer it to the X5...while the X5 will eventually get the update OTA, it will take MUCH longer (many days, potentially) to get it in the vehicle versus getting it onto the phone first. Once it's in the phone, it will transfer when you tell it to while in the vehicle in less than 10-minutes or so if I remember correctly, then once you start the updating process, that may take another 20-minutes. Once it reaches a certain point, you an exit the vehicle, so you don't have to babysit it the entire time. OTA updates seem to be about one cycle (3-months or so) behind what's available at the dealers. OTA does not get all of the updates that the dealer gets. |
Wait What?421.00 |
10-12-2021, 06:03 PM | #25 |
Rep 8,687
Drives: eVeRyOnE mAD!
my vehicle is currently in service to formally diagnose the tailgate issue. what are the chances they'll do the 07/2021 update while it's there?
10-12-2021, 06:10 PM | #26 |
7266
Rep 6,561
The dealer will not install an update unless told to by field rep. Field rep will not sign off unless you have an actual issue or glitch. I have this issue currently because my vehicles are stored in a temperature controlled garage and there isn't any service or signal. I miss a great deal of updates and BMW tells me speak to dealer; dealer tells me it is an OTA update that will be sent to me. BMW then states that if one misses the OTA update the dealer has to update the vehicle but then the dealership states they're not able to unless BMW tells them to. BMW will not tell them to update unless there is an issue, conflict or glitch in operation. They will not update just for the sake of being current; which I feel is ridiculous because that is the very basis for OTA... to be current. In the end it is a lot of finger pointing not finger clicking allow me to update. Just another reason why the BMW of yesteryear were better. Less is more.
10-12-2021, 06:14 PM | #27 | |
Rep 6,797
10-12-2021, 10:33 PM | #30 |
Rep 842
@iconoclast The solution to your dilemma seems to by driving your BMW more frequently
2021 G05 X5 ///M50i / Phytonic Blue / Cognac Vernasca
iStep 03/2023.50 |
iconoclast7265.50 |
10-13-2021, 08:23 AM | #31 | |
7266
Rep 6,561
Too many cars; too little time.
10-13-2021, 08:34 AM | #32 | |
Rep 802
Haven't noticed anything exciting about the new version yet. |
10-13-2021, 09:06 AM | #33 |
Rep 8,687
i'll specifically be testing out the 'improved' steering intervention which i disabled very early on as there were too many false interventions.
10-13-2021, 10:25 AM | #34 |
Rep 117
I have been running 07-21.40 for a while now. Works well. Dealer installed it a few months back. I haven't driven it much so can not comment on steering but I have a happy wife.. Which = happy life.
Apple carplay still needs to press play on Spotify. |
SmartSaves460.50 |
10-13-2021, 01:50 PM | #35 |
Rep 153
Last upgrade ended up closing out all of my coding. This update was summer of 2021. Does anyone know if this will happen with this software update as well?
10-13-2021, 01:51 PM | #36 |
Rep 599
10-13-2021, 01:51 PM | #37 |
Rep 8,687
very likely some or all previous coding will be erased. hard to know exactly depending on which modules are involved in the update.
10-13-2021, 03:41 PM | #40 |
Rep 528
I did the same and it saved my butt this morning on my way to work when some moron in my blind spot decided to come into my lane. I had noticed earlier that the same vehicle was swerving quite a bit. Drunk or texting is my guess, most likely the latter as he/she was driving a work van and it was at 6AM...
Wait What?421.00 |
10-13-2021, 03:53 PM | #41 | |
Rep 503
john1200c238.50 |
10-13-2021, 04:29 PM | #42 |
Rep 6,797
Of the two OTA updates I've received for my X5, both of them were flagged in the app. I do periodically tell iDrive to check for new software, and if the vehicle says there's an update, the app does too and vice-versa. Also note that there was at least one update that never was flagged for my vehicle...it may be that the modules and options that I have would not have been enhanced, so it was never offered. IOW, not every vehicle may get every update. I asked my dealer about that, and he said my vehicle may not have 'needed' that update. Don't' know how true that is.
Note, it took a long time between when the first people said they were getting it before it showed up on mine...it's been discussed before, but nobody seems to know the rationale and timing of when any one individual vehicle might get an update. BMW has said that Germany would be the first to get the latest (this time, and probably previously, but I don't remember) and that it would be rolled out to other markets over time...again, they didn't say when or provide any sort of a schedule. |
SmartSaves460.50 iconoclast7265.50 |
10-13-2021, 07:45 PM | #43 |
Rep 209
So i've been having issues with the BMW app and my car since July. I just checked and i have sw version 07 21 40.
Interestingly, the BMW app does not update and hasn't since 7/28. When I open the app, it says updating vehicle status then goes to updated from vehicle 7/28/21. I've rebooted idrive, deleted/reinstalled the app several times. Call the genius who gave me a ticket# and said someone would call me back - that was a month ago. Took the car into the dealer, they couldn't figure anything out either. Interestingly - I can lock the car/honk/climatize - no issues. I can't get 3d cameras to work - says to check data privacy settings in the car. When I go to the data privacy setting in idrive, it is literally empty/blank, if i select "Data Privacy" - there is no menu below it. I think this damn sw upgrade hosed me up and BMW doesn't have a clue. If anyone has input LMK please! Thankfully - I can still climatize as the days get cooler up here in the NE. Aceman |
10-13-2021, 08:11 PM | #44 |
Rep 8,687
