08-14-2019, 07:10 AM | #1 |
Rep 22
Cigarette lighter socket Dash Cam
The post refers to UK, but as my new X5 is built in Spartanburg maybe the folks in the States have a similar problem.
Having had a Nextbase dash cam in my other car I thought I would choose this again as it has been a reliable model and does what it says on the tin, for a reasonable price £50. So fitted it to the X5 and neatly tucked the wire behind the trim down to the cig lighter, using this rather than hard wire, only to find that the plug doesn't fit evenly, you have to move it around, and its a tight fit, and will only power up if I press and hold it at a certain angle. So not plug and forget. So my question is, are there American spec cig lighters that get fitted to European models ? are there generic spec holders or should it just be used for a cigarette lighter ? Anyone else had this problem ? |
08-14-2019, 07:49 AM | #2 |
Retired soccer mom
252
Rep 937
Drives: x5 40i 2019
Garage List 1998 Jeep Cherokee ... [0.00]
2011 Toyota Highlander [0.00] 1998 Plymouth voyager [0.00] 2019 X5 40i [0.00] |
Yup. Apparently the X5 has slighter deeper than normal sockets, so a lot of them don’t work.
There was a post back in May with several suggestions on how to fix this. I bought a dash cam also. I used the rear socket to add my own socket extension with two 12-volt sockets and two USB. It was one I already had and works in the rear BMW socket, thankfully. I didn’t hide the wires on the dash, but ran the cord to the rear socket and tucked the wires under the floor mats. Mine also has a rear camera, so running all those cords required an extension I bought on amazon. I know folks are aghast at the wires showing, but I wanted to test the dash cam before doing anything permanent. It is a Crosstour dashcam and it works great, and the wires don’t bother me and make it easier to remove the dashcam when I want to change the SD card. |
phillydilles74.00 |
08-16-2019, 08:01 AM | #3 |
Rep 22
Solution
so the solution to the plug supplied with the Nextbase Dash cams is to file off the round edges half way up the plug so you have a straight line then it will sit in neatly and connect.
08-16-2019, 02:49 PM | #4 |
Rep 1,448
See adapters recommended it RD threads
2015 BMW X5 xDrive 50i/XL/CW/DA+/EP/LP/FVS retired; 2008 X5 4.8i; 2012 X5 5.0i retired, 2004 X5 4.4i retired R360c + EL, V1G2 + V1Driver, Uniden R8 |
06-21-2020, 06:03 AM | #5 |
PANIC!
482
Rep 823
I just installed my NextBase dash cam (which is better than the Blackvue imo), and after spending a few back-bending hours neatly tucking the wires behind various headliners and pillars, I discovered that the darn thing wouldn't turn on after plugging it into the 12 Volt cigarette lighter adapter underneath the rear seat climate control.
At first I thought my old camera had died, but then I plugged it in to a USB port and it came alive. My next thought was that there was something wrong with the 12 V power, but the front port near the cup holder also didn't work. I was stumped, then I found this thread. The plug fit in perfectly as far as I could tell, but I guess it wasn't enough as someone with the same cam also had issues. Before I file the edges of the plug with a Drexel, I purchased various 12 V plug adapters, that I can plug the OE plug in to. |
06-21-2020, 07:15 AM | #6 | |
147
Rep 313
https://g07.bimmerpost.com/forums/sh....php?t=1651070
2023 BMW X7 LCI M60 (On Order) 2020 BMW X7 xdrive40i M Sport Phytonic Blue 2019 BMW X5 xdrive40i Mineral White |
06-21-2020, 08:40 PM | #8 |
147
Rep 313
No splicing involved. You literally stick a wire into the back of a connector. You can remove it and it looks like you were never there.
