      12-11-2008, 06:19 AM   #89
Citizen Z
Alpine Master
Citizen Z's Avatar
Drives: '08 135i AW Sport
Originally Posted by JohnL135I View Post
Nice flight gloves. Army?
Alpine White with Taupe Leather 135i, Sports Package, Heated Seats, Comfort Access, iPod Adapter
Fastness: http://www.1addicts.com/forums/showthread.php?t=252727
      12-12-2008, 07:25 PM   #90
imported_Noob
Drives:
Is twisting the factory oil filter hard? I heard its hella tight, like on most cars.
LOL. People are rolling in bimmers and they are asking all kind questions. Just teasing. I guess I had to learn and do shit from scratch.
Funny how even w/ oil, not much people suggested Amsoil or Exon Mobil 1. I would have nothing less other than either of those 2 brands.
NEVER OVER SHOOT your oil level, NEVER ! You are fine a bit under, but NEVER OVER ! So play it safe, follow instructions and calibrate afterwards.
Thanks.
      12-22-2008, 10:31 PM   #91
JohnL135I
Donkey Kong King
Drives: 2012 Boss 302
USAF:thumbup:
[SIGPIC][/SIGPIC]
      12-23-2008, 03:24 PM   #92
etobn01
FLBIMMER
Drives:
Great Vid! so John how much money did you spend on the oil filter?
      12-23-2008, 06:23 PM   #93
amsfoto
photographer
amsfoto's Avatar
Ireland
57
Drives: AW e92 335i, JB 135i
According to an older DIY on e90post, the filters are $15 and BMW's synthetic 5W30 is $5 a quart.
Jet Black 135i Coupe - 19" Work VS-XX - KW V2 - BMW Performance - Riss Racing - Burger Motorsports - Active Autowerke - 3DDesign
      12-24-2008, 03:00 PM   #94
audi2bmw1
audi2bmw1's Avatar
21
Drives: 09 montego 135i/acura vigor
and the filters are too bad..i was able to untighten it and tighten it by hand without any tools just fine...just used a microfiber cloth to get grip..make sure the green line matches back up...as the video states..easiest oil change ive ever done on any car!!
the bmw syn oil is 7 a qt...at least at my dealer..and the filter was around 20....i didnt care as my CA gave me a 50 giftcard...times 3...lol hes a good guy
09 135i montego blue 6speed..RR catch can,CDV,DCI intakes,stett charge pipe and tial bov, the above mods are not installed on my car, i just want to seem cool
Devils own water/meth dealer-PM me for info
former car/ 2001 audi TT ~290bhp :w00t:
      01-04-2009, 06:09 PM   #95
KCRich
Drives:
Thanks for the vid, John.
Like another poster, when I removed the oil filter cap (which was VERY tight in my case) the lettering on the filter is on the visible side. I replaced the filter the way it was positioned originally, as opposed to what was shown in the video. Is there a difference? The filter appears to function the same in either position.
Also, am I correct in assuming that you should lube the filter itself with a little bit of oil in addition to the two rings?
Thanks!
      01-04-2009, 08:24 PM   #96
JohnL135I
Donkey Kong King
Thanks!
Looking at the design of the filter I don't think the direction matters. I don't think the filter needs to be pre-lubed, just the o-rings. I base this on a regular oil filter, I've never put oil into a oil filter I was replacing, just lubed the o-ring.
[SIGPIC][/SIGPIC]
      05-26-2009, 04:13 PM   #97
e82vette
Drives: 128i
do you mind telling me where you jacked up your car?
      06-06-2009, 10:37 PM   #98
JohnL135I
Donkey Kong King
Factory jacking points, but you you need to use a piece of wood or you can damage the plastic part.
[SIGPIC][/SIGPIC]
      06-07-2009, 01:10 AM   #99
cagekicker
cagekicker's Avatar
Drives: '09 crimson red 135i
good video!
      06-07-2009, 02:07 PM   #100
cimbali
Drives: BMW
nice video...expect that I wouldnt use a couple of jacks...that's dangerous. rhino ramps work well or put the car up on jack stands.
      06-08-2009, 10:25 AM   #101
Eazy-e
Dope-like a pound or a key
Eazy-e's Avatar
12
Drives: 09 e82 135i
Rhino ramps are good and all but has anyone noticed that the car still has old oil in it when its jacked up or on ramps? I noticed how cars always have some oil left till you level it out
      06-08-2009, 11:05 AM   #102
My135
85
Drives:
Why it is important to line up the greed marking? Any one know. Thanks.
7/08 135 Coupe, Crimson Red, 6 SP, Sport, Taupe Lette/Aluminum. Performance Mods: JB4 on Map 5, BMS DP Fix V3, Injen polished intake, AR Catless DP, Maddad resonated mid-pipes, aFe exhaust polished tips, ST Suspension Coil Over and Hotchkis front sway bar. Others: BMS OCC, BT Scanner, Mud Flap. Next Mods: AA Front Strut Brace.
      06-09-2009, 01:10 PM   #103
RIbimmer
Drives: '09 128i, '17 i3 BEV
John,
Thanks so much for the video. It's been more than fifteen years since I changed my own oil, but now that I've got a car I care about it'll be fun to give it a try.
Thanks again!
      06-09-2009, 01:22 PM   #104
cimbali
Drives: BMW
I guess matching to the green marking is an attempt to estimate the 25nm required torque...although I dont think that is a very accurate way to do it. I would just use a torque wrench with the appropriate socket.
You definitely do not want to over torque this cap as you may have issues trying to remove it next time.
      06-09-2009, 01:38 PM   #105
jkp1187
Unindicted co-conspirator
Drives: to work, mostly.
Originally Posted by Mad Dragon View Post
Before you ruin your filter housing, you need to buy one of these:
You need this part? Can't just use a regular old filter wrench?
      06-09-2009, 02:08 PM   #106
JohnL135I
Donkey Kong King
Rhino ramps work the best.
The BMW oil filter removal tool is a must have, I just picked one up and this thing works great!!
Also, I highly recommend you change the oil when the car is cool. Or, make some sort of shield because the oil will shoot out of the drain plug and get all over the skid plate...... just did the break in oil change on my new 1 and I made a huge mess..
Also, for those considering an alternate oil, I just used Mobil 1 0w-40 euro forumula and my oil temps have decreased. This oil is BMW approved.
[SIGPIC][/SIGPIC]
      06-09-2009, 05:15 PM   #107
SlickShift
SlickShift's Avatar
323
Drives: '11 BMW E90 M3 ZCP, '21 X5 ZMP
You should never change your oil when the engine is cool. It's too viscous and won't drain completely.
-Nick
2018 BMW 440i - M Sport, Exec
Glacier Silver Metallic/Coral Red Dakota
Retired: '00 323i, '06 325Ci, '09 135i, '06 Z4M Roadster, '93 525i, '76 2002, '14 X1, '14 M235i, '16 X4, '16 435i
      06-09-2009, 06:02 PM   #108
jkp1187
Sorry, but does "must have" mean: you cannot complete the task without this tool? Or does it just mean it's really freakin' awesome?
      06-10-2009, 07:04 PM   #109
JohnL135I
Donkey Kong King
It is really awesome, however, you can still remove the filter housing using other methods.
[SIGPIC][/SIGPIC]
      06-11-2009, 07:15 AM   #110
jkp1187
Thanks!
1addicts
