05-21-2023, 02:23 PM | #23 | |
Rep 208
And then usually how long does it take it? |
05-21-2023, 08:25 PM | #24 | |
Rep 8,698
Drives: eVeRyOnE mAD!
**we could do this on the 45e with Battery Control (if set to 100%) |
05-21-2023, 09:51 PM | #25 | |
Rep 208
06-12-2023, 01:31 PM | #26 |
Rep 7
Hola everyone - just got my 50e on Friday. Took about a 120 mile trip yesterday (60 miles each way 95% freeway). I drove the vehicle in hybrid mode - default way it starts up. Started with 41 miles of electric range. By the time I reached my destination, I had drained the electric range down to zero, but then recouped two miles through regen. I was parked for about an hour, then I tried to precondition the cabin using the My BMW app I received a notification that preconditioning was not possible due to low battery. So I started the vehicle normally and it was in hybrid mode. It showed 1 mile electric range remaining. I pushed the battery hold button and began my 60 mile return trip. When I got home the vehicle showed 4 miles of electric range. Based on this, I think that regenerative braking does charge the battery in battery hold mode, but the ICE does not. Really disappointed to learn that cabin preconditioning is limited to HV battery only.
bjjeong10.50 |
06-12-2023, 01:56 PM | #27 | |
13274
Rep 19,798
06-12-2023, 03:42 PM | #28 |
Rep 208
ICE charge, but only up to 10%(4miles). After 10%, any energy reserved will be used right away.
You can press BH 10 minutes before the arrival then it will be charged to 10% and will have just enough to precondition. Or you can play with BH button and actively charging yourself from braking.(Brake regen then press BH button twice so increased battery level becomes new hold level) |
06-12-2023, 08:40 PM | #29 | |
Rep 8,698
06-14-2023, 08:09 AM | #30 | |
Rep 77
06-14-2023, 08:19 AM | #31 | |
Rep 208
06-14-2023, 09:53 AM | #32 |
Rep 77
Charging state was 0 miles and just started to drive... over the next several miles it gradually went up, but no higher than 5 miles... some minor up and down hills. (Southern PA hill country)
09-27-2023, 05:24 AM | #34 |
13274
Rep 19,798
It is not possible to get an exact answer to that since there are too many variables in play. It seems like many, if not most, try and keep about 30% and that has been working well. You can likely get away with half-that and be fine.
09-27-2023, 06:00 AM | #35 |
Rep 8,698
on my 45e, I’ve been able to precondition (AC) with the electric gauge as low as 2 miles, though I never tested how long it would run. (2 miles is roughly 6% on the US 45e.) while a preconditioning session automatically cuts off after 30 minutes, I don’t think 2 miles on the gauge is enough to run that long. I would also think it may require a higher minimum charge level to precondition with heat, or maybe not as it just won’t run as long compared to AC
09-28-2023, 08:31 AM | #36 | |
Rep 99
There's too many variables to get a fixed answer. At a pure WAG running the A/C long enough to cool down the vehicle (5 minutes? I didn't time it) seems to use about 1kwh of power. Assuming this rough guess is correct and assuming best practice is to leave a minimum of 10% charge then I would say you should have somewhere in the 15-20% range. |
10-03-2023, 01:21 PM | #37 |
LeeRiz
72
Rep 99
don't even have my 50e yet but reading up as much as i can. this whole thread was great as i was just thinking about "remote start" (preconditioning) and how to use it on the new X5 when i get it. I use my current remote start every single day; turn on my car about 2-5 minutes before leaving to get everything up to active state and cool/heat the interior a bit.
as for regen braking to regain some battery on long trips... i saw on youtube that there's an option on a different BMW to have the regen braking at low/med/high which changes the "harshness" of the braking when you let off the gas (1 poedal driving). Is that an option for the 45e or 50e? thanks! |
10-03-2023, 01:51 PM | #38 | |
Rep 8,698
2) the 45e doesn't have a way to adjust the level of regeneration, and i believe neither does the 50e. 1-pedal driving and the ability to adjust regeneration level appears to be featured on full EVs (not just BMWs either). i'm not personally aware of any PHEV that has this feature |
leo92372.00 |
10-03-2023, 07:10 PM | #40 |
Rep 8,698
you can completely turn off regenerative braking on the 50e? which drive mode(s)? on the 45e, the closest we can get to turning off regenerative braking (coasting like rolling in Neutral) is Hybrid Eco Pro, but even then certain requirements must be met first. if not, regenerative braking re-activates
10-09-2023, 08:11 AM | #41 | |
Rep 2,105
12-15-2023, 08:17 AM | #42 |
Rep 1
Regeneration on 50e
The 50e has 2 levels of regeneration....there is regular regen and also adaptive regen that uses the cameras to determine what is around you, and it brakes more or less depending on what's close. if a car is in front, it really slows the vehicle when regen kicks in, but if that car switches lanes for example, you can feel it release the heavy braking. The dealer told me you also can turn it off completely in the settings, but I have not tried that.
