06-11-2019, 06:30 AM | #1 |
114
Rep 325
Won't stay on Presets
So now every time I start the car I have to go to Media and select Presets to be able to scroll through my radio/nav stations. However, on next restart it will switch to regular Nav or Radio depending which I was on when I shut if off last. Anyone had this? I can't find and "default to presets" setting.
____________________
Current: 2019 g05 X5 xDrive40i 2020 f30 440 xDrive Convertible 2004 e85 Z4 3.0 |
06-11-2019, 07:01 AM | #2 |
Rep 2,609
We're all annoyed by that. Stupid implementation. Setting one of the shortcut buttons to Presets helps.
06-11-2019, 07:09 AM | #3 |
114
Rep 325
I've had the car since Dec, and it hasn't done that until this week. What caused it? Software update?
06-11-2019, 07:23 AM | #4 |
Rep 245
And I thought it was me, not the software. Even when deleting the XM (and checking the presets) in preferences, it still reverted to all XM as default.
I'll try to devote one of the programed buttons. |
06-11-2019, 07:28 AM | #5 | |
2442
Rep 1,948
06-11-2019, 08:28 AM | #6 |
Rep 2,609
Since there is no OTA s/w updates yet in North America, only you know if you've recently had a software update (or possibly only your service department if they didn't tell you). In my case, I've been on 3/2019.45 since pickup 4 weeks ago and the issue exists on that version for sure, previously discussed in a couple of other thread on the forum. If we find it is version-specific, then it will be another nail in the "BMW software teams don't know about regression testing" coffin.
06-11-2019, 09:06 AM | #7 |
Rep 3,507
Mine does not go back to anything other than what was left. If I'm on presets turn off come back the next day or from going inside store it is still at my presets. Still playing the same station. Are you all saying this does not happen? That is strange to me
2022 M8 Comp Convertible
West Austin38.00 |
06-11-2019, 09:14 AM | #8 | |
2442
Rep 1,948
This is because on startup, the car will no longer be in the presets "mode" but rather on satellite radio "mode". |
06-11-2019, 09:24 AM | #9 |
Rep 3,507
OH let me try this at some point.....
06-11-2019, 09:37 AM | #10 | |
Rep 7,467
This allows for multiple situations. I can scroll through the presets (using button #6) or I can choose to select another station on the radio band I'm listening to...instead of having to go back into iDrive. Do you guys not have the scroll button or something similar on your G05s?
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 06-11-2019 at 09:48 AM.. |
06-11-2019, 12:10 PM | #11 |
Rep 128
It used to work the 'proper way' on 2018.11 and other early builds. it changed to this new default when I was upgraded to 2019.37. Just baffling.
06-11-2019, 12:16 PM | #12 |
Rep 282
Drives: 2023 BMW X5 M Competition
i'm starting to wonder if bmw even knows this is happening because it wouldn't make sense to program it this way.
06-11-2019, 03:10 PM | #13 | |
2442
Rep 1,948
If you use the scroll wheel, the same issue occurs where you are no longer in your presets, but rather are in the last used type of radio used when you turned the car off. |
06-11-2019, 03:45 PM | #14 |
Rep 978
Same issue happening here.... just started a week or so ago, which is weird... but then not given the pile of shit that BMW's iDrive 7 is. Nothing surprises me any more.
06-11-2019, 04:31 PM | #16 | |
Rep 4,327
I really feel bad for you owners, you bought the car in good faith and are now stuck with having to deal with these issues...and I want one but am holding off due to all I've been reading. |
06-11-2019, 06:04 PM | #17 |
Rep 118
I just got my car back from having the update to .48 and it also does not go back to presets. I am missing my 2015 X5 more everyday - it may not have been as technologically sophisticated but it just seemed that everything seemed to operate so much more logically.
06-11-2019, 08:02 PM | #18 |
Rep 293
06-14-2019, 10:34 AM | #19 | |
Rep 1
I'm having the same issue with my '19 330xi and stumbled onto this thread when looking for a solution. I've since contacted the BMW Geniuses about it, hoping that the bug report/feature request will make its way to the appropriate people. This was the response:
I used this form, but you could probably also directly email bmwgenius@bmwusa.com https://my.bmwusa.com/contact-form.html |
06-14-2019, 11:22 AM | #20 | |
Rep 3,507
I enter the car, start it is play 002 my next station in order on my presets is 045, so when I press next it goes to 045 than 047 and so forth. No issues with it going to anything else. My software was just updated to 03-2019-48.
06-14-2019, 05:34 PM | #21 | ||
Rep 2,609
06-14-2019, 05:37 PM | #22 |
Rep 3,507
So my presets are all SXM, and I have another button to the only radio station.
I take it you are saying if in my presets I have that radio station to test then? I can do that and report back tonight.
