Best Gasket Kit for N52??
04-20-2021, 12:17 PM | #1 |
Rep 6
My 06 330xi has been slowly leaking from the valve cover gasket as well as the oil filter housing gasket so im looking to do a gasket change pretty soon here. While I have everything taken apart im looking to replace all gaskets including ECC seal and possibly valvetronic gasket if necessary. Btw I have the aluminum valve cover so its the steel/metal gasket. If anyone can recommend a reputable kit that holds up good that would be much appreciated.
Cheers |
04-20-2021, 05:00 PM | #2 |
Rep 2,099
https://www.fcpeuro.com/products/bmw...Lw_wcB#fitment
Bottom of the page has the other items you should probably get (up to you on the actual ESS itself along with its seal). You don't really get a packaged discount. https://www.ecstuning.com/b-assemble...11127581215kt/ or https://www.ecstuning.com/b-assemble...1377524879kt1/ https://www.ecstuning.com/b-assemble...it/n52ofhgrkt/ https://www.fcpeuro.com/products/bmw...11428637821kt1 |
