01-25-2020, 12:32 PM | #1 |
Rep 214
Remote start turns on heated steering wheel?
The last two times I used remote start I got in the car and the steering wheel was warm. Is there a setting for this?
01-25-2020, 12:41 PM | #2 |
13169
Rep 19,660
What version of iDrive are you running? I believe some members posted that in the 11/2019.xx version they added the option for heating the steering wheel in the climate rules app.
01-25-2020, 12:43 PM | #3 | |
Rep 214
01-25-2020, 12:45 PM | #4 | ||
Rep 214
01-25-2020, 01:18 PM | #5 |
13169
Rep 19,660
Perhaps there is no option for it and it just comes on automatically when the seat heat does. You can always run a few tests and see if that is the pattern you are seeing. Hopefully some others will chime in.
01-25-2020, 01:47 PM | #6 | |
Rep 214
01-25-2020, 01:57 PM | #7 | ||
Rep 2,420
01-25-2020, 02:03 PM | #8 |
Rep 2,420
I didn't find a menu item to control this function either. On preheating the 45e the seat and steering wheel are also activated below a certain temperature. I don't know if this is the same set temp. as for automatic seat heating activation. Could be indeed. Strangely the heated armrests are not activated.
mhodx5111.50 |
01-25-2020, 02:19 PM | #9 | |
Rep 214
01-26-2020, 06:40 PM | #10 |
Rep 106
I have a 40i M-Sport and find that the heated steering wheel seems to turn itself on after a remote start and below a certain temp. It actually may come on when it's below a certain temp and I start the car manually, will check and report back on that one.
Even with the seat heat rules set to heat the seats at or below 37f I never had them come on with remote start, only after I get in the car and press the start button - this is a little annoying. |
01-27-2020, 08:10 AM | #11 |
2435
Rep 1,942
01-27-2020, 08:15 AM | #12 | ||
Rep 418
Drives: ‘20 X5/M50i (ordered); &
01-27-2020, 08:32 AM | #13 | |||
Rep 2,420
01-27-2020, 08:40 AM | #14 | ||||
Rep 418
I also applaud your actual reading the manual. I've tried repeatedly but it's tedious. |
01-27-2020, 09:02 AM | #15 | |||||
Rep 2,420
I have the app on my iPhone. |
01-27-2020, 10:17 AM | #16 |
1051
Rep 1,951
For me, it seems when I remote start, by the time I'm in the car the steering wheel is warm/hot. Then seems to cool off - as if it turns off when the car starts. Since there's no indicator to let me know if it's on or not, it's hard to tell what's going on. I've tried pressing the heated steering wheel button to see if that turns it on or off. The first press, I don't get a notification on the dash, second press says heated on, third press turns it off. It's odd behavior. Why have the steering wheel come on but not the seats? There's no setting that I know of to control this.
01-27-2020, 10:24 AM | #17 | |
Rep 214
01-27-2020, 11:36 AM | #18 |
1050
Rep 1,537
Chicago winter here, so it is cold. Remote start does not activate seats or steering wheel, only climate control to warm up the car.
It is impossible to get an answer of what the car can do with remote start from anybody it seems. |
nvsocr755.00 |
01-27-2020, 12:16 PM | #19 |
Rep 135
07/2019.55 >>> Neither steering wheel nor seats heat are getting activated with remote start on this version.
BMW X5 2019 - Software version 03/2021.36
Mineral White on Canberra Beige + Walknappa Leather Dashboard |
01-27-2020, 01:38 PM | #21 |
113
Rep 325
I'm on 11/2019 as well and mine heats up when started remotely, even if been sitting for hours. Not sure if I left it on when the car was shutdown. It didn't do this until I had the 11/2019 upgrade done.
____________________
Current: 2019 g05 X5 xDrive40i 2020 f30 440 xDrive Convertible 2004 e85 Z4 3.0 |
01-27-2020, 03:19 PM | #22 | |
64
Rep 43
