      08-20-2023, 12:35 PM   #1
printemps2001
Drives: '22 Alpina B8; '19 E450 wagon
Location: Gone: '18 Alpina B7; '16 S550; '13 S550; '14 E350 wagon; '12 E550; '08 997 C4S
Alpina 20" for winter on X5
I am expecting my 2024 X5 50e any week now and need some advice on winter wheels. I have an extra set of 20" Alpina 20 spokes which I used one season on my 2022 B8. I would like to use them on the X5. Since I am buying the PHEV, it does not have a staggered setup. However, I know there are myriad wheel choices (staggered and non for the various flavors of X5). So my question is whether the offsets will fit the X5. If not, can I buy spacers to make them work? If so, any recommendations? I have bought spacers directly from Porsche, but have not seen that BMW sells them directly.
The wheels are genuine, bought direct from Alpina in Buchloe, Classic Forged CS17 sized 8.5Jx20 ET28 and 10Jx20 ET44.
Any perspective would be appreciated.
      08-21-2023, 07:56 AM   #2
PNWM50I
PNWM50I's Avatar
472
Drives: 21' x5 M50i
Those offsets should work. I am running offsets of 22 front and 23 rear for 22inch rims at 10.5 width front and 11.5 rear. Your fronts should b be ok and the rears might need spacers. What I would want to know is if the rims and tires are load rated to carry the weight of your vehicle.
Bolt pattern will also need to be 5x112 unless you get adapters.I think the bolt pattern on the CS17s is 5x120?
      08-22-2023, 01:51 PM   #3
printemps2001
Very helpful, thanks. Bolt pattern is 5x112. Tires are XL load rated. I did not know wheels had a load rating. Looks like the X5 is about 600 lbs heavier than the B8, so will check on that. Thanks again.
      04-09-2024, 10:13 AM   #4
PJ///M
PJ///M's Avatar
Drives: 2024 BMW X5 G05 LCI
2024 X5 G05 LCI  [0.00]
Hi, so did you ever mount your Alpina’s on the X5? Any pics? Weight was okay? Decide to go with spacers? I’m thinking of doing the same.
Any advice would be appreciated!
