12-02-2021, 07:15 AM | #1 |
Rep 194
Right side mirror not tilting in Reverse
I have yet to figure out the logic here but my right side mirror does not tilt down when I reverse... It was working just fine until now.
Am I missing a setting somewhere ? |
12-02-2021, 07:18 AM | #2 |
Rep 15
The driver/passenger mirror adjustment switch toggles the tilt on and off. Slide it to driver and you will be set
Consuldean78.50 |
12-02-2021, 11:18 PM | #4 |
Laker
38
Rep 116
When in reverse, manully move the mirror to point down. It retains the last set downward position.
Consuldean78.50 Silver.Solid116.00 |
12-03-2021, 03:04 AM | #5 |
Rep 194
12-03-2021, 04:31 AM | #6 |
Rep 253
12-03-2021, 09:54 AM | #7 |
237
Rep 372
Can you set both mirrors (driver and passenger) to tilt down, not just passenger side?
2021 G05 X5 s40i Phytonic Blue | Ivory White Vernasca | Anthracite-Brown Poplar Matte Trim
2015 F10 535i M-Sport Space Gray | Black Nappa (Gone) |
12-03-2021, 04:29 PM | #8 | ||
Rep 8,682
Drives: eVeRyOnE mAD!
we've had bimmers since 2008, and the curb monitor tilt value could never be manually set. what I have noticed with iDrive 7 is that the amount of tilt is way too low. our previous MY17 535i with iDrive 6 had an acceptable amount of tilt.
12-03-2021, 09:34 PM | #10 |
Rep 8,682
simple. It's in the manual.
ACTIVATE: switch to driver side (left) DEACTIVATE: switch to passenger side (right) lake_eleven Consuldean there's no way to set or program the mirror tilt. when you're in reverse with the curb monitor ACTIVATED, the switch is to the left, so can't adjust the passenger side mirror. you then flip the switch to the right to adjust the passenger side mirror, but in doing so, you've DEACTIVATED the curb monitor. you're simply just adjusting the side mirror manually, but there's no way it'll 'retain' that mirror position because the curb monitor is deactivated. the thread below has some history about the curb monitor feature: How to turn off lowering mirror while backing up https://g05.bimmerpost.com/forums/sh....php?t=1642169 |
12-04-2021, 12:01 PM | #11 | |
237
Rep 372
nZtiZia4646.00 |
12-04-2021, 12:06 PM | #12 |
Rep 8,682
60% is perfect for me, too, and that's a great idea to be able to code the driver side mirror as well! feed it back to BimmerCode as a feature request
