11-28-2021, 07:17 PM | #1 |
Rep 2,069
iDrive no longer showing 'recommended' tyre pressures
For some reason, recently my car has stopped showing the 'recommended tyre pressure', but still shows the actual pressures and temperatures just fine.
I haven't had a software update recently, so I can't attribute it to that. Anyone else experienced the same thing? |
11-28-2021, 08:32 PM | #2 | |
Rep 191
11-29-2021, 12:30 PM | #3 | |
Rep 2,069
I then remembered that I coded the tyre pressure display 'widget' with Bimmercode not long ago. So I 'uncoded' that and the recommended pressure info came back. |
11-29-2021, 06:09 PM | #4 | ||
Rep 2,609
11-29-2021, 10:04 PM | #5 |
237
Rep 372
What "widget" are you talking about? The one where you hit the BC button on the stalk and it shows the tire reading/temp on the Infotainment screen?
2021 G05 X5 s40i Phytonic Blue | Ivory White Vernasca | Anthracite-Brown Poplar Matte Trim
2015 F10 535i M-Sport Space Gray | Black Nappa (Gone) |
11-30-2021, 10:41 AM | #6 | |
Rep 2,069
11-30-2021, 10:42 AM | #7 |
Rep 2,069
Yes. It shows on the dash with the speedo, and also offers a widget on the main screen home screen, like the weather or power/torque widgets that you can choose from.
11-30-2021, 10:57 AM | #8 | |
Rep 191
11-30-2021, 11:18 AM | #9 | ||
Rep 2,609
maher116.00 |
12-01-2021, 09:18 PM | #10 |
237
Rep 372
Thanks, I have to check to see if mine still shows the recommended tire pressure tomorrow and report back.
ATLGeek00724.00 |
12-02-2021, 09:05 PM | #11 |
237
Rep 372
No dice. It no longer shows the recommended pressure.
12-03-2021, 02:37 AM | #12 |
Rep 2,069
12-03-2021, 06:59 AM | #13 |
Self-Deprecating Narcissist
7263
Rep 6,561
If you are in "Winter Tires" or "Other" mode it will not show the recommended pressures only the actual pressure/temp.
12-03-2021, 07:09 AM | #14 | |
Rep 2,069
The recommended pressures returned immediately when I un-coded the widget (I did not make any changes to the tyre type at this point). As noted by Lexx, I may have got the same result with an idrive reboot but I did not try that first. |
12-03-2021, 09:36 AM | #15 |
237
Rep 372
It is Summer tires.
12-03-2021, 09:37 AM | #16 |
237
Rep 372
I have not. Will try it this afternoon when I get a chance and report back.
12-04-2021, 12:44 PM | #17 |
237
Rep 372
mobilejo
I can confirm that rebooting the iDrive does not bring back recommended tire pressure. I tried rebooting 3 times and even let the car sleep. No dice. But myBMW app is still showing the recommended pressure so I am just going to leave everything as is.
mobilejo1110.00 |
12-05-2021, 12:14 PM | #18 | |
Rep 2,609
Also, can you please post a screenshot of the myBMW app showing tire pressures and recommended tire pressures. My setup doesn't show that anywhere in the myBMW app (or the old Connected app), but it could be an iDrive or car build version thing.
12-05-2021, 04:42 PM | #19 |
Rep 2,069
Good to know. I will still try mine again next time I'm coding something, and update if I can get the recommended pressures to display while the widget is coded to be on.
12-05-2021, 04:44 PM | #20 | |
Rep 2,069
12-05-2021, 05:37 PM | #21 | ||
Rep 2,609
12-05-2021, 06:53 PM | #22 | |
237
Rep 372
Here is what myBMW shows. Delving further into the TIRES link shows each tire and its current pressure.
