12-02-2021, 01:27 PM | #1 |
Rep 8
Ambient Light Help - Blown led?
Hi All. Need some help if anyone has had experience with this. I replaced the center console trim piece because of a nastily scratch on it. Plugged everything back in and noticed the left side LED flickered green than never came on again.
I ordered a new LED thinking it blue. I installed it and still nothing. I looked at the harness and don't see any pinched wires. Is each LED controlled by a module of something? I doubt a brand new LED would be bad. Interestingly, I plugged both the new LED and Old LED on the right side and they wouldn't light there either. I'm at a loss at what could be going on. Figured I'd try here first if anyone has ever encountered this. Any ideas? Thanks Guys. |
12-03-2021, 05:06 PM | #2 |
Rep 602
I’m sure you can attach a current limited power supply to one of your suspect LED modules to see if you get any light. That would narrow it down. Seems like there should be 4 maybe 5 pins on the connector for the LED strips, RGB and maybe W plus ground. Can you take a picture of the connector for the LED strip?
Also, have you tried going through all the colors options in iDrive, not just the blue? |
12-03-2021, 09:42 PM | #3 |
Rep 8
Thanks for the reco. I tried plugging in the new LED to the other working side before and it wouldn't light. Also tried cycling through the different colors and got the same. I'll snap a pic of the connector next time I'm out there. It think it was 3 pin connector. Thanks again for tips.
12-04-2021, 05:55 AM | #4 | |
Rep 602
12-04-2021, 12:54 PM | #5 |
237
Rep 372
Did you try plugging in the old LED on the left side to see if it is working? That would narrow down to the new LED being bad both times. I know you mentioned plugging in both old/new LED on the right, but try the left side.
2021 G05 X5 s40i Phytonic Blue | Ivory White Vernasca | Anthracite-Brown Poplar Matte Trim
2015 F10 535i M-Sport Space Gray | Black Nappa (Gone) |
12-05-2021, 12:07 PM | #6 |
Rep 602
It’s a little hard to follow but I believe the poster had both old and new on BOTH sides already.
