06-16-2019, 01:12 PM | #1 |
Rep 5,446
PSA: Check your door strike bolts mine were loose!
So, my wife told me her door wasn't shutting right, was sticking out a bit further than it used to when closed.
Took a look and sure enough, sticking out like 1/8-1/4 further than it should be to be flush. I check the strike and it is loose, bolts I can turn by hand they are so loose and I can see where the strike used to be as it had moved, adjusted torqued and all good. Check the rest, rear drivers was far from tight but not as loose, passenger side also not tight but not bad, had to re-torque them all though, none were properly tightened.
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
06-16-2019, 01:19 PM | #2 |
Rep 2,609
What's the torque and should Loctite or equivalent be used?
06-16-2019, 03:26 PM | #3 | |
Rep 4,551
I'd report it to dealer so they can advise BMWNA.
2023 840GC | 2021 740i | 2019 X3
06-16-2019, 03:54 PM | #4 |
Rep 5,319
06-16-2019, 05:12 PM | #6 | |
Rep 2,609
06-16-2019, 05:27 PM | #7 | ||
Rep 4,551
06-16-2019, 06:02 PM | #8 | |
Rep 5,446
Dealer has never worked on the car, except for updating the software they first day they had it, nothing else I know of - certainly is possible the door wasn't flush when it arrived and they adjusted and did not torque.
06-16-2019, 08:48 PM | #10 |
Rep 978
Rob - Mine was built within 5 days of yours. Just went out and checked with a Torx... all four door's screws did not budge. I'm not sure could have loosened them if I tried... They we absolutely locked in place.
06-17-2019, 09:24 AM | #11 |
1051
Rep 1,951
I'd imagine these bolts would have some sort of thread locker on them - loctite blue or maybe even red?
