      03-23-2020, 01:24 PM   #1
nate196
nate196's Avatar
Drives: 2018 540i Xdrive
Can X5M Comp be ordered with 22s all around ?
Hello friends
I'm curious to know if the x5m comp be ordered with 22s all all around as a pose to 22 rear and 21 front
Thanks in advance
      03-23-2020, 01:49 PM   #2
Alan l.
Alan l.'s Avatar
5453
Drives: 2020 F95 X5M Competition
pretty sure no and its because the Michelin tires that BMW M specifies to be used on the X5M doesn't come in the correct size in 22".
      03-23-2020, 01:50 PM   #3
nate196
nate196's Avatar
Thank you
      03-24-2020, 04:29 AM   #4
Kief
Kief's Avatar
4440
Drives: '24 iX50; '23 i4 M50
Michs 4S come in 22" 285/315, but as you alluded to, the compound could be slightly different. Once my Contis wear out, I plan on running the 4S on my M50i, moving from 275 to 285 up front shouldn't be an issue.
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired
      03-24-2020, 09:07 AM   #5
GSG5
GSG5's Avatar
127
Drives: 2020 X5MC (MBB/SS)
This is probably a stupid (different) question - so flame me as appropriate - how much leeway is there in the relationship between the width of the wheel (e.g. 10.5) vs the width of the tire (e.g. 275 vs 285)?
I think the stock width of the 21” front wheel on the F95 is 10.5 and the stock tire width is 295. Could you put, for example, a tire with a width of 305 on that same wheel or would you have to get a wider wheel (e.g. 11)? I guess my question could go the other way too - could you put a 285 tire on a 10.5 wheel or would you need to go down to a 10 wheel?
I can’t imagine there is much leeway, but I was thinking there may be some without having to actually replace the wheel...maybe not though.
      03-28-2020, 10:26 AM   #6
spike5150
Drives: 2020 X5 M50i
Depends on the tire. Manufacturer will specify rim width range that is compatible with each size tire. Usually a decent range.
      03-28-2020, 02:13 PM   #7
infamousdiz
infamousdiz's Avatar
Drives: (17 X5M)gone 2018M3CS HERE
Ohh it could be a large difference, you can't play around with the X drive. Do your research before you start switching tires. 285,30 275 30 are very different tires, your aspect ratio is percentage based not a flat number, each axle needs to be with in 1% -2% revs per mile of each other. Your 275 could be 712rp mile while your 285 are 670rp mile. The X will burn its self out, flat out break, constantly think your front wheels are slipping, screw with the handling characteristics. BMW didn't just slap on 275s because it was an arbitrary number and make their own special tire compound with the manufacturer
I didn't know I couldn't do that. But I did know I couldn't do that.
      03-29-2020, 04:16 AM   #8
Akgq
Abu Dhabi
72
Drives: 2016 LBB X5M f85 (current)
100%,
My friend was forced to change one of his tires on a road trip and the x drive didn’t survive 40 miles. It went into safety mode and limited everything.
Copyright ©2000 - 2024, vBulletin Solutions Inc.
