04-22-2019, 10:29 AM | #1 |
Rep 88
Auto detected speed limit cruise control
I thought I remembered reading in the manual that the camera system can recognize speed limit signs and if you are using cruise control it will offer the option to adjust to the new posted speed limit.
Did I imagine this feature? If not how do you activate it? |
04-22-2019, 10:31 AM | #2 |
Rep 790
Probably not available in the US market would be my guess. I've never seen the option anywhere and it is more than happy to keep me at cruise at 80 in a 65 with no complaints.
- Scott
Current Cars: 2019 X5 xDrive40i M-Sport, 2018 Camaro ZL1 Past BMWs: '16 528i, '00 M-Coupe, '14 X1 sDrive28i, '00 740iL, '02 325i, '99 M-Coupe, '00 323Ci, '79 323i, '83 320i |
04-22-2019, 10:41 AM | #3 |
Rep 3,507
EU product at this time. I also read that EU might be trying to make it a law to have vehicles adjust based on sign and make in mandatory.
2022 M8 Comp Convertible
04-22-2019, 02:59 PM | #4 |
Rep 29
The X5 does have this feature. I can't remember if there is a setting that I need to turn on, but when on cruise control and the speed limit changes, I got a "SET" icon on my HUD and I can press the SET button on the steering wheel to have the cruise speed adjusted accordingly.
04-22-2019, 03:01 PM | #5 | |
Rep 3,507
04-22-2019, 03:06 PM | #6 | ||
Rep 29
04-22-2019, 03:37 PM | #7 | |
13244
Rep 19,751
You aren’t referring to the manual speed limiter function are you? That is not attached to the cruise control. |
Tenac4538.50 |
04-22-2019, 04:00 PM | #8 | |||
Rep 6,121
04-22-2019, 04:22 PM | #9 |
Rep 3,507
Yeah I have seen this but no adjustment option. I can't remember if I was reading or watching something like Top Gear when they where talking about EU having auto makers auto adjust to keep people from speeding... I doubt that is anywhere near being in affect but was assuming the OP was asking about the auto adjustments.
04-22-2019, 04:51 PM | #10 | |
13244
Rep 19,751
I like how it reads the speed limit signs and posts them in the HUD and flashes when there is a change but not sure I would want anything to automatically happen especially if you can't program it to be limit + x mph. |
04-22-2019, 04:53 PM | #11 | |
Rep 252
it then brings up a set option on the HUD when the speed limit changes. pressing set will change your max speed when using cruise control. at least it does for me. i am on version 2018.11.49 Australia. |
04-23-2019, 02:39 AM | #12 | |
Guest
Rep n/a
Drives:
Driver Assistance Systems - Section 7.3: https://g05.bimmerpost.com/forums/sh....php?t=1563063 |
04-23-2019, 07:59 AM | #13 |
Rep 6,121
ok guys I figured it out last night. I think BMW should've named their settings better because it was an option I didn't expect.
go to display, speed limit assist and set the detect option to manual then it will prompt you with the set button when the speed limit changes.
04-23-2019, 08:53 AM | #14 | |
Rep 3,507
04-23-2019, 09:01 AM | #15 | |
Rep 5,323
I tend to set my ACC at least 6+mph above the speed limit so not sure the feature will ever help me? I had a similar system with Audi and never found it useful. |
AndroidRobot4331.50 |
04-23-2019, 09:28 AM | #16 | |
Rep 6,121
the Audi one had a tolerance of +/- 5 or 10mph which was nice because it would auto adjust (no input from you needed) so for work zones that helped instead of hitting your brakes then adjusting back, otherwise I agree
04-23-2019, 11:14 AM | #17 | |
Rep 430
I guess Audi was smarter "Techwise". They also have Smart City Traffic Lights maneuverability. It would slow down your car to adjust with the upcoming Traffic Lights on your way to save some gas. If the light is about to turn Red, Audi would slow down automatically and vice versa. But that feature works only in Smart Cities like Las Vegas, and Frisco, TX. Probably more are adding up. It probably requires the lights connected to the internet or some traffic jam assisting servers. I wonder how other car makers would implement and use it. Don't know if a software update only would do it or it needs more harware?! |
04-23-2019, 12:01 PM | #18 | |
Rep 6,121
08-13-2019, 12:52 AM | #20 |
21
Rep 45
I live in Germany. Here automatic adopt is available for G05. It also adapts pro active to reach speed wenn limit starts.. Braking and accelerating is smooth most of the times.. It uses a combination of nav database and camera but the database needs improvement.. Will do so over time.
Set speed can be preselected by +/- 15 km/h (about 10 mph) In the Netherlands automatic adopt is not available, it then switches to "set manually" at the border.. |
08-13-2019, 08:09 AM | #21 |
Rep 4,503
Drives: 2022 iX xDrive50, DGM
BMW's approach to the automatic limit is better than Audi's IMO - my Q7 is constantly braking (sometimes hard) when passing an inactive school zone, or misreading an access road by the Interstate (more alarming), or setting the speed for trucks, or just interpreting a hand-lettered work zone speed in some goofy way (80 for 60, for example). You could set it plus or minus over or under, but would much rather have a manual option.
08-14-2019, 02:58 AM | #22 | |
Rep 285
