01-20-2020, 09:04 AM | #1 |
Rep 1,069
check engine light came on
i left my car in the airport for a few days, came back home last night and drove without any issue. this morning the check engine light is on; but the car is driving perfectly fine
called the dealership and they cant set up the valet service until thursday morning but advised me to avoid driving it.. which is not possible.. my SA did say most likely it's the active grill which they've been having issues with.. any body have any similar issue?
2018 M3 6 spd
2017 M3 AW/SO 6spd 2014 435i M sport BSM/Coral 6spd (retired) 2013 550i M sport Alpine White/Cinnamon (retired) |
01-20-2020, 09:35 PM | #3 |
Rep 4,327
01-20-2020, 09:41 PM | #4 |
Rep 2,609
Is that really still a thing even on the G05? The bloody car drives itself and detects whether you're nodding off for deity's sake, it can't tell you directly if the gas cap needs attention rather than "engine might be blowing up ... psych, ha ha, just the gas cap again!"
01-21-2020, 02:22 AM | #5 |
Rep 1,241
99.9999999% of the time, you will get the infamous P0411, P0440, P0442, P0446, P0455 Check engine light codes.
It is your evaporative system.... which means that because these cars are so sensitive to emissions requirements..... almost ANYTHING can set one of these off. Got a bubble in your fuel line? Turned a corner too hard with a near-empty tank? Started the car with the fuel cap off? Went through a car wash? These codes are commonplace, and not really anything to worry about. Go to your local Autozone and pick up an OBD scanner. You can get a cheap one for like $35 or less. Read the code Google what it means Clear the code If it comes back??? Yea... THEN make an appointment at your dealership. If you bring the car in now, and it reads one of the common codes above, all they are going to do is clear the code. I GUARANTEE they won't do a single bit of actual "work". You will have wasted your entire day for them to do something you could have done in 30 seconds yourself.
15+ PAGE BUILD THREAD:https://g05.bimmerpost.com/forums/sh....php?t=1694019 690HP / 928nM Dynotune:https://g05.bimmerpost.com/forums/sh....php?t=1729813 6-Piston/4-piston BBK:https://g05.bimmerpost.com/forums/sh....php?t=2097342 |
01-21-2020, 11:08 AM | #6 |
Rep 7,468
Florida is one of the "free" states that allows automotive stores like Autozone/PepBoys/O'Reilly's/Advanced Auto/etc to read OBD II codes.
The CEL means something in the emissions system has registered a fault. It could be one or two of multiple things...and unless the light is flashing...you should be able to drive the vehicle to at least find out what the DTC (diagnostic trouble codes are). Even though you're still under warranty and the dealerhship will look at your car for free...you can "pre-arm" yourself with information and get the 5 digit code that has been part of the OBD II federal mandate since 1996. In fact, with the 5 digit "P" code...you can simply google the code since there's been decades of discussions about them. For a quick example, Ninefourteener posted some P codes...and if you were to google "BMW P0411 you'd get an idea of what info is out there by just doing this type of simple search for OBD II codes registered by the Check Eng Light (CEL). Good luck....there's no need to guess or have to wait until you take it into the dealer...you can find out for free what sensor has registered a fault code if you have an OBD II scanner/reader. And if you don't have one...again, Florida is a state where you can get it done for free by just driving there and asking them to retrieve the fault code. (don't forget to write it down or have them print it out for you)
01-22-2020, 11:05 AM | #7 | |
Rep 1,069
2018 M3 6 spd
01-22-2020, 12:50 PM | #8 |
Rep 4,327
Right, so did you check your gas cap? That will cause the error you are showing on the scanner. Once you unscrew and rescrew the cap, it will take a few miles before the error goes away, if that is the root cause.
01-22-2020, 01:04 PM | #9 |
Rep 1,069
ya i filled up yesterday and made sure it is on tight. the dealership is picking it up tomorrow from my office and dropping off a loaner so i'll find out tomorrow for sure what it is. i've heard that they've been having trouble with the active shutters on the grill
2018 M3 6 spd
01-22-2020, 01:06 PM | #10 | |
1053
Rep 1,952
01-22-2020, 01:06 PM | #11 | |
Rep 4,327
01-23-2020, 10:14 AM | #12 |
Rep 7,468
Info below is from this site: https://www.yourmechanic.com/article...by-jay-safford
P0456 code definition
01-23-2020, 10:15 AM | #13 |
Rep 1,069
thanks. the dealership picked up the car this morning. we'll see what they say
2018 M3 6 spd
01-24-2020, 10:37 AM | #14 |
Rep 1,069
So this is what was the issue
2018 M3 6 spd
Marty in NY2709.50 |
01-24-2020, 02:13 PM | #15 |
Rep 7,468
Thanks for the follow up...hope the new LDP does the job.
