2010 2011 BMW 5 Series Forum F10 Clunking when braking slotted rotors. |
03-21-2024, 08:57 AM | #1 |
Rep 216
When braking my f10 550xi I can hear a clunking sound as if the calipers are clamping onto the rotors and I feel it over the steering wheel. Ive bled the brakes several times. Anyone had this happen after swapping over to slotted and drilled rotors?
03-21-2024, 12:07 PM | #2 |
Rep 2,595
Thrust arm bushings going bad?
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial |
poverty.f1078.00 |
04-14-2024, 04:11 PM | #3 |
DIY Mechanic
78
Rep 130
Drives: 2012 BMW 535i xDrive
Check your thrust arm bushings. Try to move the arm side to side where the bushing connects and see if it flex’s a lot.
You can live in a car but you can’t race a house.
05-18-2024, 12:47 PM | #4 |
Rep 216
Thank you for the responses. I went and checked the various control arms and felt or so no play. Which thrush bushing typically causes the clunk? Didnt realize there were so many control arm components
05-18-2024, 04:53 PM | #5 |
Rep 5,409
As the brake pads "grind" against the slots in the rotors, there will be a sort of grinding/clunking sound.
Was the sound there before the slotted rotors? |
